Question about Mitsubishi WS-73513 73" Rear Projection HDTV
I have a WS-73513. The green LED on the front
I have a WS-73513. The green LED on the front panel is blinking constantly. No picture or sound. I tried the reset button and unplugging. Still won't stop blinking. Now what?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
ONLY 1 or 2 things can cause this problem----First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---Notice the one or two pairs of wires coming from the front keyboardI have a WS-73513.  The green LED on the front - 2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard2.gif with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---these sets have a Receiver(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up.
If disconnecting the keyboard2.gif allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---you can call them and get a quote for repairing the receiver.
SD TECH
Posted on Oct 07, 2009
Mitsubishi hdtv 1080 what are the blinking green light codes
ost models have a self-diagnosis feature to help determine shutdown problems.
To enable this feature do the following....
1) Turn the tv on and then let it shutdown
2) Press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds
3) After 5 seconds the power LED on the front panel will blink a two digit sequence.
This will commonly be one set of blinks followed by a short pause then another set of blinks.
This will repeat around five times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short detected - commonly caused by convergence failure - to repair this check out site for a convergence kit)
2 - 3 = Deflection protect
2 - 4 = Vertical protect
Note: A constant blink on certain models will typically be caused by a fault in the DM model. To repair this check out site a "blinking green light kit"
Aug 05, 2014 | Mitsubishi WS-55513 55" Rear Projection...
Front panel light just blinks
Hi Sharon,
Blinking of the LED at the front panel has an equivalent error code to give an idea what's going wrong to the set. Please check if there's a pattern of blinks, number of blinks separated with a pause or if the led blinks green continuously.
Jdvillanueva
Jan 05, 2012 | Mitsubishi WS-65819 TV
WS-73513 Power light continually blinks and will not come on. Tried reset as in past but no success. Is if finally dead.
hold down 1st and third buttons from the right on the front of the tv for 5 seconds. The green led will blink then pause then blink again. Count the blinks . It will give a 2 digit error code . Let me know what code is.
Aug 31, 2011 | Mitsubishi Televison & Video
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
Mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
May 31, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
check the pico fuses on the reverse side of the DM , Just check them in circuit for continuity. let me know how you make out, and if you need any more advice lert me know
Mar 18, 2008 | Mitsubishi WS-48513 48" Rear Projection...
I have a Mitsubishi WS-73513 With the green light flashing
Once Ac power was momentarily interrupted,allowance was made for a very common problem to appear. You will to hire a
skilled,qualified Mits. tech who knows how to remove,repair &
replace the DM module.The fix requires r&r of four 1000mf 25v
capacitors,Use high-temp 105 degree only. To see pix's =
www.Chris@ChrisAndNat.com ...........................T.
Nov 23, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi WS-73513 73" Rear Projection HDTV Logo
189 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
