Question about HP M490N PC Desktop
Computer turns on leaves message and cuts off
I have a HP M490N computer. When turning on computer I can hear the fan turning on and running hard. A message appears apologizing but says that the computer cannot connect to windows; that an electrical change may have caused the problem, but there was no electrical problems to my knowledge. Screen also has on it the safe mode option but indicates that the machine is shutting down to protect the files and the computer. Once the machine cuts off, if you try to hit the on/off switch again, the green indicator light comes on, the amber light flickers on and goes immediately off and the machine turns off. If you let the computer rest for five or ten minutes it will repeat the initial message that I mentioned above in the third sentence of the post ("A message appears . . .).
  • 81 Answers
When u get into the safe mode try and run a system restore to a date earlier than 2 weeks> if that doesnt solve the problem> disconnect all the external devices from the computer> other than the keyboard, mouse and the monitor> then whole restarting tap the F1 key to enter BIOS screen> hit F5 then enter> then F10 > enter> the computer restarts
Posted on Oct 07, 2009
  • 74 Answers
This means that your cpu fan is facing some problems so its better change it or else your pc will encountered on and off. you can use it for 2-5 minutes then turned off automatically and you will notice the the lights is still on.
When i turn on my hp all in one computer,it's telling me cpu fan can not be detected
Hello user...you are receiving this message at start-up because, in your bios system settings, "run fast diagnostic test" is enable...CPU fan is like a computer fan but attached with the cpu to cooled the cpu so that the cpu will function properly so as the computer...perhaps there is a problem with the fan, so its not running when the computer starts. This may harm your CPU, as a result may blow the circuits in the motherboard and eventually your computer will crash....for a technical advice, you may want to visit the nearest PC repair shop and change the cpu fan..
Jun 23, 2014 | HP Mini 1000 Netbook
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Nov 02, 2012 | HP Pavilion a1720n PC Desktop
My computer is not working....i am stuck in windows system32 drivers disk.sys when i try the safe mode...and the installation stops and just turn into black... can anyone help me ragarding this problem?...
If computer does not start normally, use this checklist to identify specific symptoms and take the recommended corrective actions to resolve the problems.Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge
  1. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.
Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook.
  • Check AC adapter wiring and power connection to the notebook.
  • Connect a different AC power adapter and remove battery, then restart notebook.
  • Connect a different battery and disconnect AC power adapter, then restart notebook.
  • If there is no power available at the notebook, contact HP to purchase a replacement battery or AC adapter.
Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing.
  • Count number of blinking LEDs or beeping tones to help with diagnostics testing.
  • Contact HP for technical assistance. There are no other user-initiated troubleshooting actions until error codes are resolved.
Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure.
  • Connect an external monitor to check if the problem is the built-in LCD display or graphics card.
  • Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset .
  • If memory or hard drive components were replaced, reinstall original components.
  • Remove memory modules and replace one-at-a-time.
  • Remove and reseat hard drive.
  • If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test .
  • On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics .
  • If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition.
    Note: All programs and data are destroyed during recovery.
Symptom 4: Computer may display an error message on a black screen during startup or boot
  • Search www.microsoft.com for terms in error message.
  • Search www.hp.com for terms in error message.
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
  • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
    • Select Disable automatic restart on system failure to view error message.
    • Run Repair Your Computer .
    • Run Last Known Good Configuration .
    • Select Boot into Safe Mode and then select Run a Microsoft system restore .
    • Select Boot into Safe Mode and then select Uninstall recently installed programs .
    • Select Boot into Safe Mode and then run Windows Update .
Symptom 6: Computer displays the Windows logo screen and stops respondingIf no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
  • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
  • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
Oct 11, 2011 | Computers & Internet
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    Oct 09, 2011 | HP Mini 1000 Netbook
    Voltage not going to cpu
    Not sure just what you mean. If your computer is plugged into the wall and the power is turned on, the power supply should be on and the cooling fan turning. Also, the CPU fan should be turning and the hard drive should spin up.
    Note that the power supply is the main component that must be supplying the power. If you don't hear or see the fan turning in the power supply and the little power light on the front of the computer does not light, replace the power supply.
    If your power supply is running and nothing else is running, I would unhook all devices and leave just the CPU and video and memory in. If you get nothing, then the motherboard is probably bad.
    Sep 22, 2011 | Computers & Internet
    Newer HP Pavilion dv6000 turned off while in use and wont turn on
    1.Start your computer and see if your hear your fan noise,and cannot see anything on screen then there is problem with your power supply.
    2.If you cannot hear your fan noise,and do not see anything on screen,then there is problem with your motherboard
    3.if you hear fan noise and can see something on screen,then it is the issue with your hard disk (very less cases)
    Mostly it would be the 2nd case that you will have to get your motherboard replaced
    Jul 27, 2010 | HP Pavilion dv6000z Notebook
    Computer shuts down
    Please visit the below link to solve your problem.Due to some problems I was unable to send you the whole solution so please visit the site.
    http://www.ehow.com/how_113600_troubleshoot-computer-wont.html
    Thanks And sorry for the inconvenience.
    Please rate me for this solution if it works for you.
  • Step 2 If you're starting from a button on the keyboard, make sure the keyboard is connected to the computer.
  • Read more: How to Troubleshoot a Computer That Won't Start | eHow.com http://www.ehow.com/how_113600_troubleshoot-computer-wont.html#ixzz0szt64gb5
  • Step 4 If you can hear the computer's fan or hard-disk drive, or if you can see indicator lights on the main unit but the monitor stays dark, make sure that the monitor is connected to a working power source, that it's turned on and that it's securely connected to the computer via the video cable.
  • Step 5 If the monitor and computer have power but the computer displays a "Non-system disk or disk error" message, check to make sure you didn't leave a disk in the A: drive. If you did, eject it and restart the computer.
  • Read more: How to Troubleshoot a Computer That Won't Start | eHow.com http://www.ehow.com/how_113600_troubleshoot-computer-wont.html#ixzz0szsjH6o9
    Jul 06, 2010 | Dell Inspiron 530 Desktop Computer
    My computer wont boot up the fan and light turn on for a second then goes right off....
    With the little bit of information presented, it appears that this is possible a power supply problem. One thing you can try is to unplug the power adapter from the laptop, remove the battery, then plug the power adapter back into the laptop. Then try to turn it on. If everything comes up normally, then the problem points, potentially, to the battery.
    Hope this helps!
    Feb 18, 2010 | HP Pavilion dv9000z Notebook
    Yellow power light on HP SR1420NX
    For reasons yet to be determined, your computer is not talking to your monitor.
    This could be the monitor cable came loose from the tower (this is our favorite, because it is such an easy repair), or something on the motherboard (that is, anything) that is not functioning and preventing your computer from starting.
    Unplug the connecting cable, and plug it back in again, making sure that it is seated properly.
    Do you hear any sounds besides the fans? You should be able to hear the faint clicking of a hard drive starting up also. If you hear this, the problem is not in the computer, but in the communication to the monitor.
    Good luck
    tony
    May 23, 2009 | HP Compaq Presario SR1420nx...
    My computer is and hp and has been doing this off and on for awhile now.Some days it works great then,,, It freezes or if you can get it to come on and work at all. The other times you push the button to...
    First, open the case and blow the dust from the components in there with some canned air. There will be dust built up on the fan and possibly the memory modules. Then remove each memory module and put it back. If you have a video card, remove and reseat that too. Now try your computer again. If your computer is still malfunctioning you most likely have a power supply or hard disk problem. When your computer is running, go to my computer and right click your hard drive, then go to properties. Go to the hardware tab, click on your hard drive, then click on properties again. Do you see any error messages there?
    May 13, 2009 | HP Computers & Internet
    HP M490N PC Desktop Logo
    85 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
