No power rca hdtv modle d52w14
Tv will not power on the button on the tv will not turn it on nor will the remote it has done this before and it was the fuse but now im not sure and i forgot what fuse it was
  • 7 more comments
  • shanneychell Dec 24, 2007
    we replaced the fuse and it still will not come on
    is there anyway i can get a diagram for the inside ofthe tv to show me where all the parts are located and thank you very much
    yx1
    is this it
    the sticker on the back is a pyrmaid with letters vde in the middle
    # is 10756480
    thank you do you know how expensive the part usually is, thank you for the help
  • vlwinfree Sep 01, 2008
    I have the same problem.
    When I try to turn TV on the power switch light blinks on and off.
    Sounds like flyback transformer is kicking in and out.
    Notice black residue on transformer
    Service number F32669yx71
    model f32669
  • jerzeylover Nov 16, 2008
    rca d52w14 im trying to find the power supply cant seem to find it any where can someome help me
    Genius:
  • 1,694 Answers
Check the AC fuse...follow AC cord into set....find fuse in clip.
Be sure to replace with correct amperage value................T.
Posted on Dec 24, 2007
  • 4 more comments
  • Vista Electronics Dec 24, 2007
    Bad IHVT ( Flyback transformer ) = for part # provide Model and
    service number off back of set.....may need # 's off xformer =
    10756 is RCA ##### 10799 is RCA ######.............?? T.
    PS. Does your service # end with BYX1,YX10,YX1 or YX2 ?
    Parts supplier says he now needs the drawing # off the
    sticker on the transformer....evidently there are three different
    possiblities.......flyback transformer is large part with red lead
    coming out of it's top....................T.
    That's it! Need # 's off it = EX 10756..............OR..............10799...........OR..........?
    10756480 Drawing number on part = RCA part # 259296.....T.
    Cost range $ 40.00 to 70.00............Thank you for the Fixya!
For--rca hd52 ---- change 6 / 10 / 20 source caps---- also check solder on source diodes and vert. ic terminals from-- repairs@ get my tv fixed . com
Posted on Feb 20, 2008
What's your problem?i have a rca tv model number d52w14 and it will not turn on just the power button comes on and goes off three times?
The set actually has a "3 strikes and you are out design".
It will try three times and if fails shut the set down.
This model is prone to bad solder connections at and near the high voltage transformer---also to bad parts in that same area which include: the transformer, the sweep transistor near it, and the high voltage splitter block it feeds.
6_12_2012_3_08_16_pm.jpgTypical high voltage transformer that is also called a FLYBACK.
Jun 12, 2012 | Televison & Video
My tv is a RCA D52W14 the green power light comes on then goes off the television takes a long time to turn on
Bad capacitors on the deflection board CP150, CP120 and CP114 very common for that model. You can get the repair kit by that same name from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Oct 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv d52w14
replace the flyback 25296 and the CP150 and CP114 capacitor. You can get the flyback and the capacitors at the following link and they provide free installation instructions with pics so you can easially do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | Televison & Video
D52W14 power button blinks 3 times
Yes make sure you get correct flyback,call UED 1-800-648-6657 see if they have part; also are you sure that is what is wrong?Check capacitor cp150 2200uf 16 v see if it is ok or if it is bad this cap if bad will keep set from coming on,and if it is bad there is 2 other capacitors that need to be replaced also.
Dec 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA tv model D52W14
That is an ITC222 chassis and likely the HOT has shorted, 2sc5588 Rca Part # 259899
You might also check Cp150 2200uf/16v in the 6 volt line, a common failure. Always replace Cp120 330uf/35v & Cp150 2200uf/16v and always resolder Cl031 & Cl032...
There is also a tech bulletin Tv-06003 Dated 12/8/2006 which states:
Replace deformed ribbon cable plastic connector BP005 on the flyback board. This connector is warping or bowing (May Not Even Look Like It) and causing poor connections to the ribbon cable. Replace Rca P/N # 258686.
Try putting pressure on the BP005 connector and turn the set on, you may find the set will now work fine. Replace connector and you may wish to replace the ribbon as well while you are doing the repair!
This set is notorious for failures like this and it is not uncommon to find multiple problems.
Hope this helps!
Bill
Aug 08, 2008 | Televison & Video
Televison & Video Logo
875 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
