Question about Boating
I have a 2002 ox66 200 hp engine. Runs fine but
I have a 2002 ox66 200 hp engine. Runs fine but if you let it idle for any length of time the warning buzzer comes on and says overheat. The motor pisses fine. If you turn the engine off and let it sit for awhile then start it back up you can take off without lugging down and the warning buzzer going off. I sent it to the dealer and they charged me 300.00 and said that the oil tank on the motor was low so all they did was flip the manual button on the engine and it pumped it full. The oil pump always keeps it full now but I still have the same problem...checked all the hoses etc still have the same problem!
    Champion:
  • 243 Answers
I Would Fit A New Impeller Add A Further 500ml's Oil To The Caddy Tank And Then Give It A Test Then Let Me Know What Gives
Posted on Mar 20, 2013
    Problem Solver:
  • 12 Answers
Check float swith in the primary oil tank the one on the engine It is supposed to activate the pump in the secondary tank the one in the boat.
Posted on Oct 08, 2009
  • William Slattum Oct 08, 2009
    You have a primary and secondary tank for tyour oil reservoirs. Primary is on the engine secondary is on the boat. You have a float switch in the primary tank which activates the pump in the secondary tank. Need to check that the float is not sticking and that it activates the pump. Check the float switch with and ohm meter. Also when did you last change your water pump. Sounds like the dealer only fixed the remedy not the problem. Bill
Mercury 150 hp 2 stroke 2003 everything runs fine with idle throttle lever engaged but when you put motor into gear i stalls idle to slow how do you adjust it thanks
If someone changed props this can cause this problem. You need to be careful that any adjustment is made for throttle rod and not for carbs if not an injected engine. You do not want to fool around with air mixture. Some throttle cables use threaded linkage and length of rod is adjustment for rpm. Others use a stop screw or hex head to move the throttle lever away from the housings.
Apr 01, 2017 | Mercury Cars & Trucks
Changed timing belt engine runs rough idle
Disconnect your battery, wait 30 minutes, then reconnect and drive for 30 minutes...
Mar 26, 2014 | Saturn L-Series Cars & Trucks
What would cause the head lights and instrument panel to flicker on a 2009 dodge journey
The headlight switch might be the reason the headlights are flickering. Pls try to turn off headlights and see if the instruments still show strange behavior.
If the problem persists, try pulling fuses (one at a time) to see if you can find the circuit which is causing the problem. There might be intermittent shorts / no connection in a circuit other than headlights.
Dec 04, 2013 | 2002 Dodge Durango
I have changed the timing belt on my 2002 Chrysler Sebring LXI coupe and the car runs great when it stays running. When I shut the car off and start it back up it just starts and dies but if i unhook the...
Check the throttle plates and idle speed control motor make sure there both clean.
Also check manifold vacuum at idle the best you can hold an idle. I have run into timing belt being one tooth off and engine still ran fine. But the vacuum was low that's how I could tell the belt was a tooth off.
Oct 27, 2010 | 2001 Chrysler Sebring
All warning lights flashing on dash of chevy trailblazer 2003. Runs fine all gagues go dark like truck is turned off but runs fine
All warning lights flashing on dash of my 2002 chevy trailblazer. Runs fine all gagues go dark and turn back on every now and then. Also the gagues all go to the right or stick half way like I am idling at 5000 and going at a speed of 60mph when I am sitting still. I am thinking it has something to do with my computer because the rest of the truck is working just fine.
May 18, 2009 | 2002 Chevrolet TrailBlazer
I have 2002 audit quattro TT with 180k miles. When I do a normal acceleration the car surges and rpm drop but pick back up. If I accel hard it runs fine. Also at idle at times it varies 200 rpm like a
this sounds similar to a problem i had. as the rpm went over 2000 the engine would stop for a split second and then kick back in.
after a few days looking my garage finally found the problem was a faulty air mass meter.
this cost me £200 in total to be repaired.
May 06, 2009 | 2002 Audi TT
2002 Kia Rio runs rough when idling
well spend some change and have a simple tune-up.  Plugs and filters and readjust the idle.
Mar 14, 2009 | 2002 Kia Rio
Boating Logo
114 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
