Question about Itech Radio Communications
What is the pairing code for these headphone
Can any one tell me what the pairing code for these headphones. I tried the usual 1234 and 0000 and neither work.
The pairing code is simply 0000. It is written in the instructions manual.
Posted on Oct 07, 2009
How do I pair my phone and iPod at the same time?
I don't think you can pair two devices at the same time. You will have to pair one at a time . On the phone go to connections and bluetooth , switch bluetooth on and make sure it is visible. Press scan for devices .your headphones should be shown in list if they are set to visable .press pair and a option to put in a 4 digit code willcome up type in a code and put same code in the headphones and press pair these devices. Do the same with the ipod but type in a different code and put code for ipod in headphones pair devices . You should be able to listen to either one
Jan 21, 2015 | Cell Phones
When I plugin my headphones The sound dosn't go to the headphones.
First, try plugging in different headphones. If those work, then your headphones are broken and you need to replace them.
If those don't work, then please check to make sure you're not plugging them into the microphone jack - you'll see two identical plugs, usually the headphone one is marked with a pair of headphones.
If you're plugging known working headphones into the correct port, then your computer must logically be the broken thing.
Dec 20, 2013 | Motorola Mobility S9 Headphones
How do i connect to a bluetooth headset?
1. On the phone's main standby screen, tap the area next to the battery life indicator in the top right corner, then select the two horizontal arrows. You should now see the Connectivity menu.
2. Select "Bluetooth".
3. Make sure the section marked "Bluetooth" is set to "On".
4. Select the Paired Devices tab at the top of the screen (it looks like two "B" logos with wavy lines between them).
5. Select "Options".
6. Select "New Paired Device".
7. Switch on your Bluetooth headset or headphones, and make sure they're in pairing mode. If you're unsure how to do this, consult the manual that came with the headset/headphones.
8. Select "More Devices".
9. If your headphones appear on the list, select it. If they aren't found, try moving the headphones nearer to the phone and select the "Try Again" option.
10. The 5800 should now complete the pairing process with the headphones. (If it asks for a numerical code, you should find it in the headphones' manual.)
11. The 5800 will ask if it's okay for the headphones to connect to your phone automatically in the future. We strongly recommend saying yes because it saves a lot of bother.
12. Select "Yes" again to connect to the headphones immediately.
Nov 19, 2011 | Nokia E72 Smartphone
I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
Feb 21, 2011 | Itech Blue Pro Bluetooth Stereo Headphones...
Hi, My Ipod Touch has developed a really irritating fault. Headphones only work on the "right" channel unless I keep my hand on the headphone input to the Ipod in which case, glorious stereo. Any...
Hmm, have you tried another pair of headphones? That will tell you right away if it is an issue related directly to the headphones or an internal problem with your Ipod. If another pair works, then problem solved, as I myself have had the same problem. Otherwise, hopefully it is still in it's warranty period (Ipod) and you can have it fixed/replaced! Good luck!
Feb 02, 2011 | Apple iPod touch
The left ear bud wont work
This is usually caused by a short in the wire. The most cost-effective solution is to buy a new pair. "Shure" makes very nice ear bud headphones.
Sep 18, 2009 | Skull Candy Ink'd Stereo Ear Bud...
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Aug 19, 2009 | TDK Audio Players & Recorders
Only hear out of one side of headphones with sansa player - tried 5 pairs...
i had the same problem, the headphone jack on the sansa is loose. I opened it all up, and saw that one of the connections on the headphone jack was loose. you can sauter it and it should work clearly again.
Mar 20, 2008 | SanDisk Sansa e250 MP3 Player
Pin code
Is this the first time you are pairing two Bletooth devices ? Is the security pin for your Samsung phone '0000' ? Usually, the code you have to enter on your phone to pair it with a Bluetooth headset or headphones is '0000' (the number 'zero' 4 times), unless Jensen's Bluetooth headphones use a different pin.
Hope this helps.
zeceten@yahoo.com
Dec 22, 2007 | Audiovox WBT212 Headphones
Radio Communications Logo
379 people viewed this question
Top Itech Radio Communications Experts
Vernon Taylor
Tom Chichester
Are you an Itech Radio Communication Expert? Answer questions, earn points and help others
