Question about Canon PowerShot A75 Digital Camera
I'm getting a message that my memory card is "locked" ...? How do I unlock it? Canon PowerShot A540
    Brigadier General:
  • 11,967 Answers
Move the slide switch on the side of the card.
Posted on Oct 07, 2009
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
When I install a new SD card in my Canon PowerShot A540 it displays Memory Card Error Card Locked. I have moved the tab on the card and it displays the message regardless if the card setting. What
it seems to be the memory card slot is damaged normally 9 contacts connect with MC if any of it doesn't contact, will not work, open and takeout card slot if the contact is bend align it to touch the MC's contacts.
Sep 02, 2017 | Canon PowerShot A540 Digital Camera
I have a Canon PowerShot A540 Digital Camera I got a new memory card it is a sandisk SDHC 8 GB but I am getting a memory card error message.... What can I do?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Please note that your particular model camera can only use up to 2GB standard SD cards. These are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them. There are also other common causes if the above didn't help, with troubleshooting steps for this problemlisted here.
Oct 01, 2011 | Canon PowerShot A540 Digital Camera
Card locked error on screen card is unlocked and even new card gets same message
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (sorry, an A540 can only use 2GB or less standard SD cards. These are very inexpensive these days, and are available on Amazon if your local store no longer carries them). There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Aug 17, 2011 | Canon PowerShot A540 Digital Camera
My memory card is locked and i tried everything i have a canon a540 powershot and the memory card is a sandisk 8gb
Have you noticed the slider on the side of the card? This acts as a lock and might have been accidentally moved to the locked position, in which case you could just move it back to unlock again. Hope this helps.
Dec 27, 2010 | Canon PowerShot A540 Digital Camera
Canon powershot A540 I have tried to erase memory card but it says card locked. How do I unlock.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 17, 2010 | Canon PowerShot A540 Digital Camera
Memory Card Error Card locked. I get the same
If you've already tried the lock/unlock switch on the side of the card, then see this link for additional troubleshooting tips for this problem.
May 16, 2010 | Canon PowerShot A540 Digital Camera
Memory card locked
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Feb 07, 2010 | Canon PowerShot A540 Digital Camera
Inserted new sandisk ultraII 2gb into camera. error message, disk locked. unlocked, still error message
Hi!
Does it work with other cards? There's a small switch on the memory card reader inside the camera which tells the camera that the card is locked. Most likely this switch is broken. You can try to point it with needle or something but I'm afraid you will have to give it away for a repair to a local repair shop or Canon service center.
Tom
Sep 27, 2009 | Canon PowerShot A540 Digital Camera
There's a little switch on the side of the SD card. Remove it from the camera and find the switch. Normally, there's some very small printing next to it saying something like (Lock / Unlock).
Mar 27, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot A75 Digital Camera Logo
46 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
