Paper jam and possible failure to pull A4 paper ?
Canon photocopier seriesiR1018/iR1080 has a jam in the side tray where it can no longer pull any papers but just to make some queer noise in the process is it the problem with the drum unit or its the pair rubber that pulls the paper that is off the shaft track because it makes a shaft/tractor like noise !
so what should i do to rectify the problem please?
  • mjkb Mar 20, 2008
    The paper is jammed, but can't get it out
  • holinessn Jul 10, 2008
    The copy goes through until the end process of rolling out. On the left side it gets stuck near the rollers it catches then jams
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
1- you must remove the jam paper first
2- set the tray to LETTER or LEGAL not A4
A4 is european size not used in the U.S
Make sure the paper adjuster in the tray is touching the end of the paper size, also there should be some markings in the tray.
The noise is coming from the jammed paper, it is trying to feed itself but is stuck.
Posted on Dec 26, 2007
Canon pixma mp495 rear tray rollers only pulls paper in on one side then it jams
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Canon PIXMA MP495 Wireless Photo...
Why does ir3300 canon photocopier show paper jam between the lower tray and right cover yet no papers jamed and even else where, what could be this?
these also can occure if the paper from the cassette isn't picked up or if the paper pass the cassette and exits but sensor flapper has slow response.
As first step I would recommend to change the paper pick-up, feed and separation rollers in cassette.
Remove the cassette out, look inside, on inner right side you will see 3 tire rollers. Each roller has nose with plastic hinge. To remove him you need to push hinge on the nose and pull out the rooler to a side.
If they are worn out they will be smooth.
You can remove the rollers from the tray that works and put it into troubled one for test. If the paper jam doesn't occuress you are sure that you need new rollers.
If not I recommend to call service.Because, also the problem can be in paper lifting claw, broken gears,...
For service manual you can contact me on
Hope that helps!
Sep 01, 2011 | Canon Office Equipment & Supplies
My canon ir 2018 is asking me to load correct paper in the tray even when the paper size is correct and all the settings are correct. It would print one copy then ask to load paper, i pull out the tray and...
Check the proper orientation of the paper. For example, if you are loading A4 size. In your tray you can find 2 A4 size. Select A4R in you want to position your paper Landscape or A4 if portrait.
To verify also the correct paper size, put your paper on the platen glass. Markings on the two sides of the platen glass shows the correct paper size.
Sep 16, 2010 | Canon imageRUNNER 2000 Copier
Our machine shows E051. so what can i do.
The JAM DUPLEX message appears if you remove a sheet of paper from the face down output tray after only one side has printed.
The paper sizes you can use with the duplex printing function are A4, Letter or Legal.
If the paper adjustment lever for duplex printing is not set correctly for the paper size, paper jams may occur and the printing will be out of position on the page.
Open the back output tray.
Use both hands to slowly pull the jammed paper out of the fuser unit.
Close the back output tray.
If the paper jam cannot be cleared, go to the next step.
Pull the duplex tray and paper tray out of the printer.
Pull the jammed paper out of the printer
Put the duplex tray and paper tray back in the printer.
Click solved and vote if problem is solved. Otherwise post again
Aug 02, 2010 | Office Equipment & Supplies
My printer pulls in about 8 sheets of paper at once, shoots them through and then says there is a paper jam. There isn't a paper jam.
It may think there is a jam because it expected lets say a single A4 and when it shot the paper through the sheets became separated a little so it looked longer than a sheet of A4.
A real easy way on ensuring that you don't get too many of these situations is not to overload the feed tray. Also just before you put the paper in do the "desktop shuffle" separate it a little then tap the sheets back together on the table both top and side. Also never use paper that has been allowed to become damp in any way.
If you found this information useful please click below
Aug 12, 2009 | HP J3680 Officejet All In One Printer
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
How to photocopy double sided A4 sheets?
you copy first side normaly. then on left side open bypass deck.Put the paper, so that the side on wich you want to print is down. Automatically when you put paper in bypass, the machine ask you wich format is it ( eg. A4 ), confirm with OK, then you need to tell machine wich type of paper ( eg. plain paper ) and OK. then green copy key.
May 02, 2009 | Canon iR 1600 Laser Photo Printer
Canon ir 2016 digital copier
Are you living in the USA? The size A4 is the Europe size of paper to our letter size... You can try to take the paper tray out and look inside, for any paper jammed in the back of the paper tray area.
Mar 19, 2009 | Canon Office Equipment & Supplies
Indicating paper jam in Canon NP2120
Dear sir; When you pull out the paper opposite direction, the sensor right underneath the roller it go opposite direction too so you just check the sensor put it back to their right position should be OK,Let me know if you need more help ! good luck,
Dec 20, 2008 | Canon Office Equipment & Supplies
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
162 people viewed this question
