Question about Panasonic PT-50LC13 50" Rear Projection HDTV
The tv clicks on but no picture or sound
The tv is plugged in i push the power button it clicks on but no picture or sound please heip!
  • 336 Answers
Hi if your tv is a DLP or LCD RPTV most likely it's a ballast issue which is the board that powers the lamp.It could also be your lamp if tv is between 2-4 yrs.God bless you!
Posted on Oct 07, 2009
Samsung ps42a457 picture disappeared whilst watching,sound still present
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 06, 2012 | Televison & Video
Toshiba model 42hp66 Plasma flat screen Problem No picture or sound. Pushing on button 2 clicks are heard A slight hum is heard at the Z SUS board. Green power light is on (power light is...
Hi
There are some factors of this kind of problem.
First you could have a failure in the power supply. Next could be the main board. Lastly you could have a problem with the panel itself, this would mean a new set for sure because the part cost is more than a new set.
However try troubleshooting the problem before spending money on repairing or replacing the television. Possibly you can restore the picture and sound to your television ...
Verify the TV is powered on by pressing the power button on the TV's remote or the front panel of the set. This may seem like an obvious step, but many TVs are equipped with a standby light that will illuminate if the TV is turned off, making it appear that the TV is on when it is not.Cycle through the TV's video inputs to verify that your TV is set to the right one. For instance, if you are attempting to use a digital cable converter box that is plugged into the Video 1 input and the TV is set to a Video 2 input that has nothing plugged into it, the TV will not display any picture or sound and may even say "No signal" on the screen. To cycle through the inputs, use the input selection button, typically labeled "input," "source," "TV/video" or the like.
Re-seat the video and audio input connections to verify a loose cable is not causing the TV's loss of signal. If you have a coaxial cable connected from your wall cable jack directly into the TV, it may have come loose thereby eliminating all picture and sound on the TV. Locate the connection cable or cables of whatever device you are attempting to watch and unplug them from where they plug into the TV. Plug them back in and check for a signal. If there is still no picture or sound at this point, the best option is to contact technical support for further assistance.
Apr 22, 2011 | Toshiba 42HP66 42 in. LCD Television
Vizio p50hdtv20a with no picture or sound
sounds like tv shop knows that is missing because they removed it so as not to work when custermer got it back with no charge
Jun 06, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Hitachi hdtv flat panel tv no soundand no picture
Most of the case horizontal output transister failure cause these type of problems. Additionally flyback transformer failure also leads same problem but it depends upon aging of the tv. Whatever it is it could be fixed by service Technician only.
Jun 24, 2008 | Hitachi Televison & Video
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
193 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
