Question about Sport & Outdoor - Others
Putting together a portable adjustable basketball hoop...Don't remember where 2 metal triangle pieces with 3 hole in them go. huffy sports 74frtcvr#1
  • yoshi_four May 11, 2010
    Can you give me more details as the to parts?
4 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: I have an old huffy
Follow the below assemble instruction as requested for your huffy sports basketball hoop;
Insert the mounting screws through the mounting holes of the backboard, then lay the backboard face down. Lay the mounting brackets on top of the backboard so the mounting screws of the backboard go through the mounting holes of the brackets. Tighten the screws with a wrench.
Insert the adjustment hardware between the brackets and insert the screws connecting to the brackets to the adjustment hardware, then add a nut to the screw and tighten with a wrench. These screws will be inserted horizontally through the brackets into the adjustment hardware. The adjustment hardware allows you to adjust the height of your basketball hoop.
Line up the holes of the rim to the holes of the backboard and install the rim screws through the rim into the backboard and secure them with a nut. Tighten the nut with a wrench. Thread the nut through the wire holes of the rim.
Assemble the pole. Dig a hole with a shovel where you want to install the basketball hoop. For the exact size of the hole, you will need to consult the directions on your Huffy basketball hoop. To achieve the regulation height of 10 feet, this step strongly depends on the size of the particular basketball pole and a specific measuring depth. Measure the hole with a tape measure for accuracy. Mix a bag of cement in a wheelbarrow with water. Consult the directions on the cement bag for exact mixing instructions.
Place the pole in the hole and shovel in the cement. Allow the cement to dry.
Use a ladder to reach up and connect the mounting arms to the mounting brackets and then to the top piece of the basketball pole. Each of mounting arms has a hole at the end that you need to line up to the mounting bracket and secure with a screw, add a nut and tighten with a wrench.
Line up the holes at the end of the two top arms to the top holes of the top of the basketball pole. Insert the long screw through the holes of the arms and pole, secure it with a nut and tighten it with a wrench. Install the bottom arms to the lower holes of the basketball pole.
I hope the above helps.....
Good luck.
Posted on Apr 03, 2011
jyackle5
  • 8197 Answers
SOURCE: i bought an old huffy
The only way to get the asembly manual is to contact Huffy on the link below.
http://www.huffysports.com/contact_us/index.php
Posted on Jun 12, 2011
Ironfist109
  • 3018 Answers
SOURCE: I want to pull apart
  • I know exactly what your talking about. When you disassemble the hoop assembly down to just the poles get yourself a friend and a couple long screwdrivers and run them through the holes at the top and bottom of the pole. One side for you and the other side your helper. You may want to spray some WD-40 or any kind of bolt buster lubricant in where the poles are connected first. Give a gentle twist back and forth as needed too. You will want to do this on a lawn so that when they come loose they don't get all scratched up. This is how one is suppose to separate these poles.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jul 03, 2011
Adjustable basketball hoop
push on the back board up to get it to lock. Use the catch plate to bring it down.
Jun 14, 2016 | Spalding 72351 Portable Adjustable...
How do I install spalding basketball hoop in the ground with concrete and how deep do I dig?
Dig below frost line, depends upon where you live, but at least two feet deep. I would make the hole about a foot wide. Pole diameter 3-4 inches in diameter.
Aug 10, 2014 | Spalding Sport & Outdoor - Others
My basketball hoop broke and I have a pole cemented in the ground. Can you buy just the hoop/backboard itself and attach to the pole or do I have to cut the pole and start over?
Sorry I know nothing about basketball but it seems a crying shame to cut down the pole even if you can't find a replacement hoop and board.
I have faced many similar things and I find remembering the wise old saying "in order to get the right answer it is important to first ask the right question"...
I suggest you ask around those who should know such things - the coach at the local schools, local teams. If you don't get satisfaction then why not ask your local repair shop or fabricator if they can make what you need at a reasonable cost.
May 17, 2017 | Lifetime Sport & Outdoor - Others
Hi! i need an owners manual for a portable Spalding basketball hoop. model number is 77537t.
We had the same issue and I just called customer service at 1-800--SPALDING and they emailed me the instructions!
Jan 02, 2011 | Sport & Outdoor - Others
Need replacement balls for a Huffy electronic
I have found the number for Huffy. You should be able to see if they have replacement balls for your electronic basketball game.
U.S. Customer Service
Email: service@huffysports.com
Phone: 1-262-820-3440
Phone: 1-800-558-5234
Fax: 1-262-820-6757
Thank you, hope this helps. Please let me know.
Apr 30, 2010 | Huffy Dual Electronic Basketball Game
I have a lifetime basketball goal with a broken backboard. My son threw a rock threw it. Can I get a replacement glass? Is it easy to change?
You NEED to get a replacement piece from the manufacturer. You could get a piece of lexon from home depot but it will cost you a bit.
Sep 15, 2009 | Lifetime 71729 In Ground Basketball Hoop
Assembly instructions for portable basketball hoop
we put all three poles into one by mistake on our new portable hoop we managed to get the screw out but cannot get the poles apart help!
Sep 10, 2009 | Huffy Sport & Outdoor - Others
Replacment 7" basketballs
http://www.amazon.com/Voit-Voit%C2%AE-Super-Mini-Basketball-EA/dp/B001285TW8
One reviewer even specifically notes that he bought them for your same game.
Jan 04, 2009 | Park and Sun Sports PS-FAH Fold-A-Hoop...
Sport & Outdoor - Others Logo
215 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
