Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Disposal won't drain
I've got a badger 5 plus that's about 9-10 yrs old. In single drain sink, it's draining water VERY slowly. When I turn on disposal, water bubbles but doesn't flow down. Blades push smoothly with my hand. I've taken apart trap and pipes are clear. I disconnected unit from main plumbing to find clog and double check it's not a pipe clog deeper in. Put allen wrench into hole in bottom and turned easily a bunch of times. Tried the reset button. Now what?
  • 34 Answers
Sounds silly but try loading it with ice and turning it on if there is debris in it the shards of ice will help to clean it
Posted on Oct 10, 2009
Insinkerator disposer causes water to drain slowly from sink
The pipe from the disposer outlet to the sink drain Tee is partially plugged. Remove the drain pipe from the disposer to clear the obstruction.
Apr 11, 2014 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Badger 5xp & a double sink. When I turn the disposal on I get a small eruption of water, air and disposed of debris from the other drain.
Take apart the tubular drain pipes beneath sink and clean out everything.
Take photos before removing pipes so parts go back together easily.
Loosen 2 nuts on trap, and trap falls loose.
Remove 2 bolts/screws and remove tailpiece from side of disposal.
Then run snake down drain line leading away from sink to make sure blockage is removed.
I wrote ez disposal steps that give tips on reconnecting tubular drain pipes:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Sep 24, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
BADGER DISPOSAL UNIT 5-81 SEEMS TO WORK, IT'S NOT STUCK BUT THE WATER WON'T GO DOWN IN THE SINK. ANY SUGGESTIONS.
Clean out the p-trap and tubular drain under the sink:
I wrote ez disposal replacement steps that cover how to take apart tubular drain pipe and put it back.
Jun 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Our disposal is full of water, and will not drain down. we had orange peels in there, which seem to not be in there any longer, but the water will not drain out of the disposal. We have a Badger as well.
Take apart P-trap located under sink.
Take photos of everything before starting so things go back easy.
Remove stuff from under sink, get some old towels, and put bucket under sink to catch water.
Loosen both nuts on P-trap and it will fall loose.
Turn on water and turn on disposal for a moment to see if blockage will fall down into catch bucket.
If disposal is still blocked, remove tailpiece connected to side of disposal and then clean out disposal with coat hanger, and/or plastic pipe that is duct-taped to shop vac hose. For a real mess, turn on the water and run disposal to clear blockage while tailpiece is off.
Clean and reassemble parts.
I use rectorseal for all tubular joints so they will not leak.
For re-assembly, I wrote tips with photos from days when I worked apartment maintenance.
Apr 22, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water has begin to spray/leak when using the
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
g
May 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Why is my badger .5 plus in sink erator leaking
One of your connections is either broken or missing a rubber gasket or a hose clamp. You have a lock ring on the top that basically bolts to the drain of the sink which is part of the disposal, IT has a rubber gasket or two on it, some have plumbers putty on the very top, the hose that goes from the dishwasher, if you have one, has a hose clamp on it, the drain line into the trap is a compression fit, needs to be tight, and it is usually bolted or screwed into the disposal itself with a rubber gasket. Check these out and tighten them up. Hope this helps.
May 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator badger 5 runs sink wont drain
Properly piped, your arrangment should look similar to this picture so that there is a separate trap for the disposal and the other sink basin.
Mar 05, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water draining backinto dishwasher from garbage disposal
You have a clog where the drain pipe leaves the garbage disposal that isn't draining fast enough or not at all. Or it could be a clog in the dishwasher drain hose where it connects onto the disposal.
Apr 07, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
610 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
