Question about Singer Sewing Machines
I have a Singer 15-98 and the bottom thread keeps bunching up??? What might the problem be?
The top thread tentioner was too loose and the thread was not seated in it. It is sewing like a champ! Thanks
Posted on Oct 08, 2009
Why does the bottom thread on my 185k Singer sewing machine keep tangling.
Your bottom thread looks like the top tension is too loose or not being fed through the tension disc.
1. While you thread do it with the pressure foot up. Make small pulls while threading to make sure there are no snags.
2. When you finish threading put the foot down. Check for resistance on the thread. There should be some; not excessive though.
3. Always start at four on tension and adjust as you need to.
Feb 26, 2015 | Singer Sewing Machines
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
Jan 29, 2013 | Singer Confidence 7469 Mechanical Sewing...
Thread keeps bunching on the bottom of thick material
try a different needle
here's a link to a free manual from singer
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
some machine can't handle thick fabric & some can
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
Aug 20, 2012 | Singer Curvy 8770 Electronic Sewing...
Bobbon thread keeps bunching
then it's very possible that the machine is out of time & needs to be serviced
make sure the needle is in serted correctly--flat side to the back of the machine & all the way up into the needle holder
May 18, 2012 | Singer Sewing Machines
Thread keeps bunching on the bottom of the material when I sew. Have a Singer Futura 920
Generally bunching underneath is related to the top tension. Check your tensions - you might have to fiddle around a bit to get it right
Feb 28, 2012 | Singer Sewing Machines
Thread bunchingup on bottom of material on singer
Here are some solutions to try.
* Re-thread your machine
It may be threaded incorrectly.
* Raise your feed dogs If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 28, 2009 | Sewing Machines
My singer 533 machine keeps bunching up with
Top tension about 4 or 5, make sure the bobbin turns anti clockwise, make sure you only use a mercerised thread no thicker than a number 40 and the bobbin thread should pull through with slight resistence only.
Oct 27, 2009 | Singer Sewing Machines
Keeps "birdnesting", besides rethreading, how do I fix?
when you have bunching on the bottom, you have a problem with the top thread: no tension. (and visa versa) Make sure the thread runs through the tension discs, these discs are activated when you put the presser foot down, so you want to thread the machine with the foot up, also feel if there no burrs, hooks, or whatever, so your top thread comes smooth off the spool, no jerking.
May 24, 2009 | Singer Sewing Machines
Bobbin thread bunching
I have a Singer 2950. The thread keeps getting bunched up on the reserve side of the fabric, and does not stitch. It is driving me crazy. I think I have the bobbin threaded correctly, as well as the machine. I have tried everything! Please help!
Oct 22, 2007 | Sewing Machines
Sewing Machines Logo
71 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
