Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Harley hard starting problem
I need some trouble shooting ideas for a hard starting situation with my 95" Twin Cam engine, big bore kit, geared cams, with 62k miles.
The bike used to start on the first try. Now (when the engine is cold), the engine has to turn a few times before it fires.
It's especially bad when the engine is hot. It seems to be compression related, because the starter gear jumps every once and awhile.
Could it be an exhaust leak causing this? If so, how would I prove there is a leak?
  • ken_simms Dec 31, 2009
    you're right... it was a bad battery.
  • ken_simms Jan 03, 2010
    A new battery seems to be the solution. Thanks for the help.
  • 116 Answers
Highley doubtful on exaust leak causing problem first make sure your battery is up to the task do a load test if that looks good do a draw test on the starter if not there it starts to get ugly that motor came with a torrington bearing on the sprocketshaft as they wear they develop crankshaft runout not a real big issue till your running straight gears on the camshafts which only tolerates .001 runout you could be binding there
Posted on Dec 30, 2009
  • makeitfast57 Jan 02, 2010
    this prob was solved look at previous comments
How to quiet lifter noise
It depends on how noisy the lifters are. Your engine is a pushrod engine and there will be some noise. Generally is just a small ticking noise due to running clearance in the rocker arm bushings and such. The tappets (lifters) in your engine are hydraulic just like the tappets in a pushrod automobile engine. If your tappets are really making a noise, like a can of rocks, you might not have enough oil pressure or the roller on the end of the tappet that runs on the cam may be bad. If the tappet is the reason for the noise, the only thing you can do is replace them. If the roller on the end locks up, it will damage the cam lobe that it runs on as well meaning the cam will have to be replaced as well.
Good Luck
Steve
Aug 21, 2011 | 2003 Harley Davidson FLHTC Electra Glide...
Tip
Adding Reverse Gear To Some Harley's and Some Twin Cam/5 speed tranny's.
I have had quite a few questions regarding adding a reverse gear to bikes.
I am in the process of rebuilding my Suzuki VS800 Intruder and adding a Voyager Trike Kit to it. While searching, I found that Tabor Trikes USA has a Reverse Gear Kit for the following bikes;
Reverse Gear for Harley Davidson Motorcycles
Now available for 6 speed transmissions
Available for 1984-1999 Evo/5-speed and 1999-2005 Twin Cam/5-speed transmissions.
You can contact them for more information. There is a CONTACT link on the left side of the page. It's the bottom "Link Button". Please use it to find out if they have a Reverse Gear for your bike if it's not listed above. They are always adding new items.
Here is the Website Link. Tabor Reverse Gear Kit
The Reverse Gear Kits are expensive, $1349.00, but well worth the cost if you are disabled as I am. Here are the installation instructions;
Page 1 Instructions
Page 2 Instructions
Page 3 Instructions
Page 4 Instructions
I hope this helps in answering your questions regarding Adding Reverse Gears to your Bike.
Regards,
Oz
on Jan 28, 2011 | Motorcycles
I have a klx 250s 2009 model and was thinking about getting a new needle and slide put in plus a 300 big bore kit will this give it more get up and go...
The 300 kit should produce more power, and you may need to rejet the carby to match the 300 kit
A good after market muffler also increases power
A needle and slide will not produce more power, unless the current ones are very worn and supplying the incorrect mixture.
May 01, 2011 | kawasaki KLX 250 Motorcycles
In my first attempt to change my engine oil, I drained oil from bottom of my 2001 Fatboy, from the plug on the right side towards the front of the engine, just below the Twin Cam Cover and floor board,...
I'm not that familiar with the Twin Cam engine but from what you're saying, Harley has a drain or something in the cam chest of the Twin Cam engine. This is something new for Harley as the previous engines had no means of draining the cam chest. I would imagine that this is what the oil you saw was, oil in the cam chest waiting to be pumped back to the oil tank by the oil pump that is located in the cam chest. When you restart the engine, this area will again fill itself to the proper level.
Good Luck
Steve
Mar 22, 2011 | Harley Davidson FLSTFI Fat Boy Motorcycles
Can i put a 96" top end kit on my 2000 road glide
I think you can but I'd have to tell you to consult your local dealer to verify. As my profile states, I specialize in Evolution and earlier model Harleys. I do not work on the Twin Cams but I do try to offer assistance when I can.
I seem to remember that when Harley introduced the 88" Twin Cam engine, they offered a 96" kit for it. They said that the kit could be installed on the bottom end without the necessity of boring the "spigot holes" in the cases. This is NOT the case with the Evolution and earlier engines.
I hope this is correct. Please check with your local shop to make certain.
Good Luck
Steve
Dec 03, 2010 | 2000 Harley Davidson FLTR-FLTRI Road Glide
2000 roadking efi we are changing over to gear driven cams we have the work done now we cannot seem to get the timing to go right we have the marks all line up but i guess we are not finding the true...
You have two "timings" to set on your Twin cam. The cams must be correctly timed to each other and then the combination must be timed to the pinion gear that drives the cams.
Now, Twin Cam engines are NOT my expertise but in all other Harley engines, the timing mark that you time the cam with has nothing to do with top dead center position of the crankshaft. There is a specific mark on the pinion gear that the cam has to be timed to or the timing will be incorrect. Knowing the way Harley does things, the same is true with the TC engine.
Good Luck
Steve
Oct 02, 2010 | Harley Davidson FLHR-FLHRI Road king...
On my 2003 fat boy all oil from tank is in engine and won't return whats the cause ? runs real rough
Ok, I'm not exactly sure what the problem is on your Twin Cam but I can assure you that it is oil pump related. One the earlier models with the external pump, you had two pumps in one body. One pump was a "feed" pump that pumped oil into the engine. The other pump was a "scavenger" pump that pumped oil out of the engine back to the tank.
When Harley designed the Twin Cam engine, they employed a better design of pump inside the engine. It's located in the gear case along with the cams. I do not know too much about the Twin Cam engine as I specialize on the older Evolution, Shovelhead, and Panhead engnes. The older engines had a breather gear that used the crankcase pressure built up inside the engne to blow the oil from the crankcase into the gear case. I don't know if the Twin Cam still uses that method of getting the oil out of the crankcase and into the gear case.
So, with my limited knowledge of the oil pump on the Twin Cam, I'd say that this is the problem. You need to find someone that is familiar with the construction of the pump. It may be that the entire pump is bad or something as simple as a sheared pin.
Good Luck
Steve
May 30, 2010 | 2003 Harley Davidson FLSTF Fat boy
I'm helping a guy who rebuilt a 1983 sportster, th...
As strange as it sounds, the TDC mark on the crank has nothing to do with the cam timing on a Harley engine, neither the Sporty nor the Big Twin. Disregard the timing marks on the crank except for ignition timing.
To time the cams, start with the pinion gear. The timing marks on the gear and the end of the crankshaft must be aligned. Then install cam #1 and #3 so that their marks align with the marks on the #2 cam. The marks on the #2 cam must also align with marks on the pinion gear. So on the # 2 cam, you have three sets of marks that must align. Once you get these, align the #4 cam. The idler gear and generator gear do not have marks. On the '83 model, there is no timing marks on the oil pump either.
Now with the cams aligned, make sure you adjust your valves to zero backlash but you'll still be able to turn the pushrods with your fingers.
On the ignition timing, bring the front piston to TDC on the compression stroke. Now, bump the engine backwards until the piston is about half way down the bore. Check this using a common plastic drinking straw in the spark plug hole. Now, bump the engine in the direction of rotation until you see the first mark. This is the advance timing mark for the front cylinder. Continue to bump the engine in the direction of rotation. You may see another mark at the front cylinder retarded timing position. Then continue to bump the engine in the direction of rotation until you see the TDC mark and the piston is at TDC. Time you engine to the advanced front cylinder timing mark.
If you have anymore questions, contact me directly at wd4ity at bellsouth.net. I'll scan a picture for you.
Good Luck
Steve
May 15, 2010 | Motorcycles
MY 2001 ROADKING WITH CARB I INSTALLED 95 IN
Try and get the carbs balanced .You may have one in need of adjusting .
Mar 17, 2010 | 2001 Harley Davidson FLHR - FLHRCI Road...
What is the stock carburetor's mm Bore on a 2003 HD FLHR RoadKing
Since I haven't ever heard of an FLHR-Y, I can only guess at the size of the carb. If the engine is the standard twin cam 88" engine, the carb should be a 40mm version. But, if the engine is one of the "factory hopped up jobs" such as a 103" or somthing else, I have no idea of the size of the carb.
Dec 05, 2009 | 2003 Harley Davidson FLHR Road king
Lands Phones Logo
1,281 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
