Question about Garden
WeedEater FL 1500 I have replaced the fuel line to the filter in the fuel tank. There is a small green wedge sheped fitting in the gas tank. What does it do and where does it belong?
  • r_wasreing Oct 07, 2009
    The little green wedge shape part fits in the gas cap with the wedge part facing down into the tank. The top of the wedge is an asterisk shaped piece that will fit into the gas cap.
2 Suggested Answers
jonvtec
  • 7 Answers
SOURCE: replace fuel lines WeedEater FL 1500 Blower
On the FL1500:
  • The Smaller line goes on the Lower inlet tube on the carborater the other end goes to the gas filter inside the gas tank.
  • The Larger line goes on the upper outlet tube on the carborater the other end goes to a fitting that holds this tube from coming out on the gas tank .This tube is only for Air, it helps fill the primer bulb when pushed.
I hope this helps.
Mechs correct me if I have made a mistake.
Thaxs Jon
Posted on Jul 11, 2010
How do the fuel lines in a weedeater trimmer pe550 hook up inside the gas tank
I have an older model that has a weighted filter in the tank. The filter flops around and can 'fall' into the fuel no matter which way you tilt the trimmer/tank. You should have one in your tank. Feed in the new line and make the end come out the gas cap. Push the filter/weight into the end of the fuel line. Pull the extra fuel line out of the tank to match the original position. You should have cut the new line to approximately the proper or same length as the old fuel line with an angle cut so you could push it into the tank.
Jul 23, 2014 | Poulan Craftsman/poulan/weedeater Fuel...
WeedEater FL 1500
if the choke needs to stay on to run it then there is a plugged jet in the carb
Aug 11, 2012 | Weedeater Garden
Need to know how fuel line end in fuel tank on a weed eater. have two lines. on large one small witch line dose the filter fit on and were does the onther line stop inside the tank
Your Craftsman trimmer is made my Poulan/Weedeater and uses 2 different sized lines. The smaller diameter line is the fule supply line and runs from the pickup filter in the tank to the supply side of the carb. The supply side is usually the lower of the fuel nipples on the carb. Make sure to put enough line in the tank so the filter can drop to the lowest point of the tank while you are trimming. The larger diameter line is the return line, and will connect to the nipple on the carb that is closest to the primer bulb. From the factory, the return line went into the tank and had a small clear plasted connector on the end to prevent it from slipping back out of the tank. This fitting does not connect to anything in the tank, it is merely a return line. If the return line fitting is missing, just make sure to leave a couple of inches of line in the tank. If the filter is missing, you MUST replace it...it will save you from having to clean the carb out every 10 minutes of run time.
Aug 29, 2010 | Craftsman 25cc Gas Line Trimmer
I have a weedeater xt 200 trimmer. The parts in
The tube in the tank is the fuel pickup line and goes directly to the carburetor. You will need to get NEW fuel lines. Fish or shake the old parts out of the fuel tank after draining. Inside the tank will be a small length of smaller diameter fuel line that connects to the small fuel filter and there will be a small nylon line connector that is plugged into the end of the larger diameter fuel line which is the fuel return line from the primer bulb back to the fuel tank. That line ends just inside the fuel tank and is held there by the small nylon line connector. The other line (smaller diameter) needs some length inside the tank so it can flop around as you move the machine enabling it to always pick up fuel. 6" or so is about right from the hole in the bottom (or top) of the tank to the fuel filter. Buy long enough lengths of fuel line that they can be inserted into the tank and pulled thru the fill cap area and then have the parts put back on them and then cut to the correct length from the fuel tank to the carburetor and/or primer bulb. Buy about 1 foot of each size line needed. Small engine repair shops have it and sell it..not expensive.
Jul 18, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Idles but dies when accelerated
Sounds like fuel flow restriction. Since you've replaced the fuel lines already try this....Remove and clean the carbureter needle valves and seats...Blow/**** out the inlet hose fittings ( should be 2 small brass fittings on the side of the carburetor) If you haven't replaced the lines completely (from inside the tank to carburetor) do that now.
Feb 12, 2010 | Garden
How to replace gas lines on a Weedeater Excaliber Hedge Trimmer
My Bolens Weedeater runs for 3 or 4 seconds and stop but it will run only if I drop some gas in the caburator then stop. Can you help me with this problem?
Norris.
Sep 25, 2009 | Garden
I have a Weedeater FL1500 Blower. The fuel line has rotted. Inside the tank there was a filter, a small white fitting with two ends and a small rubber green wedge piece. I am not sure how to attatch the...
Find a shop that can do a compression test on the engine. If the compression is not at least 100 psi, the engine will not run. So replacing the fuel lines and filter will be money out the window. It may be time to buy a new one. Spend two to three times what you spent on this unit and you may have something a little better. I like Echo products myself but you have to buy them from a dealer to get a good unit.
Sep 24, 2009 | Poulan Garden
Replace fuel lines WeedEater FL 1500 Blower
On the FL1500:
I hope this helps.
Thaxs Jon
Sep 09, 2009 | Garden
Replaced Poulan 25cc weedeater fuel lines/Now no start
You have/had a fuel filter in the tank.The connector goes to that filter, I think. The length does mean something but I don't know any way to figure it without a manual. You could try to figure from the total length. The fuel filter hold the line toward the bottom. Good luck.
Jul 11, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Garden Logo
526 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
