Question about Kenmore 73952 Gas Dryer
Is my drum loose?
Okay the drum is turning but it is knocking. could it be loose and how do i fix it?
  • 833 Answers
General reasons for a knock are that the belt is chunking out or one of the support rollers has cracked. If you can get inside, it will be obvious. I'm assuming you did check to see if there is anything that parked itself in one of the drum fins.
Posted on Dec 24, 2007
2000 Saturn LS2, knocking in front when letting off accelerator as it begins to coast down
knock on the the bumper gently with your hand , keep going around the car until you find the source of the noise, a missing bolt might not be simple to observe but if you knock on the body of the car you will find out where the missing bolt is and the source of the ratling
Nov 07, 2017 | Saturn Cars & Trucks
Washing machine shakes badly when spinning.
If not an unbalanced load, then it is an unbalanced drum. Turn the drum by hand when it is empty and it should spin smoothly (not freely because it is attached to the motor so there will be resistance). Can you hear a knocking or grinding? Push and pull the drum in and out, again any knocking? With your hands at 3 and 9 o'clock push with one hand while pulling with the other and rock the drum back and forth. Try it with hands at 12 and 6. Does it feel loose or makes a knocking?
Grinding is usually a sign if the bearings going or gone and knocking may indicate a broken drum holder (sometimes called a spider)
If everything sounds and feels okay then it may just be the machine is not level or secure. Rock the machine and if it wobbles check the feet and adjust until no more rocking. The feet do bend or adjust themselves over time, even making some kind of impression on the floor that makes it settle to a different level.
Jan 24, 2016 | Washing Machines
I have a question in that the washer when it turns either way I hear a knocking sound and I am concerned about this problem if any. Next the hot water is coming out slowly and I checked the fix it
is this front loader? if so, reach into the drum and try to move it up and down - there should be no play. sometimes the arm holding the drum will corrode and break causing the drum to come loose. it's usually not worth fixing if that happens.
Feb 15, 2015 | Washing Machines
Hoover 750 lc heavy duty macking noise whene spinning dry
Possible drum bearing. Check for any knocking by turning drum by hand whilst empty.
Sep 13, 2014 | Hoover Washing Machines
Error code 7410:0095606 How can I fix it?
Drum unit non- installing error
The drum unit is not installed or not installed properly. You must have knocked it loose.
Install the drum unit (See page P.1-5-10).
Oct 11, 2011 | Kyocera FS-3900DN Laser Printer
Ultima extra wma64 drum is loose and rattling
Your bearings have broken up in the drum. This is a very difficult DIY fix since it involves stripping the front from the machine, taking out the drup assembly, splitting it, knocking the centre spindle free and then knocking out the machine pressed bearings and replacing them.
It CAN be done by an ameture. I do it occasionally when I am repairing machines and I constantly moan about the fact that I really need to build or buy a tool to knock the bearing out. Despite the fact that the new bearings will cost about £20 ($30) ish, this is a nightmare job. Your local repair man will probably come and fit a refurbished drum for you (Then take yours away and refurbish that for his stock when he has time).
If you have never done anything like this, my best advice is that this is NOT the time to start!
Get a quote, then decide if you want the machine repaired, or to go buy a new one I'm afraid
Jun 21, 2011 | Hotpoint Ultima WF860 Front Load Washer
Frigidaire heavy duty electric dryer started with sqeaking noises now is knocking belt appears in place drum turns mannually feel somthing loose between drum and rear cover
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 14, 2011 | Frigidaire GLGR642A Gas Dryer
Loud knocking and a loose inside aluminum drum.
One or more of your tub supports is broken. Unfortunately there is no cheap fix but wiil be cheaper than a new machine.
Mar 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Drum turns when dryers not running
Does the drum just constantly turn and never stops or does it just take a really long time to stop? If it just takes a long time to stop it sounds like a loose belt. If it just turns and turns and turns something in the control panel isn't telling the motor shut off but with the clunking sound you're hearing I'd guess its the belt.
Nov 04, 2009 | Frigidaire GLER341A Electric Dryer
Maytag dryer has knocking for every turn of the drum
Replace loose blower:fa3c9cb.jpg
Start here:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 22, 2008 | Dryers
Kenmore 73952 Gas Dryer Logo
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
