Question about Dell 3100cn Laser Printer
I put in a new printer cartridge, but the printer is not recognizing it. It continues to say "Insert Printer Cartridge" 093-973
SOURCE: printer won't recognize cartridge
i had the same problem! I replaced two cartidges at once and one of the lights continued to stay red,The red light stayed on and therefore the printer would not print !!!!!! I decided to fool the printer-----I took the cartridge out and inserted into my chip resetter and then back into the printer--bingo worked like a charm.....I noticed the same type of problem when I changed ink cartidges befor when I was using different types of ink.
I think that the printer doesnot always know that there is still ink in the cartridge that has been removed and then reinserted into the printer again even if its a new one. Using the chip resetter reprograms the cartridge. Make sure the cartridges are not expired. The chip resetter cost about nine dallars--buy one on line. good luck-----Glenn
Posted on Dec 20, 2007
  • 13 Answers
SOURCE: Printer will not print with color cartridge in
go to dell AIO center
click maintain/troubleshoot on the top
under trouble aio problems - click ink levels
click maintenace tabs
and then clean print cartridges and align print cartridges. then try printing a test page.
if this does not work, remove the cartridges and install them again.
let me know how it goes
Posted on Dec 28, 2007
  • 36 Answers
SOURCE: Printer Not Registering New Cartridge
try installing the original cartridges u got with the printer & reseating the power cable assembly....make sure u hav removed the tape frm the cartridge....
Posted on Jul 12, 2008
SOURCE: dell 944 photo all in one printer
Set printer to print multiple copies. Put in less amount of paper. While printer is waiting for more paper, change cartridge.
Posted on Dec 04, 2008
jmassengill
  • 345 Answers
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Posted on Jan 08, 2009
MFC-J430W will not recognize any new magenta cartridge!
When installing the cartridges, it is important that you insert them from left to right with the black cartridge first and the magenta cartridge last. The reason for this is because the magenta cartridge has a clip on top of it that goes into the cartridge door sensor. The clip needs to push the sensor in so the printer is able to function with the cartridge door open. If you insert the magenta cartridge first, the printer will think the cartridge door is closed and you will get a error message for the other missing cartridges.
May 29, 2013 | Brother Office Equipment & Supplies
I have a lexmark x1240 and just installed a new cartridge. I keep getting an error message that says " print cartridge missing" install print cartridge even though both cartridges are in the printer.
If you insert the old cartridge, does it recognize it? If it does, then it's a problem with the new cartridge. Try to check if you already have taken out the protective tapes out of the cartridge.
If it still doesn't recognize the old cartridge, then it's a problem with the printer.
Nov 29, 2012 | Lexmark X1240 All-In-One InkJet Printer
The printer will not recognize a cartridge and keeps asking me to insert a new one. A new one is in!
Your new cartridge may not support your printer. Actually some duplicate cartridge have the problem. You can try to install cartridge properly. Hope your problem may fixed.
Apr 20, 2011 | HP Photosmart C6280 Printer
Unable to print from lexmark x2690. printer is giving the error E C 1 on display.
EC1 error message indicates that your printer having trouble recognizing one of your cartridges. You could try to re-seat the cartridges in the printer. Remove and reinsert both cartridges. You may also wipe the cartridge nozzles with a damp paper towel to clean it from dirts and clogs. If error continues, check w/c cartridge is causing the error. Insert one cartridge first, then close the cover. If no error appears, then insert the other cartridge. Replace whichever cartridge is causing the error to appear.
Apr 15, 2011 | Lexmark X2690 All-In-One InkJet Printer
7310 ask to control/check bla/wh cartridge. Replaced with new one and keeps on asking to replace. How to resolve?
How to Reset an HP Inkjet Cartridge
Hi there
Instructions
Things You'll Need:
Adhesive tape
HP inkjet cartridge can be refilled easily, getting it to work again in the printer is another matter.
The contacts on the back of the cartridge are programmed to read the ink level, but they don't reset for the printer just because you add more ink.
You must get the printer to recognize the cartridge as new.
You can do this easily if you have two other old cartridges, or you can manipulate the contacts on the refilled cartridge.
Step 1
Insert the cartridge you refilled into the HP Printer.
Have the printer print an alignment page, thus recognizing the cartridge. The printer will still read the ink level as where it was before you refilled it.
Step 2
Remove the cartridge from the printer and replace it with another old cartridge.
Have the printer print an alignment page with this cartridge so it recognizes it as a different cartridge from the first one.
Step 3
Replace the second cartridge with a third one and run the same alignment page.
Because the printer only retains the memory of two Print Cartridges, it will erase the memory of the first (refilled) cartridge.
Step 4
Insert the refilled cartridge into the printer.
The printer will now recognize the cartridge as being full.
Next Steps
Step 1
Tape over the contact squares on the top left corner of the cartridge's contacts. Insert the cartridge into the printer and run an alignment page. Ignore any messages that might appear saying there is a problem with the cartridge.
Step 2
Take the cartridge out of the printer. Remove the tape from the left corner and tape over the contact squares on the top right corner. Place the cartridge backs in and run another alignment page.
Step 3
Remove and reinsert the cartridge, this time with no tape on any of the contacts. Check to see if the printer recognizes the cartridge as being full.
Step 4
Repeat the above steps if the cartridge is still shown as being empty.
This time, use the bottom corner contact squares instead of the top ones. If you are still unable to reset the cartridges, using multiple cartridges is likely the only way to do it.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); All I ask is to call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 20, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Cartridge Errror
Hi there
Instructions
Things You'll Need:
Adhesive tape
Step 1
Step 2
Step 3
Step 4
Next Steps
Step 1
Step 2
Step 3
Step 4
Mar 05, 2010 | HP PSC 2355 All-In-One InkJet Printer
I just put in new ink cartridges and the color will print but the black won't print comes out blank?
Hi there
Instructions
Things You'll Need:
Adhesive tape
Step 1
Step 2
Step 3
Step 4
Next Steps
Step 1
Step 2
Step 3
Step 4
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Dell 926 won't recognize new color cartridge
Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
Jun 17, 2009 | Dell 926 All-In-One InkJet Printer
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Printer won't recognize cartridge
I had the same problem. I'm not sure but I think I replaced the cartridges when the printer was on because I turned the printer off and removed one of the cartridges. When I turned the printer back on it recognized that cartridge but not the others. I turned the printer off again, rmoved all cartiridges and put them back in when the printer was still off. When I turned the printer on again I had no problems. So...try turning off the printer, rmove all cartridges, then put them back in and restart printer. Hope this works for you .
Nov 28, 2007 | Epson Stylus 2200 InkJet Photo Printer
Dell 3100cn Laser Printer Logo
244 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
