Question about Samsung LNT3242H Television
My lnt3242h will not turn on. When it is plugged
My lnt3242h will not turn on. When it is plugged in the red light stays on solid. It flickers when functions on the remote are pressed but the television will not turn on. I have downloaded a service manual but cannot compare what is on the schematic diagrams to the actural pcb's in order to follow the trouble shooting guide. Any suggestions?
  • 1 more comment
  • 710smk Oct 07, 2009
    No sound at all. There is no indication that anything is functioning - the screen is black. The red light flickers as if it is receiving signal from the remote but nothing else. I do have a multimeter - the manual is on the way.
    Capacitors are not identified this way on the pcb. ie on the power supply they are like cm851, cm852 or cx801s or cy801s. Also the main pcb in my tv does not look exactly like the image - heat sinks are different - some capacitors are different etc. part# on my pcb is bn44-00155a. i have googled this number and found exact pictures but no other info.
    The model number in blue script on the side of the cover is LNT3242hx. The picture you have posted is exactly the same as the pcb in my television. The first five pins of both connectors are labeled 24v the next five are gnd. All ten pins labeled 24v have 1.247vDC. Thank you for the help.
    Sergeant:
    Champion:
  • 208 Answers
The problem is probably a bad power supply or shorted inverter board. Most people just swap the whole board rather than going component level. I found a power board pretty cheap on Ebay: http://cgi.ebay.com/Samsung-LCD-Power-Suppy-BN44-00156A-LNT32-5-Models!_W0QQitemZ120455726458QQcmdZViewItem, and a really cheap inverter board: http://www.pchub.com/uph/model/0--11344-0-1/HS320WV12-parts.html
Those are the two most often failed parts.
Posted on Oct 08, 2009
  • 10,594 Answers
Do you get sound of TV programs, can you change volume level while screen is black? Let me know to find out possible cause of problem and service manual will help me to guide you properly. Email manual copy at welcomejee@yahoo.com and let me know do you have multimeter to test/ measure output volts on power supply board? Thanks.
Posted on Oct 07, 2009
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Oct 07, 2009
    Thanks for schematics, Please check 13V volts at capacitor C103,,, 5 volts at C113 and 12 volts at C117 on power supply board. All above capacitors (Cxxx) are mounted on power supply board.
    Power supply board LN-T3242H image is shown below taken from service manual.
    Please go through Troubleshooting chart (no power) in service manual that has few steps to confirm either power supply board is working or need to be replaced.
    Thanks.
    other info.
    Is it Samsung LN-T3242H TV? above image is taken from service manual.
    BN44-00155A image is similar at Part Store.
    Can you please post snap of that board in your TV to identify what kind of board is that.
    Please check volt written on output connectors on power board and take out reading with multimeter. Let me know what volts are missing or goes down.
    Thanks.
    Does it look like following board?
It does not seem to be making a solid electrical connection
if you have acess to another cord try that make sure connections arent corroded
Dec 03, 2013 | Dolphin Maytronics Advantage
Plantronics audio 995H wireless headset not charging when plugged into computer. It does not show a red light for charging. When turned on it stays blue for several seconds then flickers red for 2 or
38cafd7a-6060-4717-bc4f-b4db91cc266a.jpgI recently fixed my 955 headphones... it's probably not going to be attempted by most folks, but it saved a great set of headphones from being tossed and replaced.
Basically you need to remove the right side padding and take out the 3 screws. This gets you access to the battery. The battery is a standard 3.6V lithium battery. Pretty much the same that is in most cell phones and many small toys. You can simply replace the battery with something like:
http://dx.com/s/3.7v+li
Or... here's what I did... add a lithium USB charger to the battery.
http://dx.com/s/li+arduino
Now, if the battery dies I can plug it into USB and the phone will work while it charges.
Nov 12, 2013 | Plantronics .Audio 995 Digital Wireless...
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
Tv won't power on
Check power fuse first, cheapest fix, if no power light comes on at all. Ballast (ballast booster) next possibility, if power light stays red, but cost is about $400 P&L. Finally, the bulb, if power light comes on, stays green, but no picture. Get the manual for your specific model.
Nov 14, 2009 | Samsung LNT3242H Television
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Red Light/Blue Light I/O Error
My nx2 is working again after having the "red light/blue light/I/O Error" problem. I just:
1. turned off my computer
2.unplugged the HD,
3. took out the HD from the enclosure and plugged it back into the enclosure,
4.started up my computer without the HD being plugged in
5. after my computer had been on for a minute, I plugged the HD in and my computer recognized it and had the proper mixture of red and blue light coming from the HD, indicating it's working properly.
Aug 26, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Jul 12, 2008 | Jazz DV-179 Digital Camera
Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Dec 17, 2007 | LG 42PX4DR 42 in. Plasma TV
Televison & Video Logo
2,090 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
