Question about Maytag Neptune MAH6500A Front Load Washer
Maytag washer MAH6500 leak - door boot issue?
I have a maytag front loading washer MAH6500 that has started to leak a little. All conections are dry but i notices a slight rip in the rubber door boot near the bottom as well as a hole at the very bottom which almost looks like a drain hole. Is this a official drain hole? And should i repair/patch these two (or one) issues?
    President:
  • 1,304 Answers
There is a drain hole at the very bottom of the sump
about 1/4 in
if you ahve any other holes you will need a new boot
there is no real way to patch them, most patches will not flex enough to stay in place
ive included the part number you can order from sears
22003070
the best way to get one over on sears is to order it
then you cazn either fix it kinda hard but id walk you through it
or when the part arrives shedule service, just tell them its leaking
only when the tech gets there tell them you have a boot
sears hates self diagnostics and you will go to the bottom of the list
Posted on Oct 07, 2009
MY maytag washer is leaking water from bottom of machine - the repairman said there is a hole in the door - please advise!!!
Check your rubber boot connecting the tub to the machine, it will fail. If you find no hole in it and have a drain in the bottom of boot, then pull front panel to see if drain tube is broken. If thats not broken, everything else will be visible as far as drain lines etc, just look for signs of leakage.
Jan 19, 2010 | Maytag MAH6500 Neptune Front Loading...
Order/Replace Rubber Boot on Maytag Washer?
it can be quite tricky to fit, you can buy one,I would however advise to get a supply/fit quote from an engineer as he will get discount on the part, unless you are good diy person ,get hired help....
Nov 28, 2009 | Maytag MAH6500 Neptune Front Loading...
My Maytag Neptune front load washer door won't lock and won't spin
Mine did the same, we just got a $300 mother board and now it works great... Good luck.
Sep 16, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag neptune front load washer wont start when button pressed
This is joyce
first lets start simple unplug the machine and leave unpluged for 1 min. replug back, see if this solves the problem.
thanks,
joyce
Feb 06, 2009 | Maytag MAH6500 Neptune Front Loading...
Neptune washer
check arround the rubber bellows that the door seals aginst, maybe a hole in it, could be a pump leak drain hose leak
a lot of could bees i know but one of these
Apr 09, 2008 | Maytag MAH6500 Neptune Front Loading...
Leaking water Maytag Nepture washer MAH400AWW
open door and feel around the rubber bellow possible tear causing leak
Feb 27, 2008 | Maytag MAH6500 Neptune Front Loading...
Mah6500 maytag is leaking
Us too are having the same problem - and recently - it has been filling with water on its own - and not emptying!!! We have had major floods!!
Jan 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
Maybe you over-loaded, or you did not shut the door properly. Try reading the users' manual.
Mar 12, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MAH6500A Front Load Washer Logo
461 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
