Question about Plextor PX-EH40L (PXEH40LT3UK) 400 GB
I have a plextor PX-EH40L NAS drive. It was working just perfectly until I screwed up. I was having to reload software on a computer of mine so I was copying data to the NAS drive. I had a file on the drive I did not need so I opted to delete of the NAS drive. I did not note that all the files on my drive were highlighted until they started disappearing. I quickly unplugged the drive. I tried to find something to recover the deleted file to no avail. I was unable to get any of the file recovery programs to connect to anything other than local drives. So SMART ME took the drive out of the case and connected my Ultra USB to IDE adapter cable to the drive and found it had 3 partitions once I configured the pins on the back of drive to 16 heads master |::| then I connected to ParetoLogic Data Recovery software and was attempting to recover the files. The software would find about 500 files and then seem to stick. I gave up on the recovery and placed drive back in case and now it will not connect to the network. Now I am not sure what the correct pin config is. I know I should leave stuff alone but I always think I can fix it.
  • bmitchell53 Nov 20, 2009
    My Plextor NAS with 250 GB drive is set to 16 head master. But I will say that I bought it used and it only worked for about a month. Know where I can find firmware?
3 Suggested Answers
ynogami21
  • 670 Answers
SOURCE: Hi, Have a PX-EH25L from a
The reason why they are unrecognized is because the hard drive aside from having a bad network card has a bad File Sytem.
Please try another computer to check if the file system of those partitions will be recognized. If not you may want to use this software called recuva and recover as much files as you could. Although it doesn't guarantee 100% file recovery I'm sure it will be able to recover the files that are still readable.
http://www.piriform.com/recuva/download
There's the link where to download the software.
Hope this helps!
Posted on Aug 22, 2011
  • 114 Answers
SOURCE: please provide manual for Plextor
You should be able to go into my computer and simply right click the drive an go to properties and then advanced and format. That should do it. If not you will have to go into system management. If you need help any further just msg me back.
Rob
If my answer has helped you today please offer four thumbs up as thanks!
Posted on Sep 03, 2011
Is there anywhere a copy of installation software?
You can download the software you need from the Plextor site, use the drop down menu on the right to select the software you require.
http://www.plextor-digital.com/index.php/component/option,com_jdownloads/Itemid,55/
Oct 03, 2013 | Plextor StorX 500GB, Gb LAN/WLAN...
Can a Plextor PX-L890UE be used with a Mac?
PX-610U for Mac according to the site this is the one they say can work ill put in the site and you can check it out. http://www.plextoramericas.com/index.php/dvd-rw/external-dvd-rw/px-610u-for-mac
Apr 19, 2013 | Plextor PX-L890UE 24x DVD PX-L890UE
Please provide manual for Plextor px-eh40l. I need to reset to factory specs - wipe out current data - be able to login defaults and reset pw
Rob
Sep 03, 2011 | Plextor PX-EH40L (PXEH40LNA) 400 GB...
My plextor digital video converter px-av100u cant work in my laptop. in my laptop i have windows 7 operating system. please tell me how can i use my capture card.
I could not download a Plextor driver that works w Windows 7. I purchased a Gigaware Video Converter from Radio Shack for $49 which works great with Windows 7. Software also converts video captures into mpeg files so saves time converting from codex.
Dec 20, 2010 | Plextor ConvertX PX-AV100U Video Capture
My HP computer does not recognize the Plextor PX-880U DVD Drive
Try getting new firmware from Plextor and see if that doesn't help the problem.
Feb 06, 2010 | Plextor (PXW5224TAT3BP10PK)...
I just got a laptop with windows7 and it will not find my network drive
Try to check your Device manager. To do this right click on the computer and scroll down to properties. After that look for device manager if there is no network drive, follow this link so to download your drive for your Pc . www.nodevice.com and look for the category you wanted.
Dec 12, 2009 | Plextor PX-EH40L (PXEH40LNA) 400 GB...
The plextor dvdr px 708a stopped working
Thanks for coming to FixYa, The problem you have is either a well documented software problem, corrupted plextor software or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then try re-installing the plextor software. Again if that doesn't work then your drive is most likely failed and you should replace it.
www.microsoft.com/kb/341060/
Hope this helps FixYa,
Chris
Jul 16, 2009 | Plextor PX-708A DVD±RW Burner
Plextor model px-av100u software
Are you still looking for the software? I have the original here if you need a copy. Do you have your serial number?
Oct 11, 2008 | Plextor ConvertX PX-AV100U Video Capture
With Windows Vista?
Unfortunately, Plextor has discontinued the unit and has no plans of EVER releasing VISTA drivers.They have never answered my e-mails about this problem...and, quite simply, us owners are screwed if we are limited to VISTA. I keep my old P4 2.8 hooked up for the occasional VHS to DVD transfer. Plextor's customer service is, was, and ever shall be, pathetic. Sorry for the bad news.
Jan 05, 2008 | Plextor ConvertX PX-AV100U Video Capture
Plextor PX-716UF
Go to the manufacturer's website and download and install the latest firmware.
Is the drive appearing in My computer with a drive letter?
If it isn't:
1. click Start, point to Run, type diskmgmt.msc, and then click OK
2. If you see your drive listed without a letter, right click on it and assign it a new drive letter
Jan 04, 2008 | Plextor PX-716UF CD and DVD Burners
Plextor PX-EH40L (PXEH40LT3UK) 400 GB Logo
444 people viewed this question
Top Plextor Computers & Internet Experts
Ben Armstrong
DROPNDEAL
DROPNDEAL
Are you a Plextor Computer and Internet Expert? Answer questions, earn points and help others
