what the problem is your pc is displaying a resolution you monitor cant display most likely its to low do you have a 2nd monitor you can hook up to set resolution Once you have done that set resolution that your new monitor can take and then hook up . when i moved from a 19inch monitor which ran at 1280 x1024 to a 32 inch samsung 1360x768 i had same problem as my screen cant display that res so set to what ya monitor can do .If you dont have a second display keep connected turn pc off with only your sharp cable in and it should turn on once into windows
Was this helpful?
Yes
No
Popular Solutions for ATI RADEON HD 2400 PRO Graphic
When my ATI drivers are installed on my computer to get HD signal the color Red stops coming up....
(More)
When my ATI drivers are installed on my computer to get HD signal the color Red stops coming up. When the ATI drivers are uninstalled the VGA signal works and all the colors come through but no longer get HD signal to monitor. Have downloaded all the updateds for both the Acer Flat Panel monitor. And the latest updates to the Raedon X4350 that i just purchased a week ago.
nie mogä? zainstalowaä? programu do karty graficznej ATI his radeon 9550 brakuje...
(More)
nie mogä? zainstalowaä? programu do karty graficznej ATI his radeon 9550 brakuje mi VGA card
I have the exact same problem as yours. I tried to so many solution, it does work sometime. I tried...
(More)
I have the exact same problem as yours. I tried to so many solution, it does work sometime. I tried to plug in the default VGA cable to the on board graphic, it works perfectly. But when I swap back to the Radeon 2400 from the DVI cable, it happens again sometimes. I would like to resolve this problem, it is so frustrating.
ati radeon 4670 video card is stating issues with sketchup pro 7. What issues is the software having...
(More)
ati radeon 4670 video card is stating issues with sketchup pro 7. What issues is the software having with this graphics card and can it be fixed. This is the best video card that this studio xps 16 has.
