Genius Soundmaker Value 5.1
Problem for Genius Soundmaker Value 5.1
Cmi8738c3dx sound card causing PC to hang up to welcome/logon screen
By Pols71 on Dec 24, 2007
Good day Sir/Ma'am!
I just want to fix my PC's problem regarding sound card(cmedia value 5.1).
before adding my sound card my PC is working well, but when I installed the said sound card and the driver there the problem goes. I can't solve it on my own because of my limited knowledge.
Could please help me regarding my problem sir/ma'am. Thanks in advance.
Regards,
Roland
Comments:
Dec 24, 2007
- Thank you Sir for your quick solution!
My OS is XP2, and I already did disabled the audio settings from the BIOS of my PC. The installation cd is hard to install as well as to unistall. Finally, I installed it, but another problem goes on as I restarted my pc it hangs up to up to before welcome/logon screen and my monitor is in blank mode where only I can see is the black screen. Could you please advise me of what to do so this problem could be fixed.
Thanks in advance for your assistance.
Regards,
Roland
Same Problem
Sep 30, 2008
-   sdfsdsdfsdf-   maom_14
Solution #1
posted on Dec 24, 2007
Somewhat Helpful)
shanth
Rank: Guru
Rating: 86%, 193 votes
Check whether the sound card drivers compatible with your present operating system. if your Pc built with Vista OS. then Get a vista driver from its official website.Some times When you install any devices or driver that might change the system files. even it may corrupt the files due to its incompatibility. Some mother board and Bios does not support some type of Sound cards . if your Motherboard has onboard audio .then disable it through Bios utility. uninstall the sound card,drivers. Remove the Sound card. REplug it. Restart the Pc. this time you can get add new hardware window. install the drivers. if problem still persists contact service centre.
thank you !
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thank you Sir for your quick solution,
My OS is XP2, I already disabled the audio settings from the BIOS but the problem still there, its hard to install as well as to uninstall. Finally, I installed it, but another problem goes on as I restarted my pc it hangs up to up to before welcome/logon screen and my monitor is in blank mode where only I can see is the black screen. Could you please advise me of what to do so I can fix this kind of problem.
Regards,
Roland
Popular Solutions for Genius Soundmaker Value 5.1
Questions and Unsolved Problems for Genius Soundmaker Value 5.1
Do you recommend Genius Soundmaker Value 5.1?
Answer
Answer
hello z60t ibm windows sp 2 with no sound card working in devmgmt.msc cant see any think that... (More)
Answer
Is exactly, how i said on the summarize. The problems is, I guess from windows and from the my... (More)
Answer
Hi I inserted the sound maker value 5.1 sound card into a PCI slot in my old PII. The system detects... (More)
Answer
i have compaq presario 783 tu with microsoft xp operating system. when i connect my head phone to my... (More)
Answer
The onboard sound on My mother board does not run on Windows 98se, So I got a soundmaker value 5.1.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Sound Card Experts
Top Computer & Laptop Repairmen
in , CA
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
