Question about Toshiba 23HLV87 23 in. LCD Television
I'm having problems ejecting the dvd from the combination tv/dvd set. It makes a humming sound and eventually gives up. It has occastionally also shot a dvd or cd out in the past.
  • 178 Answers
This unit used two rubber rollers to move the cd in or out, the humming is the motor turning in an attempt to eject the cd. The rubber rollers cannot grab the cd. One reason would be that the rubber rollers have got a very small amount of oil on them making them slick so the cd cannot eject. This can be caused by a thick finger print or the like.
Cleaning the rollers with alcohol will usually fix the problem, but you need to dis-assemble the cd unit to get to the rollers. A repair shop can fix this and it would not be an expensive repair, usually the minimum charge the shop offers.
Posted on Oct 10, 2009
    President:
  • 1,653 Answers
Power off the TV and then then power it back on again. As soon as you do this press the eject button and the DVD sould be ejected.
If there is a small pinhole on the face of the DVD player then you can carefully insert a paperclip in it to emergency eject the DVD.
Posted on Oct 07, 2009
I have a TTM 2003 and the sound has gone bad the TV is humming. Do I need to junk this or can it be fixed ?
With the price of new ones, you are further ahead in replacing the set, cost to repair will be close if not more than a new one.
Mar 12, 2012 | Polaroid TTM-2003 Combo
Our Toshiba 23HLV87 combo TV won't eject the DVD. We've had the TV 2.5 years and about a year ago, this problem would occasionally happen. Eventually we could get the disk to come out with patience and...
Hello Friend,
A small belt that connects the motor and the DVD tray is worn out or lost its elasticity, ask your nearest authorized service provider to visit and replace it.
Good Luck.
Dec 20, 2010 | Toshiba 23HLV87 23 in. LCD Television
I recently purchased a used emerson 19 1/2 in hd tv dvd combo. Love the picture but it did not have a remote. I purchased an RCA universal remote which seems to do fine except that I can't find a way to...
bookdoc969,
Without the model number I cannot give you a specific answer but the following site claims to have remotes you cannot find anywhere else. Give it a try.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 11, 2010 | Televison & Video
The dvd does not come out. TV plays, dvd plays, when eject button is pushed, it soundsl like it is coming out, then does not
Some units have a little hole where you can insert a straightened paper clip to manually eject the DVD,
Make sure the power off first.
Jul 26, 2010 | Sansui LCDVD150 15 in. TV/DVD Combo
Problem ejecting dvd from side panel 32" dvd/tv conbo
Either the drive belt for the drawer transport is worn out or the drive pulley has a crack in it and cant drive the belt. Sounds like a trip to the service shop is in order unless you are into taking it apart and investigating yourself. Belt will cost about $3.00.The drive pulley can usually be carfully glued.Making sure not to get any glue into the motor.Hope this helps.
Feb 10, 2010 | Televison & Video
I have a dvd stuck in a toshiba tv dvd combination
Try a reset on ur tv,Like unplug ur tv an hoour.Replug it back.Should get power to the DVD port to take out the DVD disk.
Feb 08, 2010 | Toshiba 23HLV87 23 in. LCD Television
Humming sound when watching tv,but not when watching dvd's
It wounds like you are getting interference from you tv to the receiver. You can try a few different things here.
1. Connect the tv output into another input on you receiver to see if it isnt the channel on the receiver.
2. Try a different set of cables between the tv and receiver. Faulty cables can give you problems.
3. Connect the cable from you tv to a different device. (another dvd vcr blue ray etc.) This will tell you if its the receivers or the tv.
Sep 13, 2009 | Yamaha HTR-6030 Receiver
I have an LG V271 - a DVD will not load and now will not eject
I found a solution. I had switched off the unit and that did not help.
I eventually disconnected the power cable and reconnected.
I was then able to eject the DVD
Jan 25, 2009 | Sharp DVRW250 DVD Players
DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
Jun 19, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
DVD won't play on any disk.
How old is your dvd and how long is this problem going on?once you can answer thequestion i wil be able to give you advice.send your answer to nicodhem@yahoo.com goodluck.
Mar 19, 2007 | Sylvania SRCD227 27 in. TV/DVD Combo
Toshiba 23HLV87 23 in. LCD Television Logo
269 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
