Question about Cobra 29 LTD CB Radio
Mike will not key in - Cobra 29 LTD CB Radio
  • 454 Answers
Take to a CB shop. It is possibly just a bad mike cord.
Posted on Oct 07, 2009
  • mwarej123 Oct 07, 2009
    Another quick check is just plug in a mike from another Cobra CB that you know works. If still doesn't work with a good mike, problem is in the CB.
Why does the channel change when I key the mike?
wrong mike is plugged to radio , many radios have the option to change the channels via two buttons on mike , unfortunately the mike connectors are pretty standard so they all hook right in easy , but that doesn't mean it's making the right connections inside , a good radio shop (there are still a few around if you look 4 them) will be able to rewire your mike to work on that radio if that's what u want to run
Dec 01, 2015 | Radio Communications
Its a cobra 25ltd when i key the mike sometimes it hangs keyed up and does it with defferent mikes so the mike is not my problem.
take some electrical spray cleaner and lightly spray the inside of the radio where the mic plugs in. could also be a keying diode.
Jan 04, 2013 | Cobra 25 LTD 40-channel Classic CB Radio...
Have a sequel when keyed up
If this is a powered mike the modulation is set to high. If you have a standard mike check your settings on the radio, if that does not help sub another mike.
Apr 03, 2012 | Cobra 29 LTD CB Radio
Hi my mag257 when i key the mike .the tx light up but no aduio sign on lcd .leave radio on for 5 minutes key mike again .all working .your roger
Hi sounds like bad caps in your radio.. also if your running a power mike, check the battery.
i suggest you post your problem on the radiomods forum, where there are loads of radio technicians browsing the forums.
http://www.radiomods.co.nz/forum
Sep 01, 2010 | Magnum 257 CB Radio
When i key the mike the red light comes on but no
What kind of radio is this? If its a uniden or cobra it still could be a broke wire in your mic.It could also be either a bad soilder or voltage regultor.
May 08, 2010 | Radio Communications
3300 240-Channels Base CB Radio: intermitant when key mike /works for a bit then st...
sounds like you have a bad soilder joint on the board. If it quits and you hit the case and it starts again is a sure way to find out.
May 07, 2010 | Connex 3300 240-Channels Base CB Radio
Cobra 29 nw when you key the radio the swr meter doesnt move and if you move the swicth to cal you can adjust it with out keying the mike but has good recive any help would be good thanks dwayne
To check the SWR, you put the swicth on CAL and key the mike with mike gain turned down all the way,then calabrate it to the meter on the CAL scale,then swicth it to SWR before you unkey the mike, then what ever the needle falls back to, that is your SWR reading.
Apr 26, 2010 | Radio Communications
I just installed a cobra 29 in a customers truck. Radio gets power but cannot get any feedback
Make sure you have the radio on cb not pa, turn the squelch to the left, turn RF gain to max. check the mike and antenna, key the mike, does it key up?....hope this helps....
Mar 11, 2010 | Cobra 29 LTD CB Radio
Radio stays keyed up with no mike .what would cause this.its a galaxy saturn
some radios will stay keyed on without a mike. plug one in and see if it unkeys
Jan 08, 2010 | Radio Communications
Uniden 520xl makes humming noise when mike is keyed
if you have a power mic , you might have it turned up to high. next make sure you have a good ground on your antenna. if that is ok and you still have the same problem have the swr checked. this should fix the fm radio noise.
Apr 10, 2009 | Uniden PRO510XL 40-Channels Base CB Radio
Cobra 29 LTD CB Radio Logo
47 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
