Question about Hotpoint Refrigerators
Our frig is not cooling but the freezer works fine, it is a hotpoint side by side fri freezer... it made a humming noise for a while but that has stopped.. any help would be appriciated... what the trouble may be and how much it will cost... thanks!
  • 173 Answers
Check the evaporator fan. May be it stuck or burned out
Posted on Feb 18, 2015
    President:
  • 1,653 Answers
In side by sides if the fridge side not working correctly it means that the air vent from the freezing unit has stuck in the closed position which causes the fridge to not be any where near as cool as it should be and if it is too cold then the vent is stuck in the open position. The vent is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up, which can be caused by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. Best call a service engineer asap.
Posted on Oct 07, 2009
Hotpoint Rfa52 fridge not working. Freezer ok.
is temp or freezer control turned all the way up? set frig / freezer control in middle and wait 24 hours. do you feel cool air going in freezer from vent? if not change control as stated and see if you have air flow. control door to frig may also be broken or stuck
Jan 30, 2014 | Hotpoint RFA51 Bottom Freezer Refrigerator
The motor by the freezer runs loud
What is the model number of your unit?
Nov 27, 2012 | Hotpoint Refrigerators
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
My Hotpoint makes a high pitched humming noise all the time.
This noise is most likely coming from the evaporator fan motor that is located behind the panel just below the ice maker. There is an air duct that the fan blows through to cool the ice maker that is why the sound is heard in the ice maker area more.
The noise does not hurt anything but the motor can be replaced if it gets too annoying, it is a fairly common complaint. The part number for the motor is WR60X10185 and runs about $60.00. It is a bit challenging to get to but can be done with a bit of patience by removing everything in the freezer and taking the back panel off the inside of the freezer.
Apr 18, 2010 | Hotpoint HSS25GFP Side by Side...
Loud humming noise
Stick you hand in the freezer, touch the back wall of freezer, see if you feel a strong or lite vibration equal to the hum you are hearing. If so, the you have a bad evap fan, if not then pull unit out from wall and see if hum is load toward the bottom rear portion of the frig, if so contact a repair tech.
Oct 01, 2009 | GE GSS25JEMWW Side by Side
Hotpoint frig,top freezer motor runs contiunally, thermostat set in middle of temp. control. side of frig stays cool all time.[does not get warm as it used to] is defrost thermostat bad or timer?
niether. is there frost on back wall of freezer? if no look behind back wall and see if there is frost on all the coils when running. if less than 80% is frosty...freon. or is there frost covering back panel..if so then defrost problem would be correct. but side would be warm so I think not.
Jun 12, 2009 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
My side by side makes a loud humming noise from the freezer when the frig is running can you help solve this promblem or do i need to buy a different brand to solve this promblem for the second time
most likely it is the evaporator fan motor.you can replace it but know telling how long the new part will last.not very expensive part but very easy to replace.once you take the back panel off in freezer you will look above the coils and you will see your fan motor.
Mar 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
2006 kenmore frig - freezer and frig are both hot
if both sides are hot it sounds as if the compressor isnt running. pull the refig away from the wall and remove the cardboard cover the compressor is the black bowling ball loking thing that you see. fell to see if it is running should have vibration and making a humming sound. if its not running listen for 3-5 minutes to see if you are hearing an intermittent humming and clicking noise. this would indicate a bad start relay for the compressor. if the compressor is running then you mostlikely have a freon problem which will require a qualified technician to repair. good luck and thanks for using fixya Peyton..
Jan 27, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Any thoughts?
Any noises from frig at all??? cicking humming???pull the unit out and remove back cover. Is the compressor(football)size motor in back hot to touch??Lights are on in frig right?
Feb 26, 2008 | Refrigerators
Refrigerators Logo
82 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
