Question about Ricoh Aficio 1035 Copier
Aficio 1035 i am getting error sc818. i want to fix it so wht is the fastest solution
  • 417 Answers
Not sure what SC818 is as not in my manuals please try the following.
Entering and Exiting SP mode
1. Press the Clear Mode key.
2. Use the keypad to enter “107”.
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
To enter the Normal Service Mode:
Copy SP On the touch-panel, press Copy SP.
Once in the service mode turn the main switch off located on the left hand side of the machine wait 5-10 seconds then switch back on. This should get the machine working. Hope this helps
PLEASE DO NOT ADJUST ANYTHING ELSE WITHIN SERVICE MODE AS CAN DAMAGE MACHINE OPERATION)
Thanks J
Posted on Dec 26, 2007
I have a 1035 and getting the code sc402. we just have the tech do a pem and they changed several parts and the code remains
Posted on Feb 09, 2008
Ricoh aficio 1035 copier gives error code 390
TD sensor defective
TD sensor not connected or disconnected damage
Poor connection between the TD sensor and IO board
IO board defective
Toner supply defective
* Insufficient toner in developing unit
Apr 16, 2014 | Ricoh Aficio 1035 Copier
Ricoh 1035 error sc 818
hi
this error happened when :
Incorrect Function DIMM installed in Slot #2 on Controller PCB. (Slot #2 is for PostScript Option only) so you can:
Reload System Firmware.
Replace Controller PCB
for fix that.
Oct 25, 2012 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 gives ERROR CODE SC322. CANT TAKE ANY COPY OF IT, PLZ HELP
that mean laser unit have proplem synchro 1 can't detect do with me 2109 and 2108 via sp mode if it's not work out change it
Jan 14, 2011 | Ricoh Aficio 1035 Copier
Fusing lamp of my Ricoh Aficio 1035 was broken 230V 650W red
Measurement the countinously of the heater lamp,check the thermistor and thermofuses nad reset the error code.
Sep 05, 2009 | Ricoh Aficio 1035 Copier
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
How do i set aficio 1035 to factory default
SC352 Indicates ID Sensor/Pattern edge detect Error 3. If its a color machine, then it's a Magenta TD ensor failure.
Usually If you need to change the developer roller you should change the developer as well. Once that is done, then you go into service mode and calibrate the developer and initialize the TD sensor.
Did you change the developer?
Aug 02, 2008 | Ricoh Aficio 1035 Copier
Ricoh aficio 1035
It needs a firmware update or re -write.
Feb 07, 2008 | Ricoh Aficio 1035 Copier
Our New Machine
Call the people you bought it from.
If its new they should set it up and provide all the needed information.
Dec 05, 2007 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
1,019 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
