Question about Panasonic KX T7436 Corded Phone KX-T7436
How do i make a light light up on a phone - Panasonic KX T7436 Corded Phone KX-T7436
  • Panasonic Master
  • 2,460 Answers
Each button is assigned by programming. It also has to have a light to light up :-)
If you're programming an extension, then press PROGRAM 99 the button and dial 1 plus the extension number. If a line, dial 0 plus the line number. All programs are ended with STORE.
Works for me.
Carl
Posted on Oct 07, 2009
Screen stopped working today. phone rings but I can't see anything on the screen Can I fix it?
Cell phones are VERY hard to service. The problem with your phone is most likely related to the back light. Time for a new phone.
Feb 12, 2016 | Cell Phones
Nokia 1208 no backlight in lcd and keypad
hi, when there isno light on keypad, it means that the light IC controlling from the board of the cell phones that makes the keypad and LDC light comes on is damaged and needs to be replaced.
It gets damaged due to water dropping on the phone,or if the cell phones light is getting weak and can't stay on for too long..
When you replace the light, the cell phone will be ok.
Make sure you take it to an expert to fix the light for you... take care..
Jun 14, 2011 | Nokia 1208 Cellular Phone
Line 1 light will not turn off. Unpulgged all phones still on. Verizon came out and said problem on our side with phone system
This is question is about a home phone not a cellular phone so my answer is for home phones.
First off, if all of your phones are working properly, ignore the light and move on.
If the light is on a piece of Verizon's equipment, unplug all of your phone equipment and, if the light is still on, it is not being caused by your equipment. Instruct Verizon to explain the light or replace the faulty equipment.
If the light is on a piece of equipment you own it is your responsibility. Test the equipment by plugging it into the outside jack which is typically in a grey service box. One side will be marked "customer" and you may need a screwdriver to open it. Your phone company can tell you how to do this if you need help.
Now if the light on your equipment lights up you should check the manual to make sure you know why it is lighting up and if that doesn't explain it contact the manufacturer.
If the light on your equipment is off, problem is your inside wiring and you should have it inspected by a professional.
I hope this helps. Good luck!
Feb 15, 2011 | Cell Phones
HOW TO REPAIR
I think the light bulb of your phone keypad is dead.
Loose the phone and clean the phone board with methylated spirit, allow it dry and test if the light would come up.
You could also use a tiny wire to connect light from the screen to the keypad. But this could be done, if you are a phone expert.
Maybe you should just give the phone to an expert of fix the fault for you.
Take care.
Dec 28, 2009 | Nokia 6030 Cellular Phone
Just bought a Philips Digital Phone Model No.CD135. Is THERE NO BACK LIGHT on this phone as it is difficult to read screen even in daylight. I would not have purchased it otherwise. If not do you have a...
Hi
I contacted Philips by phone and the told me that there is no back light on Model No CD135. I think that is stupid as you can have a back light on the cheapest mobile phone. All handset phones should have a light so it can be used in bad light.
Frank
Sep 26, 2008 | Lands Phones
Light comes on
First, it is normal for the line 1 light to quickly flash once every hour or so while it scans all of the phones. If the light is staying on though then this is a problem.
Look at all of the phones. All will show a RED light except for one that will have a GREEN light lit up for line 1. The green lighted on line 1 means that this is the phone that believes it has the right to use the line. When one phone uses the line all of the others are given a signal through a sub carrier of line one to light up in the color red.
I would suspect that the problem phone is a wall phone unit. This is because the switch on this phone is fighting the weight of the receiver versus gravity. There is not much tolerance in these switches as you will notice if you gently put your finger on the receiver at the top of a wall hanging phone.
If it is a wall phone unit causing this problem you can do 1 of 3 things.
1- you can switch this phone to a desktop so gravity is not working against you but for you.
2 - you can put an ugly looking spacer on the button so it pushes in farther.
3- you can try to perform inside surgery on the phone to adjust the tension of the spring on this button.
Jul 05, 2008 | GE 29488GE2 Corded Phone
Light behined number pad
first check and make sure the light setting on the phone is on in some phones u can set the light feature to stay on as long or as short as you like
Jun 12, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Keypad light wont turn on
It is the problem of your ribbon flex that is connector..
If you have not a good hand you cant do it. Take it to a Motorola Repair Center.
I'm sure the phone will be full functional again.
May 19, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Lights on the numbers are not lighting up
Hi,Most phones will have that option in the display settings. You can mess with the lighting and timers on the main lcd, the front lcd (or led), and the keypad.If that doesn't work, there's most likely something wrong with the phone. Take it in to a corporate store to get it replaced with a working model.
Gizmo1
Oct 14, 2007 | LG KG800 Cellular Phone
Phone charging indicator light
register phone instuction
May 22, 2007 | GE 25861GE3 Phone
Panasonic KX T7436 Corded Phone KX-T7436 Logo
164 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
