No power on my printer! First thing to happen was it stopped printing jobs because it was out of ink. I ordered some replacement cartridges and I disconnected it so I could print to my secondary printer. Then when I switched them back, the MFC just did nothing. I tried plugging it into a different outlet, and nothing. Replaced the ink carts, and still nothing. Any idea how to test the power supply, or replace it?No power on my printer! First thing to happen was it stopped printing jobs because it was out of ink. I ordered some replacement cartridges and I disconnected it so I could print to my secondary printer. Then when I switched them back, the MFC just did nothing. I tried plugging it into a different outlet, and nothing. Replaced the ink carts, and still nothing. Any idea how to test the power supply, or replace it?
I hate to sound like a nut case but.....we moved the machine from one site to another (we changed offices) we decided to keep the machine where it was so I plugged everything back in JUST LIKE IT WAS BEFORE...there is powere reaching the power cord but the juice is not reaching the actual machine. I am wondering if there is another power button besides the one on the top...perhaps it got pressed during the move. I have been here for 2 years and never had a problem..the machine was here before I got here and there is not a manual so that I can look at.
HELP!!!!!Hello,
HELP!!!!!
We are setting up our printer, and during this process, had power but the machine powers off the setup. We are still setting up the language and country! Surely the power supply can't be faulty out of the box!We are setting up our printer, and during this process, had power but the machine powers off the setup. We are still setting up the language and country! Surely the power supply can't be faulty out of the box!
Hi,Same problem. Printer does not power up at all. I took the psu unit to a local electric shop and it tested fine, supplied correct output.
So I tried it again when I arrived home, but stil nothin. I then realized it made a very sharp soft ping sound when i plug it into power unit and it keeps tiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii-ing softly until i plug it out of power unit.
Plz, those of you with the same prob, listen closely if your's makes the same sound.
Any ideas why it makes the sound?Hi,Same problem. Printer does not power up at all. I took the psu unit to a local electric shop and it tested fine, supplied correct output.
Some problem here. Perfectly fine one day, totally powerless the next. I'm even getting the same faint, high-pitched whine that Crisaturno is getting. I've checked the cable, and it is good. With the noise, obviously power is getting to the printer, but nothing is happening.
[Note: This model of printer does not have a mechanical "on/off" toggle switch to turn into the "on" position. It has an electronic "on" button that does nothing at this point.]Some problem here. Perfectly fine one day, totally powerless the next. I'm even getting the same faint, high-pitched whine that Crisaturno is getting. I've checked the cable, and it is good. With the noise, obviously power is getting to the printer, but nothing is happening.
Everything was connected and all of a sudden, the printer just died. Power went off. I checked all the conenction again, everything was connected the weay it was.I tried to reboot by switching the main power outlet off and on again but till today it still 'dead'..whats up with that?. Does this mean that I have to buy a new printer?...I just got this one not too long ago and hardly uses them...
anyone have an answer will be greatly appreciated.Everything was connected and all of a sudden, the printer just died. Power went off. I checked all the conenction again, everything was connected the weay it was.I tried to reboot by switching the main power outlet off and on again but till today it still 'dead'..whats up with that?. Does this mean that I have to buy a new printer?...I just got this one not too long ago and hardly uses them...
I have exactly the same problem with my MP 750. During printing it just stopped and now it doesn't power up anymore.
I discovered that the ticking noise is caused by the switch at the button that opens the cover, where the paper exists.
Any help is highly appriciated!I have exactly the same problem with my MP 750. During printing it just stopped and now it doesn't power up anymore.
Printer is about 18months old no problems at all but went to use it and it will not power up at all - have checked all the connections plugs etc everything fine? helpPrinter is about 18months old no problems at all but went to use it and it will not power up at all - have checked all the connections plugs etc everything fine? help
AnonymousNov 20, 2008
no power on printer. it worked fine until now. is there a fuse that should be replaced ? Thank you Julian
A940 has worked fine for 4 years. All of a sudden it will not power up.Verified I had power at surge protector.A940 has worked fine for 4 years. All of a sudden it will not power up.Verified I had power at surge protector.
Holding down power button for 5 seconds did not solve problem. Tried it several timesHolding down power button for 5 seconds did not solve problem. Tried it several times
You can't post conmments that contain an email address.
I was encountering the faint, high pitched whine that Crisaturno and theaney were getting. My printer (X6170) wouldn't power on, but after leaving it plugged in for about 5 minutes the whining stopped. My printer then powered on. I think the high pitched whine is a capacitor charging (My printer had been unplugged for a week or two). Try leaving it plugged in for a good while and see if the whine stops, if it does, hopefully your printer will start up.
After a power outage, I experienced the same problem. I plugged into another outlet & still no power. Eventually, I got the printer to power up. I think when you press the power on/off switch - you need to depress the switch for 5 seconds & then let up on it. Try this at least twice to make sure you cycle thru at least 1 on/off cycle. I also thought the power supply went out - but not so.
Is the printer connected? and switched on? (sorry for saying this but sometimes silly mistakes happen). Also is the switch on the printer turned ON? (maybe just the mains is ON). If it still does not work, u need to get your printer power assembly replaced.
the power cord wire is faulty or the main board in the printer is faulty.
if wire is faulty get it replaced its very negligible.if board is the problem.replace the printer.
its very costly to get board replaced.
try to power off printer remove the AC adapter, and hold down power button for 30 seconds, then plug in AC Adapter and power on, that may "Reset" the printer. You may be having an intermittent hardware failure. Let me know if this doesnt work. Thanks for any votes
my printer hp psc 2355 all in one doesnt function at all even it is plugged. i checked the plug it has power saw light but when i put the power on for the printer to start its not working what seems to be the problem. been using this for 4 years never had problem with it just it snot having its own power even if **** plugged properly.
2. While pressing the ON button, plug the power cord back in.
The power light should flash an orange/yellow color.
Continue pressing the ON button, and press the RESUME button 4 times. The light changes every time you press it.
3. Release both buttons, and restart the printer.
The printer should now stop blinking and operate as usual.
I hope this works for you. OMS
HELP!!!!!
Julian
