Monitor started to flicker then went blank
Screen is blank, power light is blinking green. Disconnecting the video connection makes no difference. A substitute monitor works OK, so definitely seems to be a monitor problem. Any ideas? Many thanks.
have a Envision 19''model # EN9410e was bought at staples 1 yr ago,it started to flicker then screen would go blank then come back on afew times we turned it off turn it back on green light flickered but screen stayed black,whats wrong with it
  • 3 more comments
  • bbsteg Jan 01, 2008
    I went to envision site reguarding my monitor going blank and finaly the power light going from flashing green to no light only help I received was them sending me to this site which request membership and a fee no help to me at all
  • mikeVec Nov 13, 2008
    Same exact problem... screen going in and out...after a few days it
    went blank Green power light flashing.
  • myhof Jan 09, 2009
    I have the same lcd "envision en9410e" It comes on for a second and then off for a few seconds.
  • DC420 May 01, 2009
    I have a Envision 19''model # EN9410e as well which was purchased at
    staples 1 yr ago. Recently, the green light began to flicker and now I have a blank screen. It is not a desktop issue. Any ideas on how to resolve this. Envision tech support could not provide answer accept to ship it back to them with a receipt which I don't have.
  • Anonymous May 05, 2009
    I also have an Envision 19''model # EN9410e that kept blinking off and on with start up, finally went completely blank. This is a one year old monitor. Is there a fix for this or do I need to replace it?
I have a envision professional series and I love it, but I will get to the point.
I recent ly received a Envision EN9410e monitor, had the same problem (flickering screen then turned on, then off then on then blank). The problem is bad capacitors. There are 7 electrolytic capXon capacitors that will need to be replaced. You should see if the caps are bulging or leaking, if so replace. As known by many replace with the same capacitance and voltage. There are a few incidences that the capacitors where replaced and the problem wasn’t solved; this is because the cap problem wasn’t taken care of and damage occurred to another part of the monitor. The back light is a Royer oscillator (cool things) and it uses two smd mosfet transistors. They are on the green side of the circuit board near a big control chip (they each look like a off rectangle black square with eight pins) you need to see if there is any carbon or chard residue between the pins or burning smell from them, if there is you need to remove the transistor and do some board repair then ether put a new transistor or try the old one. No offence to the people at Envision but not smart putting the drain, gate and source so close to each other under the chip where there is such high voltage! Hope this helps.
Posted on Sep 29, 2009
I have the same problem with my monitor. It started a few days ago and Christmas day it was done. So now it just keeps turning itself off and on.
Posted on Dec 26, 2007
2 Suggested Answers
SOURCE: Blank screen
its cheap buy a good one!!!!!!
Posted on May 06, 2008
I have a samsung syncmaster sa300 that just went blank.
do you mean this monitor have been tried to hooked up with other pc then still no display?. ok if their is a power indicator light at front with no blinking but their is no display ( black screen ) the cause will be either the inverter board has damaged or screen back light is busted .
Jul 25, 2012 | Computers & Internet
I've had my monitor for years with no problems. Today, when I turned on my computer, the monitor flickered. Then the screen went black, and the power button began blinking (green). When I turned it off...
A couple of things to check. First make sure that all the connections are in place. That is, the one at the PC and the one on the back of the monitor. Second - Make sure that the video card is seated correctly in the PC. Third - Replace the monitor cable. Fourth - Check with another monitor, if possible.
Mar 27, 2010 | Dell E153FP 15" LCD Monitor
No signal on monitor
Do you have another monitor to test your computer? Looks like a surge went into the computer display and damaged the video card.
Sep 07, 2009 | XFX GeForce FX 5500 Graphic Card
Blank screen
This looks like a problem with the video card or the power supply to the monitor. Try connecting a different monitor and if you still face the same problem then probably you may need to have a look at your video card or its connection in motherboard
Feb 01, 2009 | ViewSonic A90f+ 19" CRT Monitor
SVA Color TFT LCD is white on start up but goes blank.
when i turn the computer on the light on the monitor blinks green but i cant get it to turn on..i have a black screen.
Jan 16, 2009 | Computers & Internet
No video display
If the video card is built into the motherboard then try starting in safe mode and reinstalling the drivers from scratch. Download the latest drivers from the dell website. Safe mode will reduce the resolution and use a generic VGA driver. If your video card is plugged into a PCI slot try unplugging the video card and using a different slot and going through the same process. If you are still not getting any output to your monitor and you are positive the monitor is fine then you may need a new video card. To be sure, if the video card isn't embedded to the mother board, you could take it out and try it in a different computer. Hope that helps.
May 23, 2008 | Dell Dimension 4600 PC Desktop
173v flat lcd black screen
I've had a similar problem with my 173v monitor since I bought it a few years ago. When I start my computer, Mac or PC (I've connected it to both), the screen remains black and the green power light flickers once a second, almost like it's twitching - it's different from the blink it makes when the computer isn't turned on but the monitor is. Like kronem, I have to unplug the line from the monitor to the computer, wait for the monitor to register no input, and then plug the monitor in again before it displays anything. I've never figured out a way around the problem - I hate it!
Feb 21, 2008 | Samsung SyncMaster 173V 17" Flat Panel LCD...
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Blank screen
Dec 22, 2007 | Computers & Internet
Computers & Internet Logo
815 people viewed this question
Alun Cox
David Payne
David Payne
