Question about Lexmark 83 Color Ink Cartridge (Twin Pack) Printer
I have a fairly new cartridge in my computer, and the black color is coming out light yellow. Is there a way I can clean it so it will work?
  • Lexmark Master
  • 11,800 Answers
No, it's nothing you can do. Either is a serious HW malfunction in the printer or, much more likely, the cartridge has been filled with the wrong ink.
Posted on Oct 07, 2009
Yellow is missing in printouts, and the color is heavily purple, even after putting in new red cartridge and doing a deep clean
Yellow cartridge is clogged or bad. If yellow is not being out put then it will throw the other colors off. You could print a yellow, light blue, magenta (pinkish) , and black squares using MS paint or other paint program. This will narrow down which cartridge has a problem.
May 14, 2010 | Canon PIXMA MX850 Multifunction Printer
I just replaced the yellow and cyan cartridges on my Lexmark c522 color printer and now a light yellow color prints out on every page I print, even standard black and white. What should I do. Thanks
Remove the yellow cartridge. Pull back the shutter that covers the drum. Check to see if its covered with yellow toner. It should be fairly clean. You can pull another one and do the same to compare. If theres a lot of toner over it then the cartridge is bad.
Dec 19, 2009 | Lexmark C522n Laser Printer
When printing colour, black appears green
A worn out printhead can allow inks to contaminate each other, after cleaning you need to check your cartridges, if yellow is a brown color, you are getting contamination and need to replace the printhead. Black is hard to tell but when cyan gets too dark it's contaminated as well.
Aug 12, 2009 | Canon BubbleJet i560 InkJet Printer
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Changing color cartridge on my epson stylus color 980 printer.
If you need to replace an ink cartridge in your printer, please follow the instructions below:
To confirm which ink cartridge requires replacement, please use the printer's control panel (there is a black ink out indicator, as well as a color ink out indicator ), or the Status Monitor in your computer.
Red light flashing - Low ink
Red light solid - Out of ink
1. Open the printer cover and press the INK (Cleaning) button for 3 seconds. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8 (to move printhead over to color (if black was replaced first) press the cleaning button once).
8. Press the INK (Cleaning) button once, and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
May 11, 2009 | Office Equipment & Supplies
Printer will not print black ink
Seems to be a common fault with Kodak EasyShare 5100/5300
Contact Kodak Support and go though the following tests:
Remove and re-seat Printer Cartridge(s) - Done
Clean Printhead - Done
Calibrate Printer - Test Sheet Not Complete!
Run Computer Colour Test - Done
They will then send you a new Print Head.
Mar 25, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
hi,
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
HP PSC 1315 Printer
57 No. cartridge is defective. Through it in a dustbin and purchase a new one
Sep 17, 2007 | HP PSC 1315 All-In-One InkJet Printer
Ink problem
Hey tootie, the only thing possible are try head cleaning, if it dont work you can buy cleaning cartridges to fix it there only like £5 you will find below. its very common on all newer epson printers. afraid if that dont work its a new printer job as the last time i priced new heads for a epson at trade they wanted £45+vat. All the best John http://froogle.google.co.uk/froogle?q=epson+cleaning+cartridge+c86&hl=en&um=1&sa=X&oi=froogle&ct=title
Mar 06, 2007 | Epson Stylus C86 InkJet Printer
Lexmark 83 Color Ink Cartridge (Twin Pack) Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
