Question about Mitsubishi WS-65311 65" Rear Projection HDTV-Ready Television
Sound and menus but no video
-My tv suddently doesn't have video thru any inputs but it has sound and I can see the menu screens, the channel text.
Any ideas what may be wrong?
thanks
    Genius:
  • 1,153 Answers
Do self diagnosis test at ctechnicians.com
Posted on Dec 24, 2007
How do you get audio to play through a receiver? We have the TV running to input on receiver and no sound?!?!
You have to go thru the menus on the TV and tell it you want TV speakers off, and output to surround at fixed volume. Then plug audio out wires (RCA jacks or optical digital wire) from audio outs on TV to AUX or Video or something like that into the receiver.
Jan 21, 2015 | Insignia IS-LCDTV32 32 in. Television
I have a Coby TFTV4028 and just bought a sound bar which only works when on the TV input but is not recognized on any other inputs. Is there a way to fix it?
The only audio output I see is the headphone jack from which to run the sound bar input. Is the sound bar surround/expanded sound features? Check the audio setup menu on Tv, the sound bar input selection, and try a cord from the headphone jack to the sound bar, if you haven't already. There should always be 2 channel stereo at the head jack unless it's turned off in tv menus. I see the owner's manual is very poor.
Oct 26, 2017 | Coby 40 TFTV4028 LCD TV
I Have Proline LD1401 TV and it does not work with sound and picture, Only sound. What can I do. No money for new one.
Hi! Welcome to Fixya!
If you are unable to view video on your television set, the issue may be that the TV's video input selection does not match.
The TV input source must match how the equipment for example DVD is connected to the TV. Every TV is different in the way that the ports are configured on the back of the TV and the menus are presented on the TV screen; however, there are some basic similarities between them.
You may follow the steps bellow:
1. Please make sure that the cables are properly connected,
2. Use the TV's remote control and change the video input selection.
Some common names of the button on the TV remote are:
  • Video Source
  • Video Input
  • TV/VID
3. Press either of those button and check if that will give you options.
4. If you are using a coax cable kindly cycle the channels from channel 1 to 10 check what channel can give you picture
For clarifications please keep me posted.
Thanks!
Lor04
Apr 06, 2011 | Televison & Video
My screen is green and does not show a picture or sound! You cannot change the channel or access the menu! Is it the picture tube or lamp?
Can you see menus if you press the menu button? You could be set to the wrong input that doesn't have a signal coming in. I have one TV that shows a blank blue screen when I'm on an input that has no signal. If there is not a signal on the input being used you will also not have sound.
Mar 21, 2011 | JVC Televison & Video
I have a 42inch lcd polariod tv and the screen comes up blue no picture or sound
It could be the blanking circuit displaying a blue screen if no or a weak signal is connected to the TV. If you have a DVD or VCR try to see if you get picture and sound when ether of those devices are connected to the auxiliary input. If yes your signal input is weak, or you are getting no signal at all. If you go into the TV do you see text? If yes make sure you’re on the correct auxiliary input. If no text is visible the problem is internal and the LCD driver circuit needs to be repaired. If you see text and you are on the correct auxiliary input, but you get no picture and sound then the problem is internal and the front end tuner needs to be repaired. If you see video and hear the sound make sure your channel is correctly selected and set to a working channel. If you have a cable box remove the input to the box and connect it into the coaxial input on the TV and see if you have a picture and sound. If you do the cable box is defective. If you do not see any channels the cable may have lost its signal, and you should connect the cable to another device to check the signal quality. If you have a satellite service provider, and you use a known working device to check the signal and the device works then the TV needs to be serviced.
Feb 18, 2010 | Polaroid Televison & Video
I have sound but no picture. The screen is black
can you see any any menus or the volume bar or channel indicator?
Make sure all your audio and video cables are hooked up correctly to inputs on the TV and to the same set of hookups. For example all of the VCR cables hooked into video 1 and all of the DVD cables in video 2.
Also check that you haven't hooked up the video to the tv's output. Some sets output audio and/or video for external devices such as recording setups or home theater sound systems.
Oct 17, 2009 | Zenith TVBR2742Z 27 in. TV/VCR Combo
No video & no sound
12 years of service count your blessings
if its the flyback (high voltage transformer)
they are probally not available
get an estimate from repair shop no simple fix
Dec 20, 2008 | Hitachi 35CX45B 35" TV
Unusable signal prompt on video input
be sure to cycle thru the input selections-- either w/Remote (input button), or channel +/- on the panel. my truflat 26" hd set has side/front/video1 video2 inputs, yours may have more or less. also, be sure you've plugged into an INPUT set, not an OUTPUT set. Does sound work otherwise on this set? If not, maybe interal speakers (menu setting) is set to off/not checked.
And on your PS3--goto the settings menu, sound outputs, make sure you select A/V connector and analog sound. The ps3 cable can become sloppy too, wiggle/check/reseat or try another cabe (usually video is touchy more than the sound though)
If you KNOW you've got the right input selected and the PS3 is setup properly, do you have another device with audio output to test on the TV? a notebook computer, walkman, cd player--anything that has rca outputs for sound--quick swap the cables to the new 'test' device-- if sound is OK with test device, either PS3 setting or cable is bad/wrong. if no sound from test device on TV either the tv is not using proper inputs, or is damaged, or the test device is not properly configured. If you have another input receiving device to test the ps3 output sound, like the LINE INPUT on a notebook computer, or a boombox with Aux inputs, test the PS3 sound output too.
Jun 08, 2008 | RCA TruFlat 27F520T 27" TV
RCA F32665 Shows only gray screen, sound works.
You have a problem in the video circuit. Any video that comes into the set is not getting to the picture tube. The menus come from the system control microprocessor. This shows that the input at the picture tube itself is working. Also you system control is working. The signal would have to be traced through the set to find out where the loss is originating. Stargazer
Jun 14, 2007 | RCA F32665 32" TV
Mitsubishi WS-65311 65" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
