Question about Qtronix Computers & Internet
Scorpius Keyboard: Track Ball Doesn't work. I tried cleaning and picking out dog hairs... Is there a "prefered" way to restore track ball function?
  • 14 Answers
SOURCE: when i am pressing my track ball its not responding
Get a sheet of paper or a pad of paper, put your cell upside down so the rollerball is touching the paper... Rub the phone on the paper quite vigerously. This has been a problem for me with many pearls - there is some dust / dirt lodged under the ball which stops it behaving the way it should. You may need to do this in all directions.
Posted on Oct 13, 2008
brambleator
  • 97 Answers
SOURCE: screen shakes have to use track ball
Try turning off the device and take off the back cover and battery. make sure the camera button isnt stuck and try pressing it in a few times...it should kinda make a clicking noise.
reasemble the phone and turn it on by holding the red key for about 10 seconds or so and see if it still happens. if it does, call t-mobile at 1800-937-8997 for a replacement.
Posted on Jan 29, 2009
  • 173 Answers
SOURCE: the track ball on my blackberry 8310 stopped working.
No, but fortunately the trackball is not hard or expensive to replace. If you are technically savvy you can do this yourself. Just purchase a trackball on the internet. The trackball easily comes off if you put a small flat screw driver under the outer side of the chrome ring and pull if off. Let me know if you needed more help. Good luck
Posted on Mar 13, 2009
  • 9 Answers
SOURCE: the track ball does not move up only down when strolling
Try putting a small drop of kitchen de-greaser (Mr Muscle etc) on your finger and rolling the ball with that finger. Do not pour it on to the device, just a small amount on your finger should cure it.
Works for me every time.
David
www.OutdoorInbox.com
SOURCE: Spring placement for scroll wheel
Found an answer with pictures on the site.
Posted on Mar 26, 2009
Unable to scroll to the right allways
the track ball on the curve is very prone to such problems. we frequently use un-clean fingers when using the track ball. the dirt gets collected on the track ball and on the underside. use an alcohol swab to clean the track ball and your problem should get solved.
Apr 04, 2011 | T-Mobile Blackberry 8900CURVE Curve 8900...
Optical track ball is sticking. How clean it and what to avoid?
An "optical" mouse has *NO* track-ball.
If you do have a mouse with a track-ball, then rotate the "ring" that holds the track-ball inside the mouse, to "unlock" the ring. Remove the ring. Look inside the mouse. You'll see two rollers.
Look for accumulated "gunk" in a ring at the center of each roller. Gently scrape each roller, to clean it. Re-insert the mouse. Re-insert the ring. Rotate it, to "lock" the ring into place.
May 19, 2010 | Logitech 931249-0403 Mouse
My track ball scrolls on my blackberry curve but niether the keypad or the track ball works. how can this be soved without buying a new phone?
try cleaning the track ball with a qtip dipped in alcohol or nail polish remover.. It could be that the track ball isn't "reading" correctly due to oil, etc.
Nov 15, 2009 | RIM BlackBerry Curve 8310 Smartphone
Lost function on wireless mouse model kb990w
try to clean your mouse. Open and get the mouse track ball and try to remove the dust that may have accumulated on the bars holding the track ball.
Regards!
Jul 10, 2009 | Micro Innovations KB990W Keyboard and...
My keyboard and track ball do not work. I can not
Buying a new one would be very expensive. Go Visit Cell Phone Repair Center located in Dallas Tx if you are local. If you are outside Dallas you can Mail-in your Phone to them.
For more information visit www.drcellphone.com. They are the best Cell Phone Repair Service Center in the Nation.
Jun 12, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
99039URF keyboard/mice track ball not working
well u can try installing a driver that may help some times also check the batteres on the mice!
May 31, 2009 | Btc 9039URF III Keyboard Trackball...
I've got same problem at first time. After several trials, I could manage to work the whole unit by removing existing USB mouse. Just try to remove every input devices before connect it and follow the pairing instruction.
Good Luck!
Mar 28, 2009 | Btc 9039URF III Keyboard Trackball...
Track ball
never remove the ring and clean the trackball unless your phone isn't under a warrenty. Run the app loader on the phone if it doesn't work you'll have to replace the phone through your phone company if you have a warrenty. IF you don't have a warrenty you are free to try and clean it or replace the trackball and ring, they are amazingly cheap. check out amazon.
Dec 28, 2008 | RIM BlackBerry Pearl 8100
Blackberry keyboard problem
Hello everyone, this problem is cause by humidity, it is solve leaving your blackberrry rest for a while without battery in a dry place. Blackberry has not mention it but it happens a lot, and it only needs a little quantity of your own sweat to put you in troubles.
Dec 28, 2008 | Microsoft Office Outlook 2003 for PC
Pearl roller ball
It might be a case where the track ball has some dirt or debris underneath it. First, turn the device off. Next, press down firmly on the track ball while at the same time rolling it in every direction. Hopefully that will knock loose any debris. Another tip to try is to wet your thumb with a little water and do the same thing.
If those two options don't work, you may try taking out the track ball and blowing out the slot with some compressed air. Below is a link that shows how to remove and clean the track ball:
http://www.blackberryforums.com/general-8100-series-discussion-pearl/113889-how-clean-trackball-your-pearl-8100-a.html
Oct 03, 2008 | RIM BlackBerry Pearl 8100
Computers & Internet Logo
22 people viewed this question
Top Qtronix Computers & Internet Experts
David Payne
David Payne
Are you a Qtronix Computer and Internet Expert? Answer questions, earn points and help others
