Question about HP Photosmart C7180 All-In-One InkJet Printer
Black ink not working
Black ink cartrage is not printing
    President:
  • 1,653 Answers
Print out a test print to see what comes out. If the printer is printing the black and colour blocks then the printer should be OK. If not then check the black and colour inks to make sure they are OK and remove each of the cartridges and reinstall them. Then run a full cleaning cycle and reprint the test sheet. Keep doing this until all the inks are printing OK. Then run an alignment test making sure that there is plain white paper in the paper tray and adjust the printer as necessary.
Posted on Oct 07, 2009
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
EPSON CX 7800 HOW DO I MAKE IT PRINT BLACK & WHITE ONLY? IT IS A COLOR INK HOG.
take yourink cartrige to staples and get in black an white only and then purshase it and put it whre the color ink cartrage was........................how the the hell do you spell cartrage?
Nov 29, 2009 | Computers & Internet
Empty Ink Cartrage message when cartrage still has a lot of ink.
I'm going to provide you a solution worth many dollars now you can use your left over half filled cartidges and in future also use the cartridges to the extreme.
1. Go to menu and select manual override for toner cartridges and then only replace toner when the print quality starts to suffer. This can save you thousands of dollars over the life of this fine printer.
2. download and read this
http://74.125.153.132/search?q=cache:9mwf_bY_x-AJ:www.refill4.com/refillinstructons/pdf_downloads/Full-RefillInstructions.pdf+brother+mfc+5840+override+cartridge+empty&cd=6&hl=en&ct=clnk&gl=in
Jul 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
Black not printing on a Brother MFC-290C
in the printer display try head cleaning option, there must be something blocking the cartridge. hope this helps
Jul 17, 2009 | Brother Multi-Function Center MFC-240C...
Color ink cartridge says empty i just filled it
When you put in a "new" cartrage the printer sens an electrical charge to the cartrage to set it up properly. So I would treat this as a new cartrage, rather than a refilled one. Go to the printer menu and re install the ink cartrage in question, it should recognise it and start the function as a new one, good luck
Mar 24, 2009 | Epson Stylus CX6000 All-In-One InkJet...
HP Officejet T45 keeps telling me I have the wrong Ink Cartridge
Clean the cartridge contacts and the printer contacts as shown here.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jan 17, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Lexmark x1190 no black ink comeing out
you may need to reinstall the cartridge once again and test
Sep 27, 2008 | Epson Stylus 880 InkJet Color Printer
Then your point is i should buy a new set of color cartrages like the 3 colors before the printing should take place then how can i set my brothers printer mfc-240c into black cartrages only no need to buy...
First - read the manual as regards printing. I notice that you can print in Black and White but I cannot find anything to say that you only need the Black ink to do this (therefore I think that I am right in saying that you need the colour cartridges).
Question - Has it worked with only the black ink before now?
As a final solution - Contact Brother direct and check out their FAQ's and/or send them an email asking if you can run the printer with Black ink only installed (I suspect the answer will be no).
If the answer to the above questions comes back as "Yes you can use Black only" (they may tell you how to set this up in which case ignore my next comments), then please supply some more information as regards what happened immediately before it stopped printing. This will help to drill down to the problem.
May 11, 2008 | Brother MFC 240C All-In-One InkJet Printer
Printer= Epson stylus Photo R200=will not print in black
The printer is designed so that you have to have ink in all the ink cartridges. They sell more ink this way. I have the same printer and investigated this a few years ago. there is no work around. Peter
Jan 10, 2008 | Epson Stylus Photo R200 InkJet Printer
HP Photosmart C7180 All-In-One InkJet Printer Logo
356 people viewed this question
Seeker5211
Seeker5211
