Question about SanDisk Sansa e250 MP3 Player
Sansa e250 won't show up in devices!
Tried to connect, sansa says it is connecting, but computer won't recognize...is it because I don't have a "high speed" port? Please help!
  • Anonymous Dec 24, 2007
    computer wont recongnize the usb
I had the same issue. Brand new Sansa e250 player. My XP SP2 computer would not recognize it. I updated my Windows Media player to version 10. Bingo, all is working now. I previously had version 9. Good luck!
Posted on Dec 25, 2007
Sansa e250 MP3 Player: The computer won't acknowledge that my Sansa E250 ...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ......
May 16, 2010 | SanDisk Sansa e250 MP3 Player
Computer wont recognize Sansa Mp3
There are two connection settings in USB: MTP and MSC. For some reason MTP is the default, but it doesn't connect properly on all computers. Select MSC and plug the player in again, the computer will recognize sansa e250 but not show the driver just yet. It is installing recognition software (just basic drivers - nothing heavy) and it doesnt tell you what its doing until its complete. WAIT FOR IT. Once it is complete you will see both the sansa e250 and the removable memory slot in your "my computer" now you're good to go.
Jul 19, 2009 | SanDisk Sansa e250 MP3 Player
Sansa icon will not appear in source window
Jun 22, 2009 | SanDisk Sansa e250 MP3 Player
SANSA E250 IS NOT RECOGNISED
Jan 28, 2009 | SanDisk Sansa e250 MP3 Player
My sansa e250 mp3 player is unable to connect to computer nor recognized to use .It won`t turn on change the modes
turning on to change modes is your problem. If it's completely dead you may need to replace it or refurbish it. Or if the battery is completely dead plug it in all day until you can get it to turn on. ONCE ON then you can worry about getting it to connect. Try this:
Jan 18, 2009 | SanDisk Sansa e250 MP3 Player
Why won't my Sansa Media Converter recognize my Sansa e250 Mp3 player?
Mine won't read it in MTP mode. It works for me in MSC mode though.
Jun 27, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
Take the screws out of the back, take the battery out then put it back in again. This worked for me.
May 02, 2008 | SanDisk Sansa e250 MP3 Player
Sansa won't recognize!
Did you try changing the USB Connection Type I had to on mine
Jan 07, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
74 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
