Question about Cameras
Will Anton Bauer ABC800 charger charge older, non-logic series, 'Snap-On' Propac14 NiCad batteries...?
  • 473 Answers
SOURCE: Some Ryobi 18v batteries charge, others don't.
Had the same problem with some makita batteries, Was going to throw them away so decided to take apart and see what was happening. The are made up of 1.5 volt cells soldered together, found that many had .9 volts or less and others had 1.5 or more. This means that some of the cells had gone bad (probably due to lack of chemical reaction). Found that if I collected all of the 1.5 volt together could charge just fine. Problem is it is very hard to get them all soldered back together and even harder to enclose them. If a mfg. could come up with some way to change cells individually they could make a lot of money and save us a lot. So the answer to your question is buy you at least one more battery and recycle your old one.
Posted on Mar 28, 2009
SOURCE: NiCad battery not charging
the charger adapter that plugs into the battery pac from the wall has a fuse inside it open it uo and check the fuse has not blown as that's normally the reason i get no light on the pac also using a small enough file clean off all the terminals and check that the spring terminals contacting the circuit board from the plug are not corroded and contacting correctly
Posted on Apr 24, 2009
  • 8 Answers
SOURCE: Will the ryobi nicad charger also charge the
No, but the Lithium charger will charge the NiCads.
Posted on Apr 01, 2010
al_kupchella
  • 843 Answers
SOURCE: can a lithium be charged with a nicad charger
You are probably skeptical that maybe the directions telling you not to do that are just intended to get you to buy more stuff. We've all been there. However, Li-ion batteries are very different from nicads. Used incorrectly they can be downright dangerous. So, no, don't try using the nicad charger for the Li-Ion batteries.
Posted on Apr 12, 2010
  • 5 Answers
SOURCE: nicad battery for makita want charge
For NiCd and NiMH batteries - check the battery voltage (for a good battery it is ~ 19, V); each battery contains 15 units 1.2 V each; you can test each unit after disassembling the battery case (my have 4 screws each, and the case has bottom and top parts). First charge the batteries; second, disassemble cases and check each unit voltage (shouldn't be less than 1.2 V); then take any battery tester (for AA, AAA and other batteries and accus for home usage), attach 2 long (~10 inches) wires to tester's testing contacts, and test each 1.2V unit for current - if it is in "yellow" or "red" zone - the unit is dead and needs replacement
Posted on Jun 08, 2010
Anton bauer Lifesaver quad logic series battery charger
Not a car seat...
Call the manufacturer.
Apr 14, 2013 | Baby Gear
Will the P110 charger charge a lithium ion battery
No, the P110, 18V NiCad battery charger, will not charge a 18V lithium ion battery. You need one of the dual-chemistry chargers. If you have the Ryobi ONE+ batteries, you can get the P117 charger ($30) or a charger with an extra battery (P126) from a store like Home Depot. A 6 battery charger and a 12V in-car charger are also available.
I wish that I had better news for you.
(who has the Ryobi 12V drill and charger, a few of the 4V tools, and a number of the ONE+ 18V devices and chargers. The single chemistry battery charger is not used much any more.)
Nov 24, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
18 volt dewalt lithium ion battery charger stopped working for no reason....
This can happen if the battery is too dead for too long. Keep trying to make it work like you have maybe 20-30 times. Or you can leave the battery in for a few days and let the logic chip do it's job. It should start working in a day or two.
Apr 25, 2012 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
I keep getting yellow lights on my Anton Bauer Batteries when attempting to charge them. No longer do I get a blue light after hours of charging.
The internal cells are worn out and will not accept a full charge.
A full cell replacement is required.
All batteries are an expendable, they are chemical based and degrade with time.
normal life expectancy for any battery pack is 3-3.5 years at better than 60% use them or not
I can assist you with that if you like.
Regards John Ritter 954-557-9765
www.ritterbattery.com
Sep 20, 2011 | Anton Bauer ElipZ 10k Under Camera Mounted...
What lights indicate that the battery is charging and when the battery is full. Neither of the two batteries will charge and i have lost my receipt from argos
generally the red light indicates charging and the green one indicates full charge. If both flash at the same time it usually means the battery or the charger has a problem. Let me know if you need more assistance.
Apr 13, 2011 | Drills
I had my hytron 50 Ni metal hydrate batteries repacked and would like to reset the cycles how do I do that?
The cycle count on the Anton Bauer batteries cannot be reset.
This function is imbedded in the firmware on the batteries controller
chip.
Mar 07, 2011 | Anton Bauer Logic Series Hytron 50 Digital...
Can I use the ryobi P110 charger with the P103 lithium-ion batteries ? Thank You
No. The P110 is for NiCad batteries. Any of the Li-Ion chargers like the P113 are backwards compatible and can charge either but do not try to charge Li_ion batteries in a NiCad or NiHi charger.
Dec 27, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Where recell my anton bauer batteries
I can Re-Cell any Anton Bauer Battery Pack and many other styles and makes.
Website: ritterbattery.com
or contact me direct at: siebold35@hotmail.com
Phone 954-557-9765
John Ritter
Jun 16, 2010 | Inverter Anton Bauer Pro Watt 300 Power ...
One of my dionic 90 batteries has died very shortly after not holding a charge for more than a few minutes.total charges less than 250 .any help ?
The Dionic 90 series batteries will last between 2-3.5 years or about
200-250 cycles (at 60% or better of original capacity)
At this point they can be recelled (install all new internal cells) cost is a little less than half of a new battery purchase.
Another common problem is loose or broken connections which will render a battery pack useless or dead, this can be easily repaired if caught early on before the cells self drain and go bad.
I specialize in repairing Anton Bauer and other professional video
application batteries.
Regards John Ritter
Dec 08, 2009 | Anton Bauer Cameras
Need a downloadable copy of owners manuals.
Initially the green light Must come on, but begins to flash within 5 mins or so,..this indicates that the Battery has been drained enough to start the charging process,..Most of the time we plugg in Battery with alittle bit of charge (even if it already has insufficient pwr to operate the device or tool) The charger's (diodes) will detect this resistance (back charges) and will maintain Green LED lites as long as 15min, until the battery is drained to its minimal charge capacity, before it begins to pump in a pulse of 0.6 amps/sec of charge in the battery. NiCad battery have (what is called) Memory. It is an amount of nuetralized charge in the cell when you force feed (charge) in a NiCad, that will begin to occupy (molecularly) your Nicad cell if you dont drain your battery completely between charges. In short- Drain your bat COMPLETELY before charging or it will accumulate Nuetral charges until your NiCad fails to hold full charge capacity..This will definely keep the green lite ON- when your NiCad is 90% occupied by this Nuetral charge and there's no space in your Nicad to dump charge into anymore...But you can still rescue your Battery if you so choose- buts thats another story.
Sep 03, 2008 | Drills
Cameras Logo
209 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
