Question about Bissell 1698-1 PowerSteamer ProHeat Plus Upright Vacuum
Nothing spraying out of Bissell Powersteamer Proheat. I've check filter under flow indicator, pump belt is fine, cleaner in proper tank, bladder of water tank is full. We've had it for a very long time but it's barely been used. Can anyone help?
  • 17 Answers
Here is how to fix it
Posted on Feb 08, 2010
I had two problems. No water was coming out of the main unit (it was working fine via the powerbrush) and the flow indicator wasn't spinning. Because I'm out of warranty, I did two things (after trying all the options that were posted).
1. Removed the top of the main unit. There are 4 screws on the top back lid. Once you remove those, lift the back up towards the front. The front is snapped under the bottom casing. It should come up with a little pressure, but don't force it. With the top lid removed, I had to clean several of the rubber hosing by removing them and running under warm water. I actually used a long wooden skewer to scrape the grime in the tube. Make sure you do one tube at a time and replace in as it was before moving to the next one. While you are at it, make sure the 2 sprayers on the front are clean as well. They are either orange or yellow and rubber tubes also feed into the sprayers. After I finished, I replaced the lid. It it still wasn't working, so I tried step 2.
2. Remove the hose assembly from the main handle. 2 screws and 2 bolds (don't lose the nuts from the back). Once the hose assembly has been removed, then lift off the top part of the handle. Once the top is off you should be able to open the front lower part of the handle exposing the additional electrical and more rubber tubbing. In the middle is rectangular looking object. That is the water heater. If you just ran the vacuum, do NOT touch this as it will be hot. Wait for it to cool. check the connections of the rubber tubing and make sure they are clean. In my case the tube going in to the heater was all blocked up with cleaner solution. Once I cleaned that up an reassembled in reverse order, the unit worked fine.
Hope that helps you.
Posted on Jul 21, 2010
Water won't spray out of the cleaner
If it won't dispense water then that means that the pump belt needs to be replaced. Here is the belt you need:
Bissell Proheat Pump Belt
May 22, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Cant get it to spry solution on to carpet hose pluged if so how d
It is because the pump belt is worn or stretched. Here is the replacement you need:
May 19, 2010 | Bissell PowerSteamer Deep Cleaner Plum...
Not spraying or picking up water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
bmv,
Feb 02, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Steam cleaner not spraying soap
That means that the pump belt is worn or stretched and needs to be replaced. Here is a link to the belt you need and the manual which has instructions:
Bissell ProHeat Belt and Manual
Dec 12, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Can a bissell powersteamer work if the belt on the
heatman101
retr
Nov 17, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1698-1 PowerSteamer ProHeat Plus Upright Vacuum Logo
589 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
