Question about Discovery Channel Audio Players & Recorders
I have a Multi Color Digital Display AM&FM Alarm Clock. The Clock gains about a minute a day. I can live with it, but it is annoying. It is my all time favorite Digital Clock.
techman
  • 3130 Answers
SOURCE: RCA alarm clock - RP3721 - crystal or AC for time?
They used to use crystals to help the timer ics to keep time but since the development of Micropros. all this is built in to one chip. Now they will use a resonator or a small crystal for the timing clock of the micro but nowdays the manufacture uses that clock to keep all in check. If your gaining time you probably are having problems with your ac duty cycle as this also keeps clocks in check.. This would not affect most devices but could be a problem. But of course a defective Micro could also cause this gain in time And probably is?? Now a battery backup is nothing more then a battery in line with the Microproccesors B+ terminal through of course a diode as well as a voltage limiter resistor to take over the B+ when the units ac supply is absent..
Posted on Mar 24, 2006
Bogdan
  • 198 Answers
SOURCE: My digital alarm clock is fast
I'm not on this field of expertise but I could try giving you some tips. These cloks work by dividing the natural oscilations of a quartz cristal in the corresponding way to form "1 second". A quartz cristal like the one in your clock will oscilate at about 14080236 times per second. Your clock uses a specialised chip in order to count these oscilations and know they form "1 second". However, the problem is the following. These clocks doesn't compensate for frequency variation over the mains power line. You should always look firts at it's power ratings and determine if it requires 50Hz or 60Hz. Even if you use an adaptor to raise/lower the tension from 110 to 220 v or viceversa, this woun't correct the problem as the adaptor will leave the frequency unchanged. Unfortunately in order to make the required adjustments you woun't need a resistor or capacitor, but a whole bunch of them in order to make a frequency divider-convertor that's stable enough to give your clock a fixed time reference. One more thing, not all components have exactly the parameters noted on them. There's another thing called Tolerance. A 1Kilo Ohm resistor with 10% tolerance (most comon tolerance) can have any value with +/- 10% of it's noted parameters, and in this example, could have any value between 900 ohm - 1100 ohm. These clocks will need components with a very strict tolerance in order to have an acurate time reference. Note that they aren't atomic clocks, they simply use a larger chip that includes most of the clock, time reference, frequency analyser and divider. An atomic clock doesn't use quartz cristals, instead it relies on the natural oscilations of the very precise Cesium izotope atom. The rest of the atomic clock is made up in a similar way as usual clocks (more fixed and small tolerance of course :) ).
Posted on Jul 02, 2007
SOURCE: sony dual alarm am/fm alarm clock radio
HOW does one set the time and alarm on a "sony dream machine clock radio"?
Posted on Mar 08, 2009
SOURCE: face of clock looks faded. an 'E' before the time, radio wont
The E means you have tried to put an MP3 CD into it and it didn't work.  There is a button atop the clock radio that allows you to fade the backlight.
Posted on Mar 26, 2009
SOURCE: FM/AM GE Digital clock radio model#7-4966 display bulb burned out
Geri, I recently had the same problem with my GE model 7-4966 clock radio. The radio manual states that there is a spare bulb included and stored on the underside of the battery compartment door on the bottom of the clock radio. To replace the bulb: 1. Twist the bulb bar handle on the underside of the radio to unlock and remove the holder. 2. Carefully pull the bulb out of the holder and replace with the spare bulb. 3. Place the holder back in place, twist the bar handle to the right to "lock" the bulb holder in position.
In case you can't find a spare bulb, the manual states "use only a GE259 or equivalent 6.3 volt, wedge base bulb. A clerk at Radio Shack told me she could get a replacement bulb.
Dennis60
Posted on Jul 27, 2009
I can't find how to change the time for the alarm system for a Alphaline 150i digital radio alarm clock
PDF]Instruction Booklet - Sound Therapy and Relaxation Clock ...
www.conair.com/instruction.../07ps111_su7_ib.pdf
Conair CorporationThe LCD display will show the current time of ALARM 1, reset time. ... The Conair Sound Therapy & Relaxation Clock Radio System can be used with a cord ... 1) 10 high quality digital recordings .... 150 Milford Road, East Windsor, NJ 08520.
Muse - Alarm clock radio
www.muse-europe.com/en/products/alarm-clock-radio
Catalogue Products, Cat?gorie Alarm clock radio. ... M-125 CRB. Clock radio CD player with MP3 ... M-150 CR. Clock radio ... Automatic time-set clock radio PLL ...
[PDF]FM/AM Clock Radio - Sony
Jan 10, 2016 | Watches
How do set the wake up alarm on am/fm digital clock radio model ONB14AV201
1. With the unit in CLOCK mode, press and hold the ALM1/VOL+ or ALM2/VOL? button. The ALARM time will begin to flash on the LED display.
2. Press the ?/HR button to adjust the alarm hour.
3. Press the ?/MIN button to adjust the alarm minute.
4. When the correct time is selected, press the ALM1/VOL+ or ALM2/VOL? button to confirm.
5. Press the ALM1/VOL+ or ALM2/VOL? button to select the ALARM sound mode - buzzer or currently set radio station. The alarm buzzer or radio indicator will light up.
Jan 21, 2015 | Audio Players & Recorders
How do you use it
--- SCANNED INSTRUCTIONS ---
CLOCK AND DATE SETTING: 1. Press and hold MODE button for three seconds. The minutes display will begin flashing. Press MODE button to switch among minutes, hour, 12/24 hour, month and day. 2. Press ADJ button to set value of the minutes, hour, 12/24 hour, month and day. NOTE: Original screen will return after one minute of inactivity. To view the date, press ADJ button.
ALARM CLOCK SETTING: 1. Short press MODE button to switch from clock to alarm clock. 2. Press the ADJ button once to make the D))))) symbol appear, which will indicate that the alarm is on. Press ADJ button again and a bell symbol will appear, indicating hour notification signal is on. The hour notification signal
sounds once at the top of every hour. Press ADJ button again to activate alarm clock and hour notification signal, press ADJ button again to clear all.
MEMORY FUNCTION: 1. Press the MEMORY button for maximum temperature and humidity to display. Press MEMORY button again for minimum temperature and humidity to display. Press MEMORY button again to return to current temperature and humidity. 2. Press and hold MEMORY button for three seconds to clear maximum temperature, minimum temperature and relative humidity.
COMFORT DISPLAY: When temperature remains between 68F to 82F (20C to 28C) and the relative humidity remains between 50% and 70% "COMFORT" will be displayed. When relative humidity is above 70% "WET" will be displayed. When relative humidity is below 50% "DRY" will be displayed.
FAHRENHEIT/CELSIUS: To switch between Fahrenheit and Celsius, press FAHRENHEIT/CELSIUS SELECTOR button on back of unit.
INSTALLATION: 1. Use provided suction cups to position the sensor probes in the terrarium. 2. Position THERMOMETER & HYGROMETER in desired location outside of terrarium with a built-in stand.
BATTERY TYPE: 1 PC Button cell (AG13/LR44)
WARNING: Install THERMOMETER & HYGROMETER and sensor probe out of reach of pets and away from water.
For more information about All Living Things products, please call 1-800-806-7870.
Dec 24, 2013 | ALL LIVING THINGS Digital Thermometer &...
Lost manual for springfield color changing alarm clock model # 962032612V0706
I have one & I just set it. You hold down the s button until the time flashes then use the arrow buttons to set hour then push the s again to set minutes & when they flash you push the arrow button again then repeat with the alarm & date.
Tina:)
Jan 16, 2013 | Bon-Ton Springfield Color-Changing Desktop...
How to set time on jvc kd-r210
Setting the clock
  • Press and hold SEL (select) for more than 2 seconds. "DEMO", "CLOCK H", "CLOCK M", "DIMMER", or "AMP GAIN" appears on the display.
  • Set the hour.
  • 1. Select "CLOCK H" (hour) if not shown on the display.
  • Set the minute.
  • 1. Select "CLOCK M" (minute).
  • 2. Adjust the minute. Using the Control Knob
  • Finish the setting. To check the current clock time or change the display mode.
  • Press DISP (display) repeatedly. Each time you press the button, the display changes as follows:
  • • During tuner operation:
  • • During CD operation:
  • • During power off:
  • The power turns on and the clock time is shown for 5 seconds, then the power turns off.
Nov 11, 2010 | JVC AM FM CD DET FACE CAR STEREO
I need to know how to set the clock pioneer deh-p6500 thank you
Here is the link to you manual:
http://www.pioneerelectronics.com/pio/pe/vgn/images/portal/cit_11221/50163operation_manual_DEH-P6500_2003117151397330.pdf
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select Clock.
Clock appears in the display.
2 Push MULTI-CONTROL left or right to
select the segment of the clock display you
wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the clock display:
Hour—Minute
As you select segments of the clock display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
set the clock.
Pushing MULTI-CONTROL up will increase
the selected hour or minute. Pushing
MULTI-CONTROL down will decrease the selected
hour or minute.
Notes
! You can match the clock to a time signal by
pressing MULTI-CONTROL.
— If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes
10:00.)
— If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
! Even when the sources are off, the clock display
appears on the display. Pressing CLOCK
when the sources and feature demo are off,
turns the clock display on or off.
Turning the clock display
on or off
You can turn the clock display on or off.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Note
appears on the display. Pressing CLOCK when
Cheers!
Dec 04, 2009 | Pioneer DEH-P6500 CD Player
Instruction manual for a Tevion clock radio
how to set the alarm on Tevion fm/am digital alarm clock
Oct 23, 2009 | Audio Players & Recorders
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
46 people viewed this question
Top Discovery Channel Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Discovery Channel Audio Player and Recorder Expert? Answer questions, earn points and help others
