Question about Maytag Dryers
We have a maytag dryer that's about 20 years old. when we start it, it makes a shuddering type sound. then when it gets rolling, it sounds like a rock caught somewhere, or maybe a piece of belt that might be slightly torn. it has four screws in the front. it that the way in to see what's going on?
I didn't fix it. i was under the inclination that this was a free advisory thing on this puter. i can't afford anything coz i'm on a fixed income. somehow, someday, i'll try it myself. sorry about bothering you folks.
Posted on Oct 08, 2009
We have a Maytag gas dryer that is probably 15 to 20 years old. It still works fine, but it makes a noise when it fist starts up. Sort of like a grinding sound .
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 27, 2010 | Maytag Dryers
Dryer won't start-Get a buzzing sound when pressing Start
Sounds like motor cost any where from $100 to $150
maybe a little cheaper if find the right place
Apr 24, 2010 | Dryers
Dryer makes wobbling noises when starting
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 15, 2010 | Maytag MED5707TQ Electric Dryer
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
15 year old Kenmore dryer not working
Sounds like you thru the breaker. If not, it is the door switch.
Jul 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Apr 04, 2009 | Maytag Dryers
Dryer makes rumbling sound when starting
If you remove the front cover and access the blower fan and see if it is still tight on the shaft. if it isn't it makes a rumble sound when started due to vibrating and after a while it makes more noise as it goes. Now I removed the fan and placed a shim in the flat area and matched the flat area of the shaft and replace it back on the shaft and it should solve it.
Mar 21, 2009 | Maytag MDE2600 Electric Dryer
Clunking sound on dryer
Remove the front panel and check the blower wheel attached to the motor.
It may need replacing.
Possibly lint and debris blocking it.
Feb 21, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Dryers Logo
50 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
