Question about Cameras
DSC-W110 = at switch on, lens motors in and out and diplay says "turn off power and turn on again". Cannot progress beyond this point, battery OK.
Solved with a post from Chzaib who recommended airline treatment of lens segments to dislodge dust/grit followed by slapping cam in palm of hand to recentre lens assembly. Thank you for the help Chzaib.
Posted on Oct 08, 2009
My sony Camera (DSC -W110) is showing "Turn the power off and on again" while switch on the camera,it appers again & again after switching the camera on and off
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
Also tryinitializing the Cameraif you're able to access the Menu items on the Camera. The Initialize option will be available under Setup or Main settingsSub Menus.
If the issue persists again, service is required. Please click hear to locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Mar 21, 2011 | Sony Cyber-shot DSC-W110 Digital Camera
Sony DSC-W110 Hi, my camera was workign fine, plugged it into the computer to take some pictures off and the camera froze. Powered the camera down powered it back up and it froze again. Powered it down...
First, stop plugging it into the computer. Next, remove the card and battery, press all the buttons, leave it alone for 20 minutes, insert the card and then the battery (which I'm assuming is fully charged), turn it on. To download your pics in the future, use a separate card reader.
Apr 25, 2010 | Sony Cyber-shot DSC-W110 Digital Camera
Camera not switching on
I believe there is a lens error, usually that message appears when the lens are stuck or not working.
Turn the camera ON by pressing the "play" button (to see images only) and if the camera turns ON with no problem, then the problem lies on the lens.
you can send the camera for repair or buy a new lens set from ebay, they go for around 30 dollars, but you have to be familiarized with cameras and very careful in order to install the new lens.
hope this helps.
Feb 02, 2010 | Sony Cyber-shot DSC-W110 Digital Camera
Showing turn the power off and on again.
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu under Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Oct 19, 2009 | Sony Cyber-shot DSC-W110 Digital Camera
Sony Cybershot dsc-w110 won't turn on ?
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help++++Thyanks for usi9ng FIXYA
Sep 28, 2009 | Sony Cyber-shot DSC-W110 Digital Camera
Error message E 91 01
flash error for sony cybershot dscw55 ERROR CODE E:91:01 1st go to SETUP MENU then select the toolbox icon 1 then select "INITIALIZE" press ok, master reset then it goes back to normal
(DOWNLOAD & SAVE PICTURES BEFORE MASTER RESET AND KNOW THAT YOU WILL HAVE TO SET UP TIME&DATE)
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Jul 06, 2009 | Sony Cyber-shot W110 Digital Camera
Sony Cyber-Shot DSC-W110 'Turn power off and on again' repeated
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Jun 01, 2009 | Sony Cyber-shot DSC-W110 Digital Camera
Won't turn on fully
Check the batteries. Recharge the batteries fully and try again.
Feb 14, 2009 | Sony Cyber-shot DSC-W110 Digital Camera
Cameras Logo
182 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
