On an old didier 5HP why would the reservoir cap blow off on the return stroke? We just replaced the valve and it continues to blow off randomly during use.
I cannot get the water hot enough and maitain the water pressure. The groved thing in center (after...
(More)
I cannot get the water hot enough and maitain the water pressure. The groved thing in center (after removing all hardware and sace plate) is missing the red/blue clips. I am a complete novice and don't even know the names of parts ie like euschueon or whatever. I am desperate..I am tired of no pressure or not hot enough. How do I adjust the groved thing and with what and which way do you turn it...left or right and how much? I have tried adjusting the left and right screw...when I set them both there is no water flow..just trickle...so I slowly adjust each with the shower on and cannot get the correct balance of pressure and hot enough...my water heater is at max and the water in kitchen and sinks is very very hot...so do I adjust the groved thing in the ceter which just happens to be missing any colored clips..and what do I use? HELP
toilet flushing fills up to level but emptying on its own but water level still at correct level ....
(More)
toilet flushing fills up to level but emptying on its own but water level still at correct level . its a barcelona suite from b and q
our cisten lid on our kohler toilet wont come off we are not sure how to get it off it doesnt pull...
(More)
our cisten lid on our kohler toilet wont come off we are not sure how to get it off it doesnt pull off like other toilets
Have a toto toilet...not sure which model. Pump says Gmax on it. The tank fills after flushing but...
(More)
Have a toto toilet...not sure which model. Pump says Gmax on it. The tank fills after flushing but the pump continues to flow water through hose into small opening and does not stop How do I fix
I purchased a Danco anti-siphon ballcock 495 water saver for my toilet which keeps running. The...
(More)
I purchased a Danco anti-siphon ballcock 495 water saver for my toilet which keeps running. The picture for the directions is different from what the ball **** is. I have the small white plastic ballcock with the small spring and a red cap on it. The directions shows a picture of a long tube with a float on top of it. I can't follow the directions. What are the directions to replace the ballcock I purchased?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
