Question about Polaroid i830 Digital Camera
Camera shuts off right after I turn it on
When I turn on my camera it shuts off right away.I charged the battery thinking maybe the battery was dead, but it happens again after I charge the battery. I have left the battery in the camera for a long time. So I'm not sure if this is why the camera is doing this.
jackboy
  • 2985 Answers
SOURCE: Won't turn on! Possible lens problem?
If you have manually tried to adjust the lens then it is ruined - these are very fine mechanisms manual fiddling usually fixes them -for good. A repair is not usually an option Check the Polaroid tech support team first of course. But the cost of shipping/insurance and inspection plus the lack of parts will make it a fruitless task Christmas is but 6 months away though. ;-)
Posted on Jun 16, 2007
SOURCE: Dead battery?
Ugh. I have the EXACT same problem!!!!! It's extreamly annoying. When I turn my camera on it turns on, you see the polaroid screen, and theres this buzzing sound? and then it turns off. I'm so frustrated and don't know what to do. Should I take it into a camera shop? or no, Someone helppp!.. and It's not the battery.
Posted on Apr 25, 2008
  • 11967 Answers
SOURCE: Turns off right away
You probably didn't get all the sand out and now it's preventing the lens from opening correctly prompting the camera to shut down.
Posted on Aug 16, 2009
  • 561 Answers
SOURCE: Why does the battery die after only two minutes?
this may depend on what batteries are being used or some error of the camera or its settings.
1 when this happens try to open the battery compartment and close it again after a few seconds and see if this resolves the problem.
2 test the batteries in some other device such as a torch or other device and see if they work in that if so it maybe a problem with your camera or its settings.
3 if you are using regargeable batteries check in your camera setting if there is a battery type setting and ensure it is set to the same as the batteries you are using.
it is wise to use NiMh or other rechargeable batteries with a high rating such as 1000 or 1800 mAh normal alcaline batteries may not have the power to operate the camera for long.
note: if the flash is being used this will also run down batteries quicker also if images or video clips are being viewed on the camera this will also cause faster battery usage. also if the camera is being switched on and off after each few shots this may also reduce bettery life through lens extension and retraction, it maybe better to leave the camera on longer than keep switcing it off see if you have a power setting and set the camera to switch off automatically after 3 minutes if not being used then to keep the camera open if shot opertunities are still ripe the just half depress the shutter button to keep the camera live. this may help.
if this does not improve then recommend to replace the batteries as they maybe defective or the camera go to a certifed agent for testing.
Posted on Nov 13, 2009
  • 11967 Answers
SOURCE: The battery is charged but when i turn on the
Could be a lens problem...try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 12, 2010
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
When I turn on my camera it shuts off right away,i charged it many time for many hours, but no luck,it kees shutting down
by now you may have "cooked the battery!" you can over charge a battery,,,and if you do its then a dust bin job,,,try a new battery in it first,,,,
Aug 30, 2010 | Kodak EASYSHARE M1063 Digital Camera
My camera turns off right after i turn it on. it
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Unfortunantly KODAK do no longer repair this model. They offer a Trade up option where you for 25-30% cheaper than the listed price can exchange the camera to any newer model provided KODAK has the model in stock.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 24, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
After charging the Battery the power button flash blinks
i think the red light means low power for battery... maybe just maybe your battery didnt really charge.. im not saying that its the charger, but try to buy a new rechargeable batteries, use it then charge it and compare it with the other one... i think thats the problem with batteries if we stop using it for a long time... hope ull be able to resolve it
Sep 13, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Aug 16, 2009 | Polaroid T831 Digital Camera
I have the EASYSHARE M1033 Digital Camera
Mine did this as well. I now have it plugged into my PC with the usb cord. I think the ac charger that came with the camera is not functioning. Try charging it from your PC.
Aug 01, 2009 | Kodak EasyShare M1033 Digital Camera
Charger blinks red and does not charge
This maybe a solution. I had the same issue just now. Pulled battery, put back in, placed on dock, and still blinking red. So I removed the camera from the dock, pulled battery, put same old battery back in, placed on the dock and turned the mode switch on right away before it started blinkin red. It seems to be charging now with one bar and has not gone blinking red for 15 minutes.
I was outside with the camera in 10 degree weather taking pics of my dogs but had been inside for 20 minutes before placing it on the doc. I think something may have happened with the charging circuit and turning it on right away with it on the doc may have reset the charging. Try it. Hope it works for you.
Oct 23, 2008 | Kodak EasyShare DX6490 Digital Camera
Nikon Coolpix L3 thinks batteries are dead
I think this was a firmware fault on some cameras. Check with Nikon to see if there is a new firmware for your particular camera. This can be downloaded free of charge and uploaded to the camera via USB.
Jan 04, 2008 | Nikon COOLPIX L3 Digital Camera
Kodak V603 Digital CAmera
Consult the manual for fault finding A more comprehensive manual may be on ther software disk as a PDF file Consult also the Technical Support Team at Kodak
Jun 27, 2007 | Kodak EasyShare V603 Digital Camera
Polaroid i830 Digital Camera Logo
22 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
