Question about Fisher and Paykel E522B Stainless Steel Bottom Freezer Refrigerator
White flocculent precipitate occurs when ice cubes
White flocculent insoluble precipitate occurs when ice cubes added to water. Water from dispenser on door is clear with no precipitate. Fisher Paykel says to increase temp of freezer compartment. Tried, same problem continues. Repairman clueless as to cause.
2 Suggested Answers
SOURCE: Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Posted on Oct 04, 2008
Ice machine not working
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
Ice maker not functioning or producing ice cubes
  1. Check connections
Check all hose connections to ensure that water is being transmitted through your appliance and there is no frost build up.
  1. Feeler arm
Double check to make sure your feeler arm is not stuck or that ice cubes are not blocking the feeler arm's motion to produce more ice.
  1. Ice maker heater
The heater may be stuck on. The heater comes on for 1-2 minutes to break cubes free from mold. If the heater stays on too long ,the ice maker will get hot and stop making ice. Carefully feel around the ice maker mold; if it is hot to the touch, the heater is on. This indicates that the ice maker is jammed, and it is better to replace ice maker than to try and repair it.
The water valve supplying the ice maker is a key component of the ice-making system. When the ice maker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. When this part is not operating correctly, a repair/replacement part may be needed. Refrigerator Repair Help Troubleshooting and Parts
Aug 17, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
The fan at back does not come on. The fridge make a clicking noise, The fan tries to run... Also it does not pump water anymore. It does make ice
  1. Dispenser switch
  1. Door switch
  1. Feeler arm
  1. Ice maker heater
Aug 16, 2014 | GE GSS22JER Side by Side Refrigerator
Whirlpool side by side GD27DQXFW01; ice cubes are not dispensing
We will need to check the voltage at the auger motor while depressing the dispense switch. If all the other features work on the dispenser panel while I would consider checking the voltage going to the motor. Some auger motors are in areas where water causes the voltage to be shorted by constant moisture. We will need to remove the panel and simulate what you have done on the outside but this time we need to see if the voltage has been altered or if the auger motor itself is defective. Sea Breeze
Oct 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Whirlpool refrigerator icemaker does not dispense ice cubes
I don't think the ice maker liked the water being turned off. Usually there is an arm that will raise up to a catch position that will turn the ice maker off. I hate to say it, but ice makers are best to replace than repair. The internal parts are difficult to change, and with a new one you will have no problems. They are not too hard to change. Shop around for a good deal, I use e-bay.
Apr 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Floating bits in Whirlpool fridge-freezer crushed ice water
Ice cubes freeze from the outside, so the center of the cube is the last to freeze. Ice is pure water, only H 2 O, so as the ice cube freezes, all of the dissolved minerals are pushed to the center. Near the end of the freezing, there isn't much water left in the center of the cube, so these minerals become very concentrated, and they form the "white stuff" – the technical name is precipitate. The hardness minerals that cause the "white stuff" are not toxic.
Mar 20, 2009 | Freezers
Particles in ice cubes
Most new water/ice systems have break-in procedures in the manual, including flush a couple gallons of water through the water dispenser and disposing the first 24hrs of ice.
Are the particles present in the filtered water before adding ice? If so, you can probably assume the contamination is from the water tank so you should flush several gallons of water through the system to get rid. If the particles are present after adding ice, try pulling out the ice bin and dumping the ice.
Dec 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Icemaker won't dispense whole cubes, only chopped ice
Hello chitwnchk1
Welcome to Fixya,
You said,It chops ice when dispensing but won't just dispense whole cubes.
Any suggestions on how to fix it?
1. If the cubes dispense, but not whole cubes, there is not a enough water pressure.
2. r there is a restriction in the water line to the ice maker.
3. OR the fridge may not be level.
4. Is there a water filter and has it been Changed in the past 6 months?
Here are 4 reasons mentioned in the repair manual.
Shutoff arm in the off position
Ensure the shutoff arm is down and not in the raised position. If in the raised the position, the ice maker is in the off position and will not cycle.
Faulty Harvest Thermostat
There is a thermostat inside the ice maker that will close when the ice maker mold reaches the proper temperature. If the thermostat is not closing, the ice maker will not cycle.
Freezer To Warm
The ice maker will not cycle if the temperature in the freezer in not below 12 degrees. Ensure proper temperature in freezer.
No water getting to ice maker
The water inlet valve is the control device that allows water to enter the ice maker. It is energized during the last 5-8 seconds of the harvest cycle. During this 5 to 8 second period, there should be 110v across the two wires connected to the valve . If there is power supplied to the valve and the valve does not open to allow water to flow, the valve is defective.
However, if power is being supplied to the valve and water is flowing through it freely, it could be that you water supply line or inlet tube have frozen solid. These can be thawed with warm water or a hair dryer.
Let me know how it goes and what you found!
Thank You , Huuuum
Please remember to leave a rating!
Oct 18, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
Fisher and Paykel E522B Stainless Steel Bottom Freezer Refrigerator Logo
76 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
