Question about Nuova Simonelli Mac 2000 Espresso Machine
The auto fill led light flashes and the boiler shuts down. after about 15 min and doing nothing to the machine it restarts itself and works fine. it does this 2 to 3 times a day
    President:
  • 1,618 Answers
The machine cannot get water in a timely manner, check the water filter is there is one on the unit it may be time to replace it, and second check the level probe it may need to be cleaned also.
Posted on Oct 07, 2009
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
A/C runs fine for 7-8 minutes, then shuts off
Refrigeration problem. Must be a bad thermostat.
May 11, 2013 | Sharp AF-S120FX Air Conditioner
Combi boiler will not fire up on heating or hot water. pressure gauge reads approx 2.1 bar red light lit on panel
Hello
The water pressure should be 15 to 12 psi.If your at 2.1 there is a problem with your auto fill valve.
Which means the boiler is shut down on low water.
The auto fill valve is connected to your incoming cold water from the home,shut it off and check the screen inside for dirt or rust,you may need to have another one installed.
Feb 28, 2011 | Heating & Cooling
Loss of pressure in boiler, no obvious leaks, water pressure switch changed plus pressure release valve
Check that your make up water is on.
Make sure your fill valve is working but it sounds like it is not. Your min pressure should be 15 psig. on the boiler. Fill valve will maintain a15 psig on the boiler. Water and pressure does get out of the boiler when radiators are bleed. When fill valve is not working people will keep bleeding the radiators trying to get heat but only lowering the boiler pressure with no water make up.
Make sure your boiler is getting water and has pressure when running.
If it isn't...SHUT DOWN and have a professional look at it.
Pressure relief valve is factory set ta 30 psig and opens when pressure is above 30 psig. This is a safety valve.
Feb 17, 2011 | Heating & Cooling
No hot rads down stairs boiler comes on 3 miniutes then of again
Hello
By your post im guessing you have a 2 story house.
Have a look at the boiler,water pressure guage.Should be between 12 and 15 psi 140 to180.f when running.
If its above or close to 30 psi the relief valve will open to let off the pressure,we do not want this to happen normally.
If you have high water pressure at the boiler you will need to go to the highest radiator or any one on the second floor and open the bleeder.Looks like this
http://www.ourfixerupper.com/wp-content/uploads/2007/11/cast-iron-radiator-02.jpg
Carefully open it slow into a bucket,let air out until you get a steady stream of water.Do this to all of the radiators,idealy using a bleeder key or needle nose pliers.This may take some time.
Once we can assume all the air is out,check your water pressure again should be 15 to 20 psi.If you have no pressure then your auto fill valve is bad.If you have 15 to 20 then proceed.
Raise the temp of the t stat to start the boiler.6 degrees above whatever the room temp is.
If you still are having problems your t stat may be faulty.If your boiler is at 15 to 20 psi 140 to 180.f and it still shuts down after 3 min your return pump may be bad.
Hope this is helpfull
Dec 21, 2010 | Heating & Cooling
Filling the boiler tank
Sounds like the auto fill circuit is not engaging or is getting blocked, usually when all the lights in front is flashing, machine is saying it is not getting water.
Jul 06, 2010 | Astoria Argenta AEP-2 Coffee Maker,...
It shuts itself off
The SHARK ELECTRONIC Iron is equipped with an electronic auto-off. The electronic auto-off switches the iron off if it has been left standing unmoved in any position (sideways, flat or upright) for approximately 7-9 minutes. A red light on the LED display panel will flash when the iron switches itself off. (Fig. 7) To switch the iron back on, just shake the iron side-to-side several times.
Jul 31, 2009 | Euro-Pro Shark GI490 Iron
The Home Cafe machine will not pump water
It's dirty or has scale / deposits. Use a paper towel to draw out as much water as you can from the "hole that leads into the machine" - then fill it with clear, distilled vinegar and let that sit for about 15 minutes. Fill the resevoir with a vinegar / water mixture. After the 15 minutes, run the vinegar solution through until the resevoir is empty.
After you do that, you will have to run several tanks of water through, to get the taste / smell of vinegar out, but the machine will work fine again.
Dec 07, 2008 | Black & Decker Black&Decker Home Cafe...
Saeco Primea Cappuccino Ring--stuck on "boiler filling" mode!
Hello, I had the same problem, therefore the machine has gone to a repair centre. The problem is caused by a mechanical switch in the machine, that doesn't work properly. To repair it you've to open the machine completely, but that’s not easy. Because there is nothing broken you’ll should have warranty because it is a production failure. The solution in my case was to heat up the switch and push it a little together so that the contact works properly. It is the switch that you hear when you turn on the machine.
Oct 29, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Zanussi IZ12 Pumps, then Pause LED is flashing.
hi i had the same fault, the machine would go onto pause after a couple of seconds.. after nearly a full strip down of the machine and checking the obvious i found there was carbon dust on the pcb which was causing tracking (the circuit board at the top of the machine). The pcb looked like it was burnt out, but after a quick dust down to remove the carbon and refitted back into the machine it worked fine. HTH
Jul 30, 2007 | Zanussi IZ12 Front Load Washer
Nuova Simonelli Mac 2000 Espresso Machine Logo
148 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
rhodesworks
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
