Question about Moen & Replacement Cartridge
How do i replace a moen faucet cartridge I have model # 87480 & need to replace the cartridge part # 1224
  • 127 Answers
If it is a 2 handle faucet, (thinking that because of the cartridge number) then you take the handle off. There will either be a nut that you can use a crescent wrench on or it could be the type that has a recessed nut....if that is the case there is an inexpensive tool you will need to reach down inside to undo the nut that is holding the cartridge in. Once the nut is off...you grab the top of the cartridge with a pair of channel locks and pull it out....reverse the steps for install.
Posted on Oct 25, 2009
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How do i fix my leaky moen bathroom faucet?
    Moen faucets are easy to repair. The cartridge you're looking for is most likely the #1224 cartridge, sold in pairs, and available at almost any home improvement store.
    Shut the water off, unscrew the handle, remove the nut that holds the old, cartridge in, swap it out, and put the handle back. The whole job should take you about ten minutes.
    Good Luck!
    May 21, 2014 | Plumbing
    I need replacement part for bath sink cartridge 4570
    The Moen 1225 or 1200 cartridges are the same except the 1200 is brass in stead of plastic. They will fit most Moen single handle faucets. If it is a two-handle faucet, the 1224 cartridge will fit most two-handle models unless it is a fancy widespread faucet more than about 15 years old. I don't know the model numbers for those cartridges. All of these cartridges require a removal tool if you can't get them out with a pair of pliers.
    Dec 09, 2011 | Moen Soap & Lotion Dispenser 3910S
    I have a single -handle Moen Torrance 87480 kitchen faucet that needs the cartridge replaced. (I had Moen ship it to me.) My problem is, I can't remove the single handle using my 3/32 allen wrench. When...
    Should be coming out if head not stripped or threads inside at set screw aren't stripped. Can you tell at all with perhaps flashlight if set screw is turning at all? Look like it backing out?
    Jan 30, 2011 | Moen & Replacement Cartridge
    Replaced moen teo handle cartridge 1224 now faucet
    the lines the cartage attaches to will have seals or teflon tap. if the seal has a small nick, it will leak. Or if the tape was applied in the incorrect dircection or was cut it could also creat a leak
    Jul 19, 2010 | Moen & Replacement Cartridge
    How do I get to the valve cartridge to replace it?
    how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
    Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Faucet is leaking. Can you tell me if this is a
    yes it is a cartridge replacement,the cartridge is,should be all that you need to replace.you did not list what kind of faucet. so here is a few number's. some bath/shower valves' take#1225-(plastic) this is also use'd in some kitchen,lav, model's.two handle faucet's#1224,the "posi-temp"#1222 is a tub shower only,there are cartridge puller's available,and recomened them,one is made by moen,another by brass craft,i have pulled cartridge's with out,so it is up to you.hope this help's.
    Nov 03, 2009 | Moen & Replacement Cartridge
    Replacing Moen O kitchen faucet O ring
    if it is dripping from the spout then there is a cartridge that needs replaced...1225 for the single handle type and 1224 for the 2 handle type. Moen does not use O-rings in their valves. If it leaking around the base of the spout there is an oring kit that you will need and you will have to pull the spout off to access them. Most Moen faucets use a 117 kit for the spout but there are some different ones.
    Oct 19, 2009 | Moen & Replacement Cartridge
    0n a Moen TL2383--what do i do to get hot water thru only cold comes out
    The tl2383 is just a trim kit...if you have a 2 handle shower valve and it is moen then the number is 2919....you just need a new cartridge if you are not getting any hot water....it is a 1224 cartridge.
    Oct 09, 2009 | Moen 2919 Chateau Two Handle Tub and...
    Moen & Replacement Cartridge  Logo
    1,209 people viewed this question
    Top Moen Home Experts
    Mike
    john h
    Andrew Bugbee
    Are you a Moen Home Expert? Answer questions, earn points and help others
