Question about Explorer Appliances 12 in. Domino P320MX-BO263HA Gas Cooktop
Error code E1 de dietrich hob dtv418 - Explorer Appliances 12 in. Domino P320MX-BO263HA Gas Cooktop
De dietrich induction hob dt1304je1
Sorry if you can not find it how are we going to . it is something I have never heard of in the USA
Aug 08, 2015 | De Dietrich Cooktops
Induction hob not heating up. What does 5h or SH error code indicate?
if they are not steel bottomed pans they will not work with induction hob test them with a magnet
Apr 07, 2013 | Smeg Cooktops
My cook top is beeping nonstop ! i overboiled some whater and it fell on the cooktop. now it is beeping all the time ! what should i do?
You need to contact your dealer. Tell them to fix it or replace it. Boil over water should not affect an induction stove top.
Jan 09, 2012 | De Dietrich Cooktops
On the instalation of a de dietrich dti714v does it simply sit in the worktop hole? only supported by the glass lip?
there is a foam seal to fit between the glass and worktop and there should be some brackets that go underneath to hold it firm.
basically the glass does sit very close to the worktop.
Mar 14, 2011 | Cooktops
Piezzo ignition continuously sparking without pressing any knob!
The most posible cause is that the ingiter have been mositure probably from a water leak and have be short the wires of the ingiter. Their is a small chance that it will dry by it self and be normal again. If not you can remove the top and reach for the ingiter, is a plastic box with a lot of wires in and out and with hair dryer you can try to dry it. If it still sparking again then you need to replace the igniter
Jan 12, 2011 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Light stays on in De Dietrich oven DOD438 all the time. It is in the lower oven. Stays on whether door is open or closed. Oven is new since May 2007
I too have just had this problem. The door switch (top right corner) is broken and the oven thinks the door is always open. Chances are it won't heat up either.
Apr 05, 2010 | De Dietrich 22 in. DTV315 Electric Cooktop
Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Jun 18, 2009 | Cooktops
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Explorer Appliances 12 in. Domino P320MX-BO263HA Gas Cooktop Logo
281 people viewed this question
Top Explorer Appliances Cooktops Experts
Paul Carew
Are you an Explorer Appliances Cooktop Expert? Answer questions, earn points and help others
