Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
I accidentally kicked the power plug out of my 360 and now the wireless adapter only stays red and won't connect! is it dead? tried restarting the router and modem but, no luck.
  • 416 Answers
Its microsoft!!!!!!!!!! bugs galore!!!!!!!! unplug the wireless adapter while the xbox is off.........turn the xbox back on and let it load with the ethernet plugged in...turn the system off using the control after you have established a connection the the network......unplug the ethernet and reinstall the wireless....turn it back on and let it load.....it still might not work in which case you will have to power cycle one more time.........and oh yeah, check in your setting to make sure wireless adapters are activated...
GOOD LUCK!!!!
Posted on Oct 07, 2009
Wont stop flashing green and I can not connect to xbox live yet I used to be able to Any Help Thanks, Paul
IF The LIGHT IS FLASHING GREEN then there is something wrong with your wireless network
Check your network settings and Retry connecting
Check the adapter's status light loadTOCNode(2, 'moreinformation'); The adapter's status light can tell you a lot about the state that the adapter is in. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is not recognized. Try plugging the adapter into a USB port on the front of the Xbox 360 console.
  • Flashing green: The adapter is attempting to connect to a wireless network.
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) .
  • No light: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console
Jan 10, 2011 | Microsoft Wireless Network Adapter Xbox...
I have an ac adapter for the new xox 360 250 gb , that has the red light lighted up that means false alarm what should i do to get it back to green its been 1 week?
Check the status light on your adapter The state of the adapter's status light indicator can tell you the status of the Xbox 360 Wireless G Networking Adapter. Here's what the different lights mean:
  • Steady red light: The adapter is ready to be configured. For information on how to do this, please see: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support.
  • Not illuminated: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. Select Configure Network.
  4. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article:
    977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  5. Select Scan for Networks.
  6. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article:
      909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  7. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  8. Press B on your controller, and then select Test Xbox LIVE Connection.
    If you successfully connect to Xbox LIVE, you'll see this screen:
    If you receive an error message, please go to www.xbox.com/networkhelp (http://www.xbox.com/networkhelp) for further help.
Dec 03, 2010 | Microsoft Wireless Network Adapter Xbox...
The wireless adapter on my xbox 360 will not turn on. when the device is plugged into the console the status light will flick red for a second and then turn off instead of staying on like it should under...
this happens to me with my adapter but I happen to get it to work by leaving it plugged in and leaving the xbox on.or i restart the xbox over and over. Mine seemes to have like a charge time so keep restarting and plugging the adapter in other ports.. It should after a while turn on. if not try another adapter because it may not be the adapter that's causing the problem. Your console may have bad ports.
Dec 28, 2009 | Microsoft Wireless Network Adapter Xbox...
My wireless adapter for my xbox 360 stays on red light
You can try fixing this using Xbox360 repair guide that covers almost all xbox 360 problems, you can get a copy from here
http://xbox360repairguide.com
Jul 10, 2009 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 Does not recongize my wireless adapter
My adapter light is a solid red. When I plug in an ethernet cord, that'll connect.. but when I take the ethernet cable out, the 360 always reports Disconnected under Network Adapter even though the wireless adapter is plugged in.
Apr 03, 2009 | Microsoft Wireless Network Adapter Xbox...
Red light flashes as i plug in the adapter
solid red light means ready to connect. If you hve a flashing red light that means you have a hardware ploblem. Try using adiffent USB. go to xbox 360 suport for more imfo.
Jan 29, 2009 | Microsoft Wireless Network Adapter Xbox...
My light stays red never turns green
This means that it hasnt connected to a wireless router. Make sure your router is wireless, that you have searched for you network and found it. If this still doesnt work then make sure that your routers wireless capabilities are working and try entering the settings in manually to the xbox 360 network settings.
Jan 17, 2009 | Microsoft Wireless Network Adapter Xbox...
XBOX 360Adaptor
the adapter should have the right settings as that of the network it is trying to connect to. you may want to contact your wireless router (or wireless AP) manufacturer to get the settings then have the adapter connect to those settings.
Nov 04, 2008 | Microsoft Wireless Network Adapter Xbox...
Wireless adapter
What exactly are you refering to Here ( adapter ) The Power Brick, A wireless or wired Controller ?
There are 2 USB Ports on an XBOX 360 same place Front R/H/S Slot Side By Side.
Mike @ Compurepair.
If it,s Orange ( whatever it is youre refering To ) then it,s in standby Mode. Red ( error/Fault ) Green working OK.
Hope this helps.
Feb 24, 2008 | Microsoft Xbox 360 Console
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
218 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
