Question about Refrigerators
I have a Tri-Temperature Honeywell Water Dispenser model number 87344 and I need a replacement cap for the drainage spout. Where can I order one?
peyton32034
  • 410 Answers
SOURCE: Water spout replacement
this is a surprisingly easy repair that you can do in about 30 minutes.
  • first remove dispenser cover: there are 2 slots on the very bottom of the cover insert flat tip screwdriver and carefully pry it off. then you should be able to disconnect a wiring harness and lay the cover to the side.
  • next move switch console out of your way: you will either have 2 screws or 2 thumb latches on either side. you may need someone to hold this out of your way for the following steps.
  • we need to disconnect the incoming water line down at the bottom hinge: remove kickplate and find the water line you should find a connector. while pushing the tube into the connect push down on the collar then pull the tube out of the connector.( you will most likely get a little bit of water when the tube pulls loose.
  • back at the dispenser: find where the tube comes out and remove any retaining screws, then gently pull the entire tube up and out of the door.
  • now do everything in reverse to finish up: the tube will push abck thru. when you get back to the hinge the tube may hange up I use a very small screw driver to line the tube up to come back thru the hinge.
  • whne you reconnect the tube at the grille make sure that the tubing seats all the way to prevent any leakage
Be surre and be safe by unpluggin the unit before you perf any type of repair water and electricity dont mix. good luck Peyton
Posted on Jan 31, 2009
SOURCE: Water dispenser
The lever on the outside water dispenser is broken, how can this be fixed?
Posted on Apr 08, 2009
  • 112 Answers
SOURCE: I have a stainless steel Frigidaire side-by-side
the front cover will come off. if you dont see any screws then it WILL unsnap. look for a slot on the top or bottom of the cover. good luck some of them can be nasty
Posted on Oct 29, 2009
BIKER T
  • 909 Answers
SOURCE: I have a Kenmore side by side model number
You have a defrost issue.Occurs when door is accidentally left open.(even slightly for a period of time). You need to do a proper 12 hour defrost to resolve this problem.(Fan is jammed due to ice build up)
Posted on Nov 13, 2009
SOURCE: I have Kitchenaid Model KSRG25 and need water filt...
If it is the model KSRG25FK, the following filters will work:
4396510 (best filtration)
4396508 (standard filtration)
Posted on Jun 09, 2010
I took the spout of the smoothie plus 600 apart and can't put it back together
When you say you took the spout apart and can\'t put it back together its only 5 total pieces. The spout, the spring, the handle, the dispenser (rubber insert with plastic stem) and the threaded cap which holds the dispenser and handle to the spout.
If you can\'t get the handle to re attach, that does not surprise me. This is very poor craftsmanship. The plastic nobs that hold the handle onto the dispenser tend to break off.
If this is your problem, you can either, buy a new one for $5 plus shipping depending on where you live OR
You can fix the part that broke.
All you would need is a Drill, a small piece of number 14 copper about an inch long and same size drill bit. Drill the handle as close to center where the plastic molded nobs were located that either broke off or worn away. Then drill with the same size drill the stem to the dispenser which has the rubber stop attached. Drill this as close to the top of the stem where the nobs would snap in to hold the handle in place. You are basically making a pined handle, which will outlast the quality of this blender.
NOTE: You want to use a drill bit about the same size as the number 14 copper wire.
Then with one hand hold the threaded cap with the dispenser placed into position through the hole, be sure to put the spring in, small hole to the bottom of the rubber dispenser, pushing the spring and dispenser up through the threaded cap, attach the handle by putting the piece of copper wire in your hole which will connect your handle to the stem of the stopper. The copper should be cut no wider thent the width of the handle, if it sticks out a tiny bit, that\'s ok. The plastic cap will simply be carved out where the copper rubs against it. After that, simply screw the handle cap back onto the spout and screw the spout back onto the blender making sure the two washers are still on the pitcher.
All in all, for someone who is handy, this should take about 10 minutes. I would rate it about a 5 out of ten for difficulty simply because you have to drill straight and centered in the handle where the nobs were. Other then that its easy and if you can have someone help you put the pin in place, it would also make it easier.
If for some reason the rubber stop does not seem to go back into the spout, make sure the rubber didn\'t role up onto itself. Also if the spout drips, you didn\'t either put the spring back in or you didn\'t drill at the top of the plastic stem but some where in the middle, simply ream the hold towards the top where the plastic nobs would stop. Its a square reseated area in the stem. Looking at it you should be able to tell.
As for the spout instructions, you can download the pdf manual at the manufactures website: http://westbend.com/spl6white-smoothie-maker-plus-600.html
Hope it all helps, Its worked for me!
Dec 31, 2012 | Back to Basics 600 Smoothie Plus Work Top...
Water dispenser leaking
water dispenser leaking due to water valve in rear needing to be replaced if you need a part number of the valve that you need to order for your machine message me back.
Thank you
Rick
Nov 24, 2011 | Frigidaire Model: FRS6HR4HB
Ge portable air model APH1GAAG1. Can't find a the water bucket. Has been at 83f for past 2 days. The spout in back leaks water. Home depot suggested I put the unit on small table and bucket...
Call GE customer support at 1-800-626-2005 or... go to this link:
http://genet.geappliances.com/DocSearch/Dispatcher
and enter this model number APH10AA
The manual file is 1.28 mb.
This is straight from the manual page 6:
Drainage/Routine Maintenance
This air conditioner produces water during normal
operation. The unit should be drained if it is not
going to be run for an extended period of time.
The unit should also be drained prior to storage
at the end of the cooling season.
To drain the unit, follow the instructions below:
1. Unplug the power cord and roll the unit to a
drain or outside.
2. Pull out the drain cap and allow water
to drain from the unit.
3. Securely replace the drain cap.
Thanks for choosing FixYa,
Kelly
Jul 21, 2011 | Heating & Cooling
I've got a side by side Whirlpool refridgerator. The Water Filter status light is not indicating. What could be the problem and solution?
There are several pages that explain dispenser programming. This is on page 10 of the owners manual.
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> sea_breeze_132.jpg Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
Apr 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The inside water spout on this refrigerator stopped dispensing water
Checckwater pressure.The 1/4" water supply line should deliver at least 9 ounces of water in 5 seconds. If not, the water pressure is low. Make sure the dispenser is notlocked. Some models have a lock feature that deactivates the dispenser andcontrol buttons. The lock button is located on the dispenser front cover.This feature controls unintentional dispensing. Press the"Unlock" or "Locked" button to reactivate the dispenser andallow dispenser function. You may need to hold the button for2 to 3 seconds. A clogged or incorrectly installedwater filter will reduce the water flow to the water dispenser. Check for aproblem with the filter by removing the filter and operating the dispenser. Ifwater begins to flow, then the filter is either clogged or incorrectlyinstalled. A clogged filter will need to be replaced. Thanks.
Feb 03, 2011 | Amana ARB2259CS Bottom Freezer...
Want to know when and how to replace water filter on a ge side by side refrig
The water filter status light or indicator, present on some models, will help you know when to change your water filter. The light, or indicator, is located either on the temperature control panel in the refrigerator compartment or on the dispenser control panel on the freezer door.
The indicator will be one of two styles.
If the indicator is a light or series of lights, the light will change from green to yellow. This tells you that it is almost time to change the filter. It is recommended that you replace the filter when the status light changes to red or when water flow to your water dispenser or ice maker noticeably decreases.
If the indicator resembles a stack of bars, the bar height will decrease and the status display will change from "Good" to "Order." This tells you that it is almost time to change the filter. Replace the water filter cartridge when the water filter status display changes to "Replace" or when water flow to your water dispenser or ice maker noticeably decreases.
If a filter status light/indicator is not present, the filter should be changed at least once every 6 months. Your filter may need to be replaced more frequently depending on your usage and water quality.
If the water flow to the water dispenser or ice maker noticeably decreases before 6 months have passed, you may need to replace the water filter cartridge more often. Decreased water flow is a sign that the filter is clogged and needs to be replaced.
If the filter is clogged and you are not able to immediately replace it, remove the filter so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing or low ice production. However, in order to have filtered water, you will need to install a new filter.
The filter status display will help you know when to change your
water filter. When the display reads 10%, order a new filter. It is
recommended that you replace the filter when the display reads 10% OR when water flow to your water dispenser or ice maker decreases.
Step 2
Step 3
Step 4
Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter.
Step 5
Step 6
Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed.
Step 7
Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Step 8
Flush the water system. Use a sturdy cup or glass. Depress and hold the
water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat this process until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever. Hold down for 5 seconds and then release for 5 seconds. Do this on/off process for about 2 minutes. This will flush air from the filter and water dispensing
Hope this helpout in changing the water filter......
Aug 10, 2010 | GE Refrigerators
Water dispenser spout broken
we had the same problem. My husband cut a flexible straw to the length he wanted, and crammed in in the hole. works great !! saved between $ 35.00 and $55.00 (labor was free)
Aug 06, 2009 | Whirlpool GS6NBEXR Side by Side...
Part needed
I finally found contact info for the maker and I have a number to call in Canada to order the part.
May 29, 2009 | Whynter FX-6SB Free Standing Hot & Cold...
No water at dispenser
apply hair drier to spout and surrounding area for a minute every ten minutes , after about an hour the ice that has formed will be loose enough for the water to come out of spout
Mar 28, 2009 | Hotpoint HSS25GFP Side by Side...
Drips water out of Ice maker spout
There is a valve that controls the flow of water at your door. Take the front console off and take it out. There will be wires attached to the console for your water/ice control so make sure you either tag or write down where these wires go. Then replace the valve you will clearly see that opens the water up. Take down your model and serial number down and go to your local appliance dealer so they can cross reference the part number OK? Randy B. A.I.R. Appliances
Feb 27, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
228 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
