Question about Toshiba Satellite A45-S250 Notebook
Cooling system fails
When my laptop boots up, a pop up window is displayed stating that the cooling system fails and to shut down immediately. How do I go about fixing this problem?
  • 4 Answers
There are two fans in this unit. It was my secondary fan that had failed. The primary fan is the one on the bottom that you can see, and the secondary is in the back near the usb connectors.
You'll need to determine which one has failed. I was able to diagnosis mine by setting the power management features to Level 2 from 4 on the cpu, and the fan setting to "battery optimized."
In that particular configuration, I could hear a fan turning on, but it wouldn't run long enough to trip the error message. I was then able to use the machine in a very slow speed waiting for the replacement fan to arrive. The fan was about $35, but because of it being buried so far into the internals, it took me three hours to disassemble, replace, and reassemble the machine.
I used the pictures here: http://www.irisvista.com/tech/laptops/ToshibaA45/Satellite-A45-remove-hinges-1.htm as a guide for assembly and disassembly.
Posted on Jan 07, 2010
    Novelist:
  • 128 Answers
Most likely the internal cooling fan has stopped spinning.
I would try using a vacuum cleaner and apply suction to the cooling vent on the laptop. This will help to remove trapped dust and potentially free up a stuck fan.
Sometimes a little puff of air from a can of compressed air in the fan outlet can get the fan spinning again, although use the vacuum first so that any bits of dust are not pushed into the fan.
It is quite possible that the fan needs to replaced, which is a typically a $60 part that would require laptop disassembly to replace.
Posted on Oct 07, 2009
  • 74 Answers
I think your cpu fan is already facing problem its better to replace it other wise it will keep working like that sometimes good and more than bad.
Computer shuts down
Make sure Windows Update is turned on. For Windows 7, Vista, and Windows 8 there are Updates that resolve some hardware glitches such as the one you are experiencing.
Apr 03, 2014 | Dell (6F858) Cooling Fan
Cant log on to my laptop
Probably the easiest way to resolve this issue is by following the steps outlined below.
1. Shut down the computer.
2. Turn the computer on and immediately press F8 repeatedly until you get the "Advanced Boot Options" menu.
3. use the down arrow to select "Safe Mode" and press enter.
4. Window is should start with a "Help" window.
5. In the help window there is an underlined "What is System Restore?"
Click on that and "Click to open System Restore"
6. click on that and a new window comes up recommending restoring to a previous state.
7. Click ok and the operating system should restore your computer successfully and reboot into normal mode.
//javaftper
Aug 01, 2010 | Acer Aspire 4520-5141 Notebook
My laptop turned off but it has 35% remaining battery
Laptop turns off suddenly? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage.
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
May 29, 2010 | Computers & Internet
Turns off suddenly
Mar 27, 2010 | Toshiba Satellite M55-S331 Notebook
Boots up windows runs for 5 mins then system shuts
You may have a cooling problem (with older computers), if you hear your fan running excessively and then it shuts down on you. Otherwise it is more likely a hard drive issue.
Jan 25, 2010 | Toshiba Satellite P25-S5263 Notebook
My computer restarts alone ! on/off ?
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
Good luck
Dec 10, 2009 | Acer Aspire 5500 5570-2609 Laptop
My laptop keeps shutting down at random times. I
Good luck
Oct 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Shuts down
Hi..
If the laptop shutdown maybe it cause overheating.
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | HP Compaq Presario V6000T Notebook
Cannot shut off & no display
The eMachines M5105 is notorious for failing to boot if left unplugged and powered off long enough for the battery to become mostly discharged. Plugging it in to AC power will cause the battery to start charging; and the hard disk drive to spin while the CPU cooling fan cycles on and off vigorously. THE UNIT WILL NOT BOOT UNTIL THE BATTERY IS NEAR FULLY CHARGED; then THE AC DISCONNECTED; and then THE (charged) BATTERY REMOVED AND RE-INSTALLED! Most units will boot after following the foregoing procedure.
Jun 24, 2009 | E-Machines M5105 Notebook
THE LAPTOP JUST SHUTS IT SELF DOWN
Check if the cooling fan is actually turning on or if the exaust is cloged with any derbis. If so, you should try cleaning them and later observe if it works. However, if the cooling fan fails to run you should replace it.
Mar 22, 2009 | Toshiba Satellite A205-S5809 Notebook
Toshiba Satellite A45-S250 Notebook Logo
318 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
