Question about Jenn-Air 30 in. CCG2423 Gas Cooktop
Burner replacement igniter replacement
    President:
  • 1,304 Answers
Call 1-877-477-7278
ask for part number
AP4088999
17.00 in stock
Posted on Oct 08, 2009
Have trouble starting gas burners on nobel fse90-1. Is there a trick to starting the burners. I need serious help before I go mad!
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | Cooktops
On our 6 burner gas coocktop, the right two burners don't light
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 10, 2010 | Thermador SGS36GS Gas Cooktop
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
Igniter doesn't spark on only one burner
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
Jan 13, 2010 | Miele KM360GSS 23 in. Portable Gas Cooktop
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
Viking cooktop gas unit ignition clicks on all burners when I use
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
Intermittant/interrupted ignition device
The problem here is that the port holes in the burners are probably clogged. Clean ALL burners by taking a toothpick and unclogging the port holes. As for the position problem, if you have independant igniters, as some models do, you may need to replace the igniter. Remove knob and remove igniter,(white rectangular item with two wires) remove wires and replace.
Sep 08, 2008 | Thermador Cooktops
Jenn-Air 30 in. CCG2423 Gas Cooktop Logo
148 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
