Question about Nikon Coolpix 4600 Digital Camera
Battery door broke and ordered replacement part. Part came with just the door none of the inner parts. Need to know how to reassemble battery door parts. Thanks
dutchman05
  • 487 Answers
SOURCE: Panasonic Lumix DMC-TZI - broken battery tab and battery/card door
well there is no easy way. You will have to open the machine up when you have ordered the parts you needed. Not to hard but make sure you keep you eye on the sequence how you pull it apart.
Posted on Apr 24, 2008
SOURCE: broken battery door
I phoned the Olympus people for replacement parts 800-622-6372 and they shipped me a replacement battery door assembly for my Stylus 1010 camera. I only paid shipping.
Posted on Oct 29, 2008
SOURCE: Battery door latch broke off body of Canan A590
The same thing happened to me this week. I called Canon Canada directly and asked to order the part (The battery compartment door). They gave me a phone number to call and I was able to order the replacement door for about $8.00 + $10-$12 shipping. Hope this helps!
Posted on Feb 25, 2010
  • 102366 Answers
SOURCE: Olympus stylus 1010 battery door latch broken
http://uscamera.com/vk9076.htm
Posted on Jun 14, 2010
SOURCE: Broken Part - Battery Door
It is not too easy to change the door, but can be done.
You have to "tear" away the rubber from the handle. There are a couple of screws under the rubber to remove. The righter part of the batteryholder is kinda loose at that point. You can use a little screwdriver to open enough gap from right side from the point A. Then you can slide the battery door loose and replace a new one.a298e8d.jpg
Posted on Jul 20, 2010
I need to change the plastic sliding piece that keeps the battery in place in my Fe-230 dig camera. Where can I order the parts? Help will be really appreciated
Most battery doors of camera cannot be manually replaced. If your battery door for your camera broke off or the hinge is loose, the only option you have is to contact Olympus customer service.
May 17, 2011 | Olympus FE-230 Digital Camera
How do I open a Braun 8585 shaver to replace the battery?
You will find batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Jul 13, 2010 | Braun 8585 Electric Shaver
Jul 10, 2009 | Canon PowerShot A590 IS Digital Camera
How do I replace an Olympus Stylus 710 Battery Door?
Please visit this site and order a new batterydoor for your Olympus camera www.lutoncameras.co.uk
regards Rob NL
Apr 15, 2009 | Olympus Stylus 710 Digital Camera
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Broken handle on sliding door behind driver
First get vin call toyota parts dept/ get the part its really easy to put in look for screws in little pop ups take screws out then go from the bottom of the door and lift out then go side do the same thing then lift from bottom of door and upward then you will take of vapor or plastic sheet then you just replace the handle thats it then out it back together/ Please rate my response thank you very much
Dec 28, 2008 | 1999 Toyota Sienna
Inner door seal
You need to disassemble the door and reassemble with the inner glass well in place, no need for a new door.
If the glass is damaged, call manufacturer and replace glass.
If some other part on the frame has bent, replace the faulty part.
The whole door is expensive.
To replace or refit the door glass you can do the following:
See diagrams below as an example, I do not have Tecnik diagrams:
Contact Tecnik at the number listed on the owner manual to get diagrams for your model.
Apr 09, 2008 | Tecnik TKC1426 Electric Kitchen Range
Nikon Coolpix 4600 Digital Camera Logo
19 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
