Question about Comfort-Aire RAD-243 Air Conditioner
I have just tried to run my ferroli optimax 31c boiler. The boiler fires up, but then displays a d2 message and the radiators do not heat up. Any ideas what causes this problem and how I can solve it please?
  • 9 Answers
D2 is not a fault what that means is delay and 2 refers to CH which means the boiler has gone into standby mode. you need to check that your CH circut is open, there is a filter on the return valve into boiler make sure this is not blocked. If this is blocked the water is just going though the boiler by-pass so then the boiler thinks its up to temp. hope this helps
Posted on May 04, 2010
2 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: ferroli optimax 31c
Here is a link to the manual.It shows fault codes.
http://www.ferroli.co.uk/Product_Documentation/Domestic/Optimax_HE_31_C_Manual.pdf
Please rate this solution.
Posted on Jan 17, 2009
Hello! I've got a Ferroli Optimax HE Plus 31c boiler with the F37 fault flashing.
Try bleeding the air out of the rads then represure system
Sep 17, 2016 | Heating & Cooling
Ferroli boiler optimax he 38 c.Powers up ok,no hot water,no error code.Think its an ignition problem.Heating flame not showing?????
Is there an error code? If not the flow sensor for the hot water could be faulty. Also if you've had a power cut depending which model of Optimax HE you have, you sometimes have to tell the boiler it's a Combi, as they have a generic Pcb fitted which is also used on the system only boilers.
Sep 26, 2013 | HQRP Universal A/C Remote Control...
Ferroli optimax 25 c heating won't come on
Did you ever find out what this was as I have the same problem??
May 03, 2012 | Heating & Cooling
Ferroli optimax he 31c. brand new system will only heat 3 of 8 rads. boiler on 90c will only burn for 15sec then D2 shows and it cuts out. Why??
it is either your pump is not running or blocked [ debris from installation ect ] or your diverter valve is stuck partially open allowing a little water to pass into the heating system [ usually first rads on system ] it runs for a short while and cuts out because your overheat stat is kicking in because of poor circulation [ it is only running around the primarys in the boiler where it quickly reaches the over heat limit ] temp tends to rise approx 1 deg per second a clear indication of circulation problems.
solution GET RID OF THE FERROLI
Dec 22, 2010 | Heating & Cooling
Hi i have a ferroli optimax 31c , hot water works but my heating dont ,it comes on the the heat temp raises to its highiest then cuts of saying A3 AND D2 can you help please
hi had same problem engineer came out and the diverter valve was cloged up sorted it and recomended a system flush plus install a magnet clean whitch picks up debri be 4 it gets 2 the boiler.
Sep 26, 2010 | Quasar HQ2051TH Air Conditioner
Ferolli HE 31C fires up fine, hotwater works, but ...
diverter valve fault most likely. when you call for central heating do you get 3 swiggley lines coming off radiator symbol in the boiler display if you do and not getting central heating then definitely diverter fault
May 20, 2010 | Quasar HQ2051TH Air Conditioner
Ferroli otc settings
this sounds like the boiler is in comfort mode press the eco/comfort button once and eco will be dispalyed on LCD. also check terminal 3 and 4 have no wires on the terminal strip as this is were the OTC is connected to boiler.
May 02, 2010 | Heating & Cooling
Problem with heating on ferroli optimax 31c
d2 is the code symbol for delay after central heating. and is not a fault code.. however if this is coming on then stopping the operation of the boiler then it usually points to a sticking diverter valve.
Mar 28, 2009 | Quasar HQ2051TH Air Conditioner
Ferroli optimax 31c
Jan 16, 2009 | Heating & Cooling
Comfort-Aire RAD-243 Air Conditioner Logo
1,764 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Ottoniel
Tim Whalen
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
