Question about Linksys Wireless-G WRT54G Router
Having problem with the router everytime i connect it to the internet to set up my network it doesn't work
    Problem Solver:
  • 5 Answers
Please emake sure you are connecting you network to the correct port on the back side of the router make sure you are in the lan port
Posted on Oct 07, 2009
  • krazybonekri Oct 07, 2009
Reset the router
1. On the back of your router there is a little black reset button. Use a pen or paper clip and press down for 10 seconds. Make sure the lights on the router stop blinking for one second. Release the button and make sure to reset your wireless security and network ID.
2. If that doesn't work just unplug your routers power cord. This is the easiest way to reset your internet connection without resetting your router to factory settings.
3. If neither of those work, unplug the power cord of your modem. This will completely reset the internet connection without resetting the routers settings.
Jul 09, 2011 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
I have a Toshiba Satelite A205-5000. I have bought 2 new routers, one Linksys and Netgear. It gets a network connection but the IE exploer will not bring up sites. It acts like it does not get a good...
Hi there, Before we start, try hooking your laptop up directly to the modem - if you're not getting an internet connection there, call your Internet Service Provider. If you are, then follow the steps below.
1) Make sure that you're not using more than one router at the same time. One router should be hooked up directly to your modem in the WAN port. If you have wireless security enabled, go to step 2 2) As a test, remove the security on your wireless network and then see if you can access the internet properly. The router can be accessed by typing it its address in internet explorer, as long as you are connected to the router. Generally the address is 192.168.1.1 3) If you still can't access the internet, go to Internet Explorer Options, the Connections tab, LAN settings, and make sure "use a proxy server" is NOT checked. 4) If you DO get an internet connection now, go back to your router and enable WPA security (some older laptops have problems with WPA2 connections).
If everything doesn't work, post back with some more details! Alex
May 30, 2011 | Toshiba Computers & Internet
My wireless network is visible but when I try to connect with the correct password , it doesn't connect because of an error. The only way I can get it to work is to change the password everytime, then a...
To see if your router is working properly press and hold the reset button. This will reset your router and it will have no password requirements. Connect to the network and see if it continues to drop the connection. If so, you have a bad router. If not connect to the router with the supplied cat-5e cable open an internet window and type 192.168.0.1 in the address bar. Select admin as the user name and leave the password blank. Then follow the set-up wizard.
Manual can be found here. http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
Mar 20, 2011 | D-Link DIR-615 Wireless Router
I have a wireless network of computers, one wired and 2 wireless. in the correct setup, my other acer laptop doesn have internet, but s connected to the router, and this laptop im using CAN connect...
All the computers should have the same NETWORK NAME or SSID.
Recheck the settings and make an adhoc connection for each of the computers to your router.
You can also get a USB wireless adapter to enable ht NO internet laptop and connect them.
Just keep playing with the NETWORK SETTINGS.
Make sure all are connected to the SAME SSID.
Hope it helped.
God Bless You!
Feb 05, 2011 | Linksys WRT120N Router
I have a NetGear Wireless Router which wont connect to internet.
Verify that you can connect to the internet without the router by hooking the cable from the dsl modem to your computers NIC.
If you can connect to the internet that way the problem is with the router. press and hold the reset button on the back of the router to reset it to the factory settings. (this just makes it easy to determine the problem) if this corrects the problem you can setup your security again
Aug 30, 2009 | NetGear RangeMax WPN824 Router
I have DI 524 d-link. Internet works on desktop and one laptop. Just got a new laptop and everytime I try to connect on the network of 1st. laptop, it says connected with limited access. unable to have...
Make sure that every setting in the new laptop matches the settings in the router. If one setting is off, you will not get a connection. It is also possible that the router is set to only allow specific computers to connect to it. If that is the case you will have to add the new laptop to the allowed connections in the wireless settings of the router.
Aug 10, 2009 | D-Link AirPlus DI-524 Wireless Router
How do i secure my internet router with a password?
setup your router in private connection, the network asking for password or put a password by open the firmware of your router, if he have it. with this only can hook and have internet to connect it.
And also read the manual for further instructions on how to put a password.
Jul 18, 2009 | Computers & Internet
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Identifying network, unsecured network
Are you using the Dell utility to connect to networks ? Try setting the network you want to connect to as your "Preferred" network in your wireless utility on your laptop. Also, try moving the network to the top of the list. Doing this might set it as your "Preferred" network.
Mar 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
